Povratak   PC Ekspert Forum > Računala > Storage > Mediji
Staro 22.05.2006., 22:43   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Kruzno zgrebani DVD...
Kak se zgrebu DVD-ovi, vecinom iz videoteke, ali tak da su kruzno izgrebani. I to vecinom pri kraju DVD-a. Mislim, to ziher nije necija nepaznja, jer je "kirurski" precizno. Kaj neko ima sugu od DVD playera il kaj?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 22.05.2006., 22:48   #2
mat
Postovi: 2,105
neznam puno o tome ali pretpostavljam da ga toplina lasera moze "izrezati" kada se cesto upotrebljava
mat je offline   Reply With Quote
Staro 22.05.2006., 22:48   #3
Facelessone
Facelessone's Avatar
Postovi: 4,205
dok je devede u kutiji stavi prst na rub dvd-a i vrti ga u krug..
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 22.05.2006., 23:17   #4
domy_os
domy_os's Avatar
Postovi: 18,959
Autor mat
Di je granica tvojim glupostima?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 22.05.2006., 23:31   #5
Facelessone
Postovi: 4,205
Autor mat
onda su moji devedeji isparili po tome...
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 23.05.2006., 01:35   #6
Inovator
Inovator's Avatar
Lokacija: Bjelovar
Postovi: 482
Autor Facelessone
i ne samo tvoji...
snaga lasera u čitačima i pisačima nije dovoljna za rezanje zaštitne plastike.
Staro 23.05.2006., 01:47   #7
West
West's Avatar
Postovi: 268
LOL
West je offline   Reply With Quote
Staro 23.05.2006., 02:03   #8
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Ajmeeeeee.... Kaj se ja svega načitam ovdje.
Idem sa svojom DVD przom kosit travu. Weeeeeeeeeeeeeeeeeeeeeeeeeeee.....
Staro 24.05.2006., 14:23   #9
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
......d!!!
Staro 24.05.2006., 14:30   #10
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Autor Panzer
Vjerovatno jedini razlog (ako izuzmemo to da igras frizbi sa njim) bi bio taj da se izgrebao u samoj ladici od DVD citaca/playera... pri samoj produkciji i rotiranju jer velika vecina playera u ladici ima malen zub pri rubu pa je lako vjerovatno da se DVD/CD više manje zagrebe na taj nacin...
G0RKI je offline   Reply With Quote
Staro 24.05.2006., 16:06   #11
pava
pava's Avatar
Lokacija: zagreb trnje-pescenica
Postovi: 309
Autor G0RKI
Ma kakvi, to se desava kod srotnih ili neispravnih playera, laser i mehanika se spuste prije nego se cd-dvd zautavi rotirati, pa se onda disk jos vrti po ladici.
pava je offline   Reply With Quote
Staro 24.05.2006., 22:37   #12
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
cisto hardverski problemcic, kao sto je neko naveo: i sami ziher znate vrtit onak u kutijama cd/dvd prstom. sam sam svjedok toga kad sam radio to, nisam znao od ceg i onda odjednom mi sinulo. ali nekad opet znam to napravit, onak iz navike
Spoiler alert!
Staro 30.05.2006., 11:33   #13
Mad_Duke
Autor mat
Je.. istina. Kad je vani zima, onda otvorim stari kazic i stavim neki drek u onu rupu da mi se laser upali. hebes centralno kad imas lasersko!
Autor pava
Je.. to je onaj specifican zvuk cega drugog nego grebanja. Tak je bilo meni pred 6 godina na srot cd-romu cyberdrive. koma, glasno, a kad stisnes gumb za izbaciti samo cujes huššššššššššššš.
Staro 30.05.2006., 13:45   #14
domy_os
domy_os's Avatar
Postovi: 18,959
Autor Mad_Duke
JJe.. to je onaj specifican zvuk cega drugog nego grebanja. Tak je bilo meni pred 6 godina na srot cd-romu cyberdrive. koma, glasno, a kad stisnes gumb za izbaciti samo cujes huššššššššššššš.
I izađe ladica na kojoj se vrti CD, tj. zaustavlja...
Staro 30.05.2006., 16:06   #15
Mad_Duke
Yep. Znam to po starim original audio CD-ima kupljenim pred najpster generacijom. Zapitam se, kak to da rade jos uopce!
Staro 04.06.2006., 18:51   #16
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Autor mat
- prijevod kad nemaš pojma jednostavno drži jezik za zubima.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
