Staro 19.03.2003., 20:03   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Novi DVD/Divx player
Another DivX capable DVD player was announced at CeBIT: The Scott DVD-842 plays DivX3.11 and 4.02 and MPEG-4 ISO compatible streams, as well as WMA8 and MP3 audio. There's no word about DivX5 support though but that may just arrive via a firmware update.
Efo nova igračka, valjda če biti bolji od Kissa.
I još mali dodatak.
LiteOn has announced a new DVD standalone player at CeBIT. The LVD-2001 is not only capable of playing DVDs but also DivX and XviD. What's particularly interesting is that DivX in this case means DivX4/5 AND DivX3.11 so you can finally play all your SBC rips on a TV without having to connect a PC (or modded XBox) to your TV. KiSS' already available DP-450 player will also become DivX3.11 capable via a firmware upgrade (which also enables Ogg Vorbis playback, but not OGM). KiSS' DP-500 even has an Ethernet connection allowing you to download movies from your PC to your standalone.
I još mali dodatak.
Staro 19.03.2003., 20:39   #2
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
ajde berem su se sjetili xvida....stvar postaje sve popularnije i nebi bilo ok kad bi stand alone playeri konacno poceli pustati divx a da svi filmovi dolaze u xvid formatu
Staro 20.03.2003., 00:18   #3
Kova
***2CROwded***
Kova's Avatar
Datum registracije: Mar 2002
Lokacija: Cro
Postovi: 1,610
Ja s tim Xvidom nikako na zelenu granu...
Neznam koji player, kako codec... nešto sam skidao, no počne mi film pa stane pa ...
No jednog dana ... shvatit ću ja
Kova je offline   Reply With Quote
Staro 20.03.2003., 09:23   #4
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
u cem je rpoblem...ja sam skinio najnoviji codec i radlight ga vrti bez frke......
mozda pricas o onoj verziji LOTRa koja je bila sjebana pa je tako zastajkivala??
Staro 20.03.2003., 13:42   #5
Kova
***2CROwded***
Kova's Avatar
Lokacija: Cro
Postovi: 1,610
Ma ocito...
Budem i ja skinuo najnoviji codec
Ma dobro je da napreduju..
Jos samo da ubodem DVD przilicu..
Staro 20.03.2003., 23:43   #6
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Ma Xvid samo instaliraš kao i Divx i trebao bi (ako je sve ostalo OK) raditi kao beba uz bilo koji player. Ja ga vrtim na BS, radi i na WMP i par ostalih bez problema...
Staro 21.03.2003., 00:29   #7
Kova
***2CROwded***
Kova's Avatar
Lokacija: Cro
Postovi: 1,610
E pa da to sam i ja mislio ... i onda instalirao.. pa problemi..
Jedino ako nije bio film zeznut pa zato. Ili sam krivu seriju skinuo.
No nisam još na novom kompu stavio, budem.
