Staro 05.09.2006., 09:55   #1
lord_nihilus
Postovi: 224
Pentium 4 Northwood overclock
'vako... radi se o intel p4 na 2.0GHz... kloknuo sam ga na 3.1 bez povecavanja voltaze... jel mi mozete rec kaj mogu dobit sa povecavanjem voltaze??: bonker :
hvala!
There is NOTHING in existence which is too 'sacred' to be attacked.
lord_nihilus je offline   Reply With Quote
Staro 05.09.2006., 16:14   #2
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
stabilnost i veći overclock
Smartguy je offline   Reply With Quote
Staro 05.09.2006., 22:27   #3
lord_nihilus
Postovi: 224
kolko mogu dignut voltazu na svom procu a da ne s***em nes? i koji je rizik dizanja voltaze?
Field Value
CPU Properties
CPU Type Intel Pentium 4, 3000 MHz (20 x 150)
CPU Alias Northwood, A80532
CPU Stepping C1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 2000 MHz
Min / Max CPU Multiplier 20x / 20x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
CPU Physical Info
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 55 million
Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
Die Size 131 mm2
Core Voltage 1.475 - 1.55 V
I/O Voltage 1.475 - 1.55 V
Typical Power 38.7 - 89.0 W (depending on clock speed)
Maximum Power 49 - 109 W (depending on clock speed)
CPU Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization
CPU #1 6 %
Staro 05.09.2006., 22:31   #4
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Napon nemoj dizati preko 1.7V, sve više od toga je poprilično riskantno.
Rizik dizanja napona je izgaranje proca
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 05.09.2006., 22:44   #5
lord_nihilus
Postovi: 224
CPU OVERVOLTAGE: +5.0%
stavio sam tako i OCCT pokazuje da je core 1.63
sad testiram dal je stabilan tako pa cu probat jos klokat
Staro 05.09.2006., 23:01   #6
GrAviTy
Lokacija: Sweden
Postovi: 255
pa dobar si clock postigao,ja sam moj 3.06 dignuo na 3.9 i stabilno radi,dobro se klokaju ovi northwood
GrAviTy je offline   Reply With Quote
Staro 05.09.2006., 23:07   #7
lord_nihilus
Postovi: 224
OCCT ga sad testira i na 85% je... temperatura je na 64... ali inace u idleu je cca 40. sutra cu uzet jos 2 venta tak da ce se i to malo smanjit... i namjeravam uzet scythe katanu...
sad ga hladi GlacialTech Igloo 4350 Pro i super hladi... samo je malo glasan
a kaj se tice kloka, stvarno se dosta da klokat
Staro 05.09.2006., 23:11   #8
Bare_st
Bare_st's Avatar
Postovi: 319
moj 2,4 bivsi je radia na 3,4 sa temp najvecom 37 stupnjeva hladjen sa sonic towerom stabilan ko sam vrag izdrza mi je dosta prime-a i tih testova a sad imam isti proc sam 2,8 al neam plocu za klokat
Bare_st je offline   Reply With Quote
Staro 05.09.2006., 23:14   #9
lord_nihilus
Postovi: 224
evo, test je zavrsio i izgleda da je stabilan
sad cu uploadat grafove od OCCT-a pa mi recite dal je sve oke jer se ja bas i ne kuzim u to
za par minuta stizu slike...
Staro 05.09.2006., 23:20   #10
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Jesi zaključa AGP/PCI clock?Ako ne obavezno moraš..
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 05.09.2006., 23:22   #11
lord_nihilus
Postovi: 224
Staro 05.09.2006., 23:25   #12
lord_nihilus
Postovi: 224
Autor BladeRunner Pregled postova
to je ono : AGP overvoltage
PCI overvoltage ??
to nisam nista diro...
Staro 05.09.2006., 23:35   #13
lord_nihilus
Postovi: 224
argh, neda se peder na 3.2 >_<
stavio sam opet na 3.1 i sad moram provjerit ako je povecanje voltaze pridonjelo stabilnosti... nes mi je srao prije
Staro 05.09.2006., 23:51   #14
lord_nihilus
Postovi: 224
OCCT kaze da nije stabilan na 3.1 i da bi mogo nneke errorove radit... ali da je moguce da bi bio stabilan u svakidasnjoj upotrebi
da vratim natrag na 3.0 ili da budem uber kul i ostavim na 3.1?
Staro 06.09.2006., 00:49   #15
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Bolje hlađenje... stavi voltažu CPUa na 1.6V ili 1.65.
Pripazi na omjer memorije i FSBa, da ti nije memorija ošla pre visoko i povećaj voltažu memorije za korak ili 2. Stavi AGP na fixnu freqvenciju
Nemam više lema!!!
