Staro 24.05.2006., 01:24   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Samsung to Launch Flash-Disk-Based Portable PCs
Samsung Electronics will launch two portable computers next month that use flash memory in place of a hard-disk drive for data storage, the company said Tuesday.
Flash memory has long been eyed as a potential replacement for hard-disk drives because it works faster, is lighter and more shock-resistant, but it’s still more expensive. Despite the costs, flash memory chip prices are coming down to a range that some specialist users might be willing pay for the benefits.
Samsung has built 32GB of NAND flash memory into a case the same size as a 1.8-inch hard-disk drive. The so-called "solid state disk" (SSD) has the same interface as a hard-disk drive, so it can be directly substituted with little extra work.
http://www.cio.com/blog_view.html?CID=21352
Staro 24.05.2006., 01:41   #2
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
Spremaju se opake brzine.. al još uvijek je to eskapada za većinu naših džepova
Newbie Pro je offline   Reply With Quote
Staro 24.05.2006., 07:50   #3
speedy-3
speedy-3's Avatar
Postovi: 458
a budu i cjene za koju godinu full pristupacne,,,,,, sada ce napokon i PDA uredaji dobiti veci diskovni prostor ,, ,,
speedy-3 je offline   Reply With Quote
Staro 24.05.2006., 10:09   #4
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,764
Autor Jelc
Flash memorija imas samo brzi RAT, STR je i dalje mizeran. O ogranicenom RW ciklusu ne bih sada... BTW, nije li NAND memorija battery dependant?
Programer
Staro 25.05.2006., 00:30   #5
Trek
Trek's Avatar
Postovi: 1,313
kolko je obicno znam da intelov 8 mb flash u linksysovom rotueru ima oko 10000 RW ciklusa, ovi u usb stickovima oko 1000000, taj disk moze imat oko 10-12 miljona?
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
