Staro 17.05.2006., 13:57   #1
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Datum registracije: Sep 2004
Postovi: 1,163
W o W:guest card...
jel zna tko, da li je moguce sa guest brojem kreirat svoj novi account i poslije ga placat.
Npr, ja posudim igricu frendu on instalira i ide kreirat account sa brojem guest kartice i onda posle kupi prepaid karticu i pocne igrat??
I dal zna ko dal bi se WoW bar tak tak vuko sa 56k modemom??
JVC HX-Z10 je offline   Reply With Quote
Staro 17.05.2006., 19:40   #2
Facelessone
Facelessone's Avatar
Postovi: 4,203
da.....tak inace kad kupis igru prvo iskoristis guet carda pa onda kasnije dopises i broj s bona tak da imas 10 dana duže
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 17.05.2006., 20:16   #3
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
Al ja nebi stavio guest karticu na svoj account nego bi ju iskoristio da imam 2accounta, pa onda placam oba dva? Pa me zanima jel se to moze?
Staro 17.05.2006., 23:41   #4
Facelessone
Postovi: 4,203
da....
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 17.05.2006., 23:53   #5
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
da, kreiras novi acc s guest kodom i onda moras kupit jos jednu igru da bi mogao ukucat kao od nove igre jer inace nemozes nastavit nakon 10 dana
Staro 18.05.2006., 03:07   #6
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
Autor vga killer
a tako , nadao sam se da je mozda moguce izbjec kupnju igrice nego samo nastavit sa plaćanjem.
Staro 18.05.2006., 09:54   #7
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
ROFL - naravno ..
Blizz je odlućio gubiti novce i prodati upola manje kutija :P
LoL
Staro 18.05.2006., 10:09   #8
mat
Postovi: 2,105
hehe da, to bi bilo bas lijepo. onda bi 2 frenda kupili fino jednu igru i evo je duplo jeftinije
mozes igrat 10 dana, al moras kupit igru
mat je offline   Reply With Quote
