Staro 07.08.2006., 22:12   #1
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
WLAN/LAN na Linksys WRT54GL
danas sam kupio dotican router.
1 komp se spaja na router preko kabela, drugi wireless.
oba kompu mogu fino na net, nema nikakve frke.
kak sad da namjestim da se ta 2 kompa medjusobno vide?
sNNooPY je offline   Reply With Quote
Staro 07.08.2006., 22:16   #2
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
valjda file and folder sharing, a pod network bi morao vidjet drugi komp.
To onako samo teoretski, jel nisam u praksi imal nikad to, al tak bi trebalo radit.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 07.08.2006., 22:58   #3
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
ako imas winXP na oba kompa
start->programs->accessories->communication->network setup wizzard
Drinking Rum before 10am makes you a Pirate, not an Alcoholic.
MasterX je offline   Reply With Quote
Staro 08.08.2006., 00:59   #4
Clicker
Lokacija: Đurđevac
Postovi: 21
ili jednostavno postavi istu grupu na obje mašine. CP-System-Computer Name-Change... i na oba komp. mora biti ista grupa.
Clicker je offline   Reply With Quote
Staro 08.08.2006., 01:31   #5
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
thnx!
uspio!
sve fino sljaka.
