prcknedl
Postovi: 3,131
![]() evo ovo je kompilacija s nekoliko 5.25" rescue diskova... ![]() Windows Setup requires %ld bytes available on your %c: drive. Cannot open source file Cannot open destination file Cannot copy file Cannot create a temporary directory If you have HPFS or NTFS installed on your hard drive, you will need to create an MS-DOS boot partition to set up Windows. Unable to delete file Windows requires MS-DOS version 3.2 or later. Windows requires a computer with an 80386 processor or higher. This may be caused by too many files in the root directory. A high memory manager was not found. Setup will load a memory manager and restart. Setup cannot find a high memory manager and cannot continue. Incompatible high memory device driver installed. Remove this from your CONFIG.SYS file and run Setup again. Cannot copy Setup files to temporary directory. Run Setup again without any options by typing SETUP. Mini Windows subdirectory empty. Too many options specified. Run Setup again and specify fewer options. Disk Drive ): not ready. Cannot write to the disk. Setup cannot run from the MS-DOS prompt in Windows. Setup cannot run from a OS/2 DOS VM. Windows is not compatible with the version of 386Max memory manageron your computer. Windows is not compatible with the version of QEMM memory manager on your computer. Setup Warning G1: Setup cannot run from MS-DOS with EMM386.EXE Kor other memory managers (such as QEMM or 386Max) running on your computer. Not enough free Extended/XMS memory to run Setup. Setup needs approximately %ld bytes of free Extended/XMS memory. Windows Setup requires 'largest executable program size' to be at least %ld bytes to run. Missing cache program: A disk cache program was not found. Cannot load disk cache program, because of low memory. The following terminate-and-stay-resident (TSR) program(s)or device driver(s) are running on your computer. Windows will not install or run correctly with these programs. LoadString failed to find entry #win.comwin386.exedosx.exePATHWININST.400mini299133 Invalid temporary directory. Setup cannot continue until all hard disk problems have been fixed. Could not find the specified Setup (.CAB) file. Cannot determine the Setup (.CAB) file version(has detected a corrupt Setup .CAB file). System has run out of memory Setup has failed to determine the compression type. Could not decompress this Setup (.CAB) file. System is unable to write to the temporary directory. Setup has detected a Setup (.CAB) file reserve mismatch. Setup is unable continue with this Setup (.CAB) file. Decompression has been interrupted or canceled. Setup detected an internal error(unable to read this Setup (.CAB)) file. Setup cannot run from MS-DOS mode with a private configuration. Stack overflow Integer divide by 0 Not enough space for environment Floating-point support not loaded Null pointer assignment Packed file is corrupt edit: code tag ne radi :confused: |
#2 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,725
#3 | |
Lokacija: Pitomača(VT)
Postovi: 621
Istina da Win ima svoje "mušice" ali da je baš takav shit dal bi B.Gates bio najbogatiji čovjek na svijetu? ![]() |
ČLAN FKTa
Datum registracije: Jul 2004
Postovi: 2,264
Pa barem se to lako isključi ![]() |
