Staro 14.07.2006., 00:24   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
CompTIA A+
Bok!
Da li ima u HR ispitih centara za polaganje A+ ispita? Vec dulje vremena pikiram proci kroz taj program certifikacije pa me zanima da li to "zivi" kod nas.
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 02.06.2008., 22:21   #2
PostuP
PostuP's Avatar
Postovi: 194
Dižem temu iz mrtvih jer me zanima odgovor na pitanje iz prvog posta.
Zna li možda netko odgovor nakon 2 godine?
PostuP je offline   Reply With Quote
Staro 02.06.2008., 22:35   #3
duggi
duggi's Avatar
Postovi: 610
span....
duggi je offline   Reply With Quote
Staro 02.06.2008., 22:40   #4
Roberto
Roberto's Avatar
Postovi: 2,654
I nakon dvije godine ggogle radi, za ovo mu je trebalo 0,15 sekundi, uz malo više vremena i truda mislim da bi pronašao i više (span...):
http://www.algebra.hr/cert_VUE.asp
http://www.it-edukacija.com/proizvod...ID=121&PID=734
Staro 03.06.2008., 00:01   #5
PostuP
PostuP's Avatar
Postovi: 194
da budem iskren, nisam se ubio guglajuci na trazenje hrv. stranica ugledao sam pce kao treci rezultat, kliknuo i podigao ovu temu
fala
btw... koji vam je klinac to "span..."
edit ... hvala na spanu nisam znao za taj span
