Staro 23.08.2006., 19:32   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Konfiguracija za 4000kn sa periferijom...
Znaci trebam konfu do 4000kn sa monitorom, misem i tipkovnicom i nekim zvucnikima.
Konfa ce sluzit za knjigovodstvo, internet i eventualno za koji film ili neku stariju igru.
Nije bitno AMD ili Intel, samo da nije celeron/sempron, nego Pentium/Athlon. Nekih 512MB - RAM, te DVD-RW ak ce stat u cijenu...
Monitor nek bude neki 17" CRT, nevjerujem da ni najjeftiniji LCD stane u cijenu.
I da, grafa nest tipa X300/GF6200, eto probajte nesto skombinirat, trebao bih to do sutra.: sweating
Hvala
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 23.08.2006., 19:58   #2
Postovi: 7,568
Prijedlog:
_________________________________________________
Procesor: Athlon64 3000+, sck. 939, BOX - 618 kn
Matična: Albatron K8NF4X, sck. 939 - 417 kn
Memorija: 512MB GoodRAM DDR400 - 385 kn
Grafička: Leadtek 7300GS, 256MB GDDR2 - 412 kn
Hard disk: 160GB Hitachi, SATA II - 455 kn
DVD/RW: LG GSA-H10, Black - 268 kn
Napajanje: Fortron 350W, 12cm FAN - 210 kn
Kućište: Mode Com Step 207 - 135 kn
Miš: Logitech B58, Black - 69 kn
Tipkovnica: Logitech Deluxe, Black - 64 kn
Zvučnici: Logitech S-100 - 54 kn
Monitor: LG T710BH ezFlatron - 883 kn
Ukupno: 3.970 kn .....sve iz Ve-mila
Staro 23.08.2006., 20:17   #3
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Links...
CPU: Venice 3000+ 628kn
MBO: Abit KN8 s939 - 652kn
RAM: PQI, KIT 2x256MB, PQI3200-512DBL - 372kn
VGA: PCI-E SAPPHIRE ATI RADEON X550 Advantage - 363kn
HDD: Seagate Baracuda 7200.9 80GB 8mb cache - 362kn
DVD: LITE-ON SHM-165P6S - 258kn
Kanta: Kućište Codegen 6089L-CA, MIDI, 400W, crno, ATX2 - 230kn
Monitor: 17'' Samsung SM793DF sreb., 70 kHz, 0.20mm - 900kn
Tasta: Logitech Deluxe - 60kn
Miš: Logitech B58 - 75kn
Zvučnici Genius 2.0 SP-Q06S, crni - 65kn
Sve zajedno 3965kn ako sam dobro zbrajao...
Have a nice day...
Staro 23.08.2006., 22:59   #4
Panzer
Panzer's Avatar
Postovi: 1,814
Hvala puno : cheers2 , uzet cu vjerovatno McG-ov prijedlog, ponajvise jer je sve iz ve-mila, a najlakse mi je do tamo doci.
UPGRADED...
Staro 24.08.2006., 23:18   #5
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
@McG
Jesi možda isprobao tu kombinaciju ? Dali slučajno ima nekih konflikta ?
U planu je nešto slično i malo se dvoumim između te ploče i ECS NFORCE4-A939 te GoodRAM-a i 512MB DDR400 SuperRAM Kingmax
Od te 4 komponente koje 2 bi najstabilnije radile ? Oc ni pod razno, imaš li kakvih saznjanja ?
Zadnje izmijenjeno od: stuc. 25.08.2006. u 00:57.
stuc je offline   Reply With Quote
Staro 24.08.2006., 23:36   #6
Postovi: 7,568
@stublina
Sprobal sam kod frenda kombinaciju: Athlon64 3200+, Albatron K8NF4X i 2x512MB Kingmax SuperRAM. Sve dela kak spada i ni jedna komponenta se nije klala s drugom. Ploča dela stabilno na defaultu bez ikakvih problema, a pruža i čak solidan clock (300HTT). Kaj se tiče GoodRAM memorije, mislim da ne bi trebalo biti problema, jer je po kvaliteti/pouzdanosti u rangu Kingmaxa. Ipak, ako si sumnjičav u svezi GoodRAM-a, zemi Kingmax, razlika u cijeni je zanemariva. Za ECS ploču, nemrem ništ reći jer se dosad nisam susrel s dotičnom; po review-ima se ECS ploče čine čist solidne, a to opet ne znači ništ pretjerno kad ju nemaš prilike sprobat.
Uglavnom kombinacija Athlona64 3000+, Albatron K8NF4X ploče i Kingmax ili GoodRAM memorije, ne bi trebala stvarati nikakve probleme. Za default...bog-bogova. Pričekaj možda se javi još neko, a da posjeduje Albatron (ili ECS) ploču, ili je pak imal iskustva s dotičnima, pa da veli riječ-dve.
Staro 24.08.2006., 23:57   #7
stuc
stuc's Avatar
Lokacija: Online
Postovi: 2,404
E baš ti hvala.., cjelo popodne čitam razne review-e ( na engleskom:confused: ) i mudrujem šta sa čim sparit a da poslje ne bude nekakvih phizdarija. Iz prve ruke je uvjek zakon !
Athlon64 3000+,
Albatron K8NF4X
Gigabyte GF 7300GT PCIE , Turbo rev.
To će biti konfa za klince prvenstveno a i za sve ostale u kući, bolje rečeno
Staro 25.08.2006., 00:48   #8
alimilano
alimilano's Avatar
Lokacija: Split Hrvatska
Postovi: 936
ploča je za tu lovu OK...pogledaj moj sig
alimilano je offline   Reply With Quote
Staro 25.08.2006., 15:23   #9
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,850
Autor Panzer Pregled postova
ma ti ne znas ni do mene doci, kak onda do ve-mila
Spoiler alert!
Staro 25.08.2006., 19:56   #10
Panzer
Panzer's Avatar
Postovi: 1,814
Hehe, sad znam...
Ma kartu u ruke i vozi.
UPGRADED...
