Staro 27.08.2006., 15:55   #1
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Preporuka kucista (jos jedna):|
neko malo "bolje" kuciste ali budzet je do 450kn. najvaznije mi je zapravo da ima 2x120mm intake/exhaust i mjesta za maticnu da se moze iscupat a da ne moram hard vadit, kao sto je slucaj sa sadasnjim. zapravo je to zadnje i razlog moguceg uzimanja novog kucista.
Spoiler alert!
Staro 27.08.2006., 15:59   #2
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
CM Centurion 5
A ne ko ovo moje malo smeće...
Pazi samo razliku između mog i sky-evog stackera
http://www.imagesforme.com/images/6156DSC01939.JPG
Staro 27.08.2006., 16:03   #3
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Chieftec neki, jedino kaj nema 120mm intake, vec 92mm.
Ak hoces, mogu ti jedan dan dofurat svoje da ga vidis..
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 27.08.2006., 16:09   #4
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
http://links.hr/index.php?option=art...kl=052.601.043 - Tu neznam kako stoje sa ventovima, mislim da je iza 120mm a napred neam pojma. Kučište je mrcina..
http://links.hr/index.php?option=art...kl=052.607.028 - Ovaj coolermaster ima napred i nazad 120mm
Staro 27.08.2006., 16:18   #5
Delta S4
She`s back...
Postovi: 983
Evo jedno friško s tržnice
Ali požuri...čini se da se već neki interesiraju za njega
http://forum.pcekspert.com/showthread.php?t=45367
Delta S4 je offline   Reply With Quote
Staro 27.08.2006., 16:20   #6
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Autor Vucko Pregled postova
naprijed je 2x80 a odozada 1x120
Staro 27.08.2006., 18:55   #7
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Antec iz siga je dobar za 450kn
iveumag je offline   Reply With Quote
Staro 27.08.2006., 20:57   #8
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
ovaj cm mi se cini malen. moze neko stavit sliku kucista sa otvorenom stranicom?
Spoiler alert!
Staro 28.08.2006., 01:20   #9
John_Doe
John_Doe's Avatar
Postovi: 275
CM Centurion 5
ako mozes skupit jos cca 70kn ja bi ti preporucio i centurion534. ako nemozes onda centurion5.: goood :
Bez linkova u sigu
John_Doe je offline   Reply With Quote
Staro 28.08.2006., 08:54   #10
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
a, cuj, ja bi to ko poklon za rodendan od tete, ali ona ima relativno ogranicen budzet. samo moze linkovi za centa5 i 534?
Spoiler alert!
Staro 28.08.2006., 09:21   #11
nicko
Postovi: 4,190
evo, imas ovdje. Ja si danas kupujem CM 531 ili 534 (jos moram vidjet) pa mozes doc kod mene pogledat...
nicko je offline   Reply With Quote
Staro 28.08.2006., 10:01   #12
John_Doe
John_Doe's Avatar
Postovi: 275
Autor nicko Pregled postova
ja isto! samo, di kupujes? links? gledam na netu pise da ih jos nema a lik iz nabave kad sam ga bio zvao (cetvrtak) je rekao da su im na carini i da danas dolazi u ri. nadam se da je dosao.
Bez linkova u sigu
Staro 28.08.2006., 11:05   #13
nicko
Postovi: 4,190
Links, tako je...evo sad se vratio, uzeo centuriona 531 zbog gornjeg front panela....i moram reci da puno bolje izgleda uzivo...dosli su danas, web jos nije updatean...
Staro 28.08.2006., 11:13   #14
John_Doe
John_Doe's Avatar
Postovi: 275
u rijeku jos nisu dosli. ali, postoji nada! rekla mi cura koja radi tamo da im jos overseas nije dosao.
Bez linkova u sigu
Staro 28.08.2006., 11:35   #15
nicko
Postovi: 4,190
Onda ce uskoro...
Staro 28.08.2006., 13:26   #16
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
@nicko: hvala za link, ne bi bez tebe mogao:|
kad da dodem pogledat?
Spoiler alert!
Staro 28.08.2006., 16:23   #17
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,947
Autor John_Doe Pregled postova
Ja bi isto išao na 534
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 28.08.2006., 18:05   #18
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
dvojba je 531 i 534, samo jos treba to sve isposlovat. ici ce 534 jer samo njega imaju u crnoj boji
Spoiler alert!
Staro 28.08.2006., 18:10   #19
John_Doe
John_Doe's Avatar
Postovi: 275
meni je 534 puno lijepsi od 531.
nadam se da ce sutra doc u rijecki links pa ide sklapanje konfe.
Bez linkova u sigu
Staro 28.08.2006., 18:32   #20
nicko
Postovi: 4,190
Uzivo 531 izgleda puno bolje nego na slikama...punooo bolje...ali ipak 534 malkice bolje izgleda...
Staro 29.08.2006., 13:22   #21
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
u to sam se uvjerio jucer u linksu. oba kucista super izgledaju. daj mi samo reci, tamo mi se ucinilo da 531 ima 92mm naprijed, a pise da ima 120.
Spoiler alert!
Staro 29.08.2006., 16:28   #22
nicko
Postovi: 4,190
120mm ima...
Staro 29.08.2006., 16:40   #23
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
uvjerio sam se tome kod tebe, ocito su oni u linksu zamijenili 120 sa 92mm
Spoiler alert!
Staro 29.08.2006., 16:53   #24
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
evo bas malo gledam ta kucista po ducanima: jel taj stacker ima 300mm vent sa strane il mi se to cini?
sto kazete na onaj ammo? koliko je to razlicito kuciste od 534?
Spoiler alert!
Staro 30.08.2006., 12:26   #25
p3tar
Mozilla Slave
p3tar's Avatar
Lokacija: Daruvar
Postovi: 486
oćeš moje? izgleda da ću ga prodavati, momentalno je na procjeni, 2x80mm intake, 120mm exaust i na bočnoj 1x80mm i 1x92mm(ili 120mm ako se makne držač).propuha puno....:burn:
p3tar je offline   Reply With Quote
