Staro 26.08.2006., 00:26   #1
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Zalman ZM-B47J+7000B
Oce se tuc Zalman ZM-B47J i ovaj moj 7000b na Abitici?
triba mi odg što prije.
Danke very mač.
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 26.08.2006., 01:17   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Nebi smjeli, ja imam p4p800 koja ima slican layout ko abitica, i imam zalmana 7000 i plavog ZM-NBF47, lepezastog zalmana gore. Ide bez beda, jos ima kojih 1-2 centi razmaka... Taj lepezasti je jos i veci od ovog obicnog, tak da nebi smjelo bit problema.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
