Datum registracije: Jun 2004
Postovi: 368
Pomoc oko odabira....
Frend kupuje lap pa se ne moze odluciti izmedu dva HP-a. HP COMPAQ nx6125 PY421EA • Procesor: AMD Sempron Mobile 3100+ • Zaslon: 15" XGA TFT 1024 x 768 • Grafički sustav: ATI Mobility Radeon X300 do 128MB • Radna memorija: 512MB DDR (proširivo do 2GB) • Tvrdi disk: 60GB ATA • Optički uređaj: DVD RW DL • Dimenzije: 328 x 267 x 31 mm • Masa uređaja: 2.72 kg • Jamstvo: 12 mjeseci • Baterija: 3.5 h • Operativni sistem: Windows XP Home • Modem: da • Mreža: da (Gb LAN) • Bežična mreža: da (802.11g) • Audio ulazi/izlazi: da • USB podrška: 3 x USB 2.0 • PCMCIA: da • ExpressCard/54: da • TV out: da • FireWire: da • VGA izlaz: da • Čitač kartica: da (6-u-1) • Čitač otiska prsta: da • HP Docking Station(priključak): da Kvaliteta i pouzdanost Kućište je otporno na grebanje te oštećenja pri radu u pokretu. HP local Recovery Solution by Altiris omogućava brz i jednostavan način da vratite zabunom obrisane podatke. HP Pavilion dv5027EA Microprocessor Mobile AMD Sempron™ Processor 3300+ obile AMD Sempron™ Processor 3300+ Microprocessor Cache Level 2 cache 128 KB Memory 1024 MB DDR 333 MHz (2 x 512 MB) Memory Max up to 2 GB DDR Video Graphics ATI RADEON® XPRESS 200M IGP graphics Video Memory 128 MB dedicated Hard Drive 80 GB 4200 rpm Multimedia Drive DVD Writer Dual Format (+/-R ±RW) with Double Layer support Display 15.4” WXGA High Definition BrightView Widescreen Fax/Modem High speed 56K modem Network Card 10/100 LAN Ethernet integrated Wireless Connectivity 54g™ 802.11b/g WLAN Sound Altec Lansing® speakers Keyboard 101 key compatible keyboard Pointing Device Touch Pad with dedicated vertical Scroll Up/Down pad PC Card Slots * One type I or II PC card slot * One ExpressCard/54 slot (also supports ExpressCard/34) External Ports * 1 VGA port * 3 USB 2.0 ports * 1 IEEE-1394 * 1 RJ 11 modem connector * 1 RJ 45 Ethernet connector * S-video TV out * Remote control infrared port (Remote Control optional) * 1 Headphone-out w/ SPDIF Digital Audio * 1 Microphone-in port * Cable docking connector Dimensions 26.39 cm (L) x 35.78cm (W) x 3.5 cm - 4.4 cm (H) Weight 2.98 kg (6.6 lbs) Power * 65 W AC Power Adapter * 6-cell Lithium-Ion (Li-Ion) battery Unaprijed zahvaljujem. P.S. HP COMPAQ nx6125 moze nabaviti za 5200 kn, a u trgovini mu je cijena 7 k kuna, a ovome drugome je u trgovini cijena nekih 6200 kn. |
Lokacija: nasice, zagreb
Postovi: 15
po meni ovaj drugi.. vise memorije, bolji ekran, veci disk(cini mi se malo 4200rpm, ali mislim da je i gornji isto toliko), procesori podjednaki. to je moje misljenje (ps. pogledaj toshibu za te pare) |
Postovi: 268
br. 2 |
The Man
Lokacija: Novi Zagreb
Postovi: 1,252
drugi, više rama, ajde i neš jači proc, grafa na oba nije neš tak da to ni ne gledam, veči hard i po meni bolji ekran (subjektivno mišljenje što se tiče ekrana)
"Everybody's at war with different things...I'm at war with my own heart sometimes" |
Postovi: 9,069
1Gb radne memorije ce ti dosta znaciti. Makar i na prvoga mozes nadograditi jos 512Mb memorije, a razlika u procesoru, odnosno izmedju oba notebooka nije velika.
___________ Just atha x |
Postovi: 368
Puno hvala svima na odgovorima i savjetima. : cheers2 |
Lokacija: Hrv. Zagorje
Postovi: 40
evo i jac cu svoj dat drugom. |
