Staro 04.08.2006., 17:31   #1
robert7
robert7's Avatar
Postovi: 1,708
Welcome screen
Molim vas za pomoć jel ću popi....
Naime kad palim komp,sve se brzo digne osim onog welcome screena,njega gledam jedno 10-ak sekundi,onda se cuje onaj zvuk,i onda jos cekam 2 sekunde i tek mi onda ude u win.
Kako to rijesiti,probao sam format i radilo je super dok nisam instalirao ZA,otad me pocelo zahebavat.
konfa je
A643000+ s754
MSI K8Neo nforce3
1024MB RAM
R9800Pro
Maxtor 120GB Sata
WinXP Pro
probao sam i deinstalirati ZA nece,probao optimizirati sa bootvisom,nece,napominjem da su svi servisi koji usm i nepotrebni ugaseni jel cim on makne taj welcom screen odma mi je za sekundu spreman za rad
help pliz
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 06.08.2006., 17:50   #2
robert7
robert7's Avatar
Postovi: 1,708
any idea nešto bump biloka?!
Staro 07.08.2006., 19:22   #3
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
Disabling the Welcome Screen
On computers running Windows XP Professional that are not members of a domain, the default is for users to see a Welcome screen that includes the names of all users with accounts on the computer. The user’s password prompt is revealed when the user clicks his or her name. Because the names of all user accounts are made visible on this Welcome screen, this behavior is less secure than using the Ctrl+Alt+Del user interface.
To disable the Welcome screen and require CTRL+ALT+DEL to be used for logons
1.
In Control Panel, click User Accounts.
2.
Click Change the way users log on or off.
3.
Clear the Use the Welcome screen check box. This also disables the Use Fast User Switching option.
Users will now log on using the Ctrl+Alt+Del user interface.
više:http://www.microsoft.com/technet/pro...c16621675.mspx
prošvrljaj malo tamo
terminator je offline   Reply With Quote
