Postovi: 47
Kao se nadograđuje software tj. postupak za dvd player i di da skinem taj firmware?dali može što poći po zlu...? |
#2 | |
Laughing Man
Postovi: 3,041
Da može poći po zlu. Firmware i linkove potraži ovdje: http://board.softpedia.com/index.php?showtopic=1553 http://pwp.netcabo.pt/dhammer/ Postupak je relativno bezazlen, ali u slučaju da se završi sa mrtvim playerom da ga se vratit u život.
Postovi: 2,233
LG DVX9900 Unofficial Firmware by FallenAngel http://dvx9900.altervista.org USING THIS FIRMWARE VOIDS THE WARRANTY. USE IT AT YOUR OWN RISK! How to upgrade firmware: ------------------------ 1. Check the player "Model ID": a. Make sure there is no disc inside b. Go to SETUP/DISPLAY/TV Aspect and highlight 16:9 c. Press sequentially: 1, 3, 9 ,7, 1, 3, 9, ENTER d. A system information page will appear (note: factory defaults will be restored) 2. Rename the firmware file to " 3. Burn the "LG_DVD" folder on a CD-R/RW at the minimum burn speed 4. Load the disc in the player and follow the on-screen instructions 5. The upgrade process takes up to 2 minutes. When finished, the player will reboot 6. Restore factory defaults (see step 1) How to change region code: -------------------------- 1. Open the tray 2. Press sequentially: PAUSE, 0, 0, 0, 0 3. A region code setup page will appear 4. Set the desired region code (0=region free) How to change TV standard (PAL/NTSC/AUTO): ------------------------------------------ 1. Open the tray 2. Press and hold the PAUSE button for 5 seconds 3. TV standard will be changed and reported on the player display -EOF- |
