Staro 25.05.2006., 01:32   #1
Arthas
Arthas's Avatar
Postovi: 374
SilverStone NT02
Bas sam danas nabavio taj cooler i reko ajde da stavim koju sliku prije nego ga ugradim pa mozda netko ima kakav komentar (ono zaje... si se, nis ne valja itd..) Cudo je tesko skoro kilu ali stajat ce on na ploci bez beda, nadam se
I morate mi oprostiti na losim slikama, to je s motorolom napravljeno, uskoro cu nabaviti pravi pa ce i slike biti bolje hehe (kad ga budem ugradjivo na IC-7)
Ovo je u kutiji:
[img=http://img168.imageshack.us/img168/4083/24050623535mc.th.jpg]
[img=http://img97.imageshack.us/img97/1093/24050623540wl.th.jpg]
I evo redom ventilator od Everflowa, pasivac sa 3 heatpipe (2 lijevo jedna desno), pribor,pasta i vijci za instalaciju na skoro sve sockete te na kraju jedan potenciometar za ugradnju u 3.5" utor na kucistu:
[img=http://img168.imageshack.us/img168/2796/24050623555ol.th.jpg]
[img=http://img117.imageshack.us/img117/466/24050623560ox.th.jpg]
[img=http://img117.imageshack.us/img117/3218/24050623571jl.th.jpg]
[img=http://img117.imageshack.us/img117/8899/24050623588up.th.jpg]
I malo pogled sa drugih strana:
[img=http://img117.imageshack.us/img117/4508/24050623590cb.th.jpg]
[img=http://img117.imageshack.us/img117/1881/25050600006kh.th.jpg]
[img=http://img117.imageshack.us/img117/3965/25050600016lh.th.jpg]
Uskoro i slike case moddinga
1) P4 Prescott 3.0 on Abit IC-7 MAX3 with 2GB DDR400 ST
2) P4 Northwood 2.6 on PX865PEC Pro v2.0 with 1GB DDR400
3) HP Compaq nx6125 with 1256MB DDR333
4) AMD Athlon 950Mhz on MSI K7T Turbo2 with 768MB SDRAM
5) PIII 600E on Procomp BVC2B with 384MB PC100 Win98
6) PIII Celeron 1300 on Asus TUEP2-M with 384MB PC100 Linux
Arthas je offline   Reply With Quote
Staro 25.05.2006., 03:37   #2
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Kad već pitaš;ako si ga kupovao mislim da si se za***************ao...jer si mogao uzeti za manje novaca Freezer 7 Pro ili recimo Scytche Katana Cu Oni hlade isto tako ako ne i bolje;a mislim da imaš test tih Nitrogona tu na PCE,pa si potraži i pogledaj...
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 25.05.2006., 12:14   #3
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
mogao si proci bolje za te pare...uf i to koliko bolje...big typhoon
Ph03n1x je offline   Reply With Quote
Staro 25.05.2006., 15:17   #4
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
jedina stvar kaj mi se na tom kuleru sviđa je fan regulator i kutija
baterija je offline   Reply With Quote
Staro 25.05.2006., 15:59   #5
Arthas
Arthas's Avatar
Postovi: 374
hm da, uopce nisam skuzio da u ve milu imaju big typhoonea, a ovog vise niti nemaju na popisu : stoopid a dobro, sta je tu je, nije mi zao 100kn ako ce ovaj hladiti prescotta kako spada
Staro 26.05.2006., 01:10   #6
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
valjda hoce . slobodno postaj rezultate da prokomentiramo
Staro 26.05.2006., 01:43   #7
Arthas
Arthas's Avatar
Postovi: 374
Hocu, nema beda, samo kad mi dodje ploca i kad uhvatim malo vremena da testiram sa ovim stoc coolerom pa onda sa NT02
Ma jbo ga ja ako za 400kn nece dobro hladiti... jedino me malo brine to sto nije dobro ispolirana dodirna ploha sa procesorom... mozda i to prije sredim...
Staro 26.05.2006., 01:45   #8
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
ispoliraj ju dok si u ocekivanju ploce...
Staro 26.05.2006., 15:18   #9
Ozy
Ozy's Avatar
Postovi: 1,685
Imam neš za polirat,pa da pitam odmah...dakle imam Fleks-ericu pa sam samo mislio sa njom i na vodu sa recimo 1200 papirom,će to biti ok
Jerbo to poliram ovaj VF700 šta ide na NB,a možda i Freezera64Pro malo ispoliram;iako brijem da mu je baza odlična (još čekam da roba dođe sa Linksa....)...
Wolv,priključi se
Dakle može li ispast ok to poliranje samo na vodu,bez one polir paste,i tih sranja Znam da sam auto završno pred lakiranje polirao špric-kit sa 1200-kom i bilo je zaaakon!
Staro 26.05.2006., 15:47   #10
domy_os
domy_os's Avatar
Postovi: 18,906
Nećeš valjda fleksericom polirat, neće ninašta ličit. Stavi papir na neku ravnu podlogu, cooler na njega, kružne pokrete radi i poljevaj. Papire mjenjaj postupno po granulaciji, od manje na veću.
Staro 26.05.2006., 18:36   #11
Ozy
Ozy's Avatar
Postovi: 1,685
Maaaa....flekserica rulz...!
A vidjet ću još,kako budem od volje
Staro 26.05.2006., 21:50   #12
Arthas
Arthas's Avatar
Postovi: 374
Da, mislim da ci i ja do frenda malo to izglancat da na nesto lici
