Staro 12.05.2006., 21:25   #1
maxtor
maxtor's Avatar
Postovi: 382
Question Konfa za frenda do 6500 kn
Frend kupuje novi komp pa me zamolio za savjet za kupnju,inače komp će služiti za igranje igrica,slušanje mp3,gledanje filmova pa sam mu ovo sastavio iz Ve-mila.Limit je 6500 kn a najviše bi se mogao ''isprsiti'' do 7000 kn
HDD HITACHI HDS728080PLA380 80GB SATA300 7200rpm 8MB 391,7
FDD 1.44 MB ALPS/NEC, crni 45,75
Point Of View GF 7600 GT, 256MB, PCI-E, TV-out, 2 x DVI 1595,08
CODEGEN midi tower 4063-CA, 400W, P4, USB,audio,crno, perforirane bočne stranice radi boljeg hlađenja, perforirano lice kučišta, plastične nožice; 455x200x415; 5.25"x3, 3.5"x2, 3.5" (hidden)x1 245,94
MB Albatron K8NF4U, Socket 939, NVIDIA nForce4 Ultra, 4 x Serial ATA II, SATA RAID, UDMA133, 2PCI, 3PCI-E x1, PCI-E x16, 4DDR (Dual Channel, 400/333/266MHz), 6-channel Sound, Gigabit LAN, nVidia FireWall (ActiveArmor support), USB2.0, ATX 676,12
DDR 1 GB PC3200, 400MHz, SuperTalent 645,53
Fax Modem Int. soft. V.90/92 PCI Smartlink 52,51
Monitor Samsung SM 796MB, 17" GAMER FLAT CRT, 0.20D/P, H(30-85kHz), P(135MHz), 1600x1200@68Hz, 1280x1024@75Hz, Dark Gray/Silver, MagicBright2 (Maximum brightness 500cd/m2), MagicTune, NaturalColor Pro, Highlight zone 3, TCO'99, KS17CNJBHAnalog/Digital, TC 999
DVD+RW/-RW/RAM LG GSA-4167BLB, DVD+R DL 6x, DVD-R DL 4x, Multi-Format Writing, DVD+RW (8x), DVD+R (16x), DVD-RW (6x), DVD-R (16x), DVD-RAM (5x), CD-RW (32x), CD-R (48x), ATAPI, 2MB buffer, Superlink Buffer Underrun Error Protection, black, bulk 306,56
CPU AMD Opteron 144 BOX, Sck.939, 1MB cache, 1.8 GHz 1488,79
CODEGEN Keyboard KM-1001-C9CACA, siva sa crnim tipkama i crnom linijom kod funkcijskih tipki, slim-line, PS2 37,38
CODEGEN mouse optical MO-003-CA, PS2 29,52
ODEGEN Speakers S2-007-CAC9, srebrni, 6W RMS 37,38
UKUPNO 6551,26 kn
maxtor je offline   Reply With Quote
Staro 12.05.2006., 21:32   #2
nicko
Postovi: 4,190
uzmi samo drugo napajanje, Fortrona ili Chiefteka....a onda i kuciste po volji...
nicko je offline   Reply With Quote
Staro 12.05.2006., 21:59   #3
maxtor
maxtor's Avatar
Postovi: 382
Mislio sam mu stavit Athlon64 3500+ pa me zanima koliko je ustvari operton brži od 3500+
Staro 12.05.2006., 22:18   #4
nicko
Postovi: 4,190
opteron je dobar ako hoces clockat, on na 3ghz bez beda ide....
samo sto ta albatronka nemoze ici na toliki fsb!
ili mu uzmi epoxicu i opterona ili albatronku i san diega 3700+
Staro 13.05.2006., 02:48   #5
E.T.
E.T.'s Avatar
Postovi: 2,458
Izbaci:
Autor maxtor
-Uzmi neko kuciste tipa Novatron te za napajanje Chiefteca ili Fortrona...
-Stavi si San Diego3700+ na tu plocu i malo ga oc-aj ili uzmi AMD 3000+ i oc-aj do kud ide, a 600Kn ulozi u nesto drugo.
-Vjeruj mi ne zelis Codegen misa i tipkovnicu, a jos manje zvucnike.
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 13.05.2006., 11:47   #6
nicko
Postovi: 4,190
mislim da 3000+ nemoze bas puno oc-at na toj albatronki....tako da mu preostaje izbor koji sam gore naveo...
Staro 14.05.2006., 02:36   #7
maxtor
maxtor's Avatar
Postovi: 382
Stavio sam Opertona jer je jeftiniji a bolji od 3700+
Staro 14.05.2006., 20:28   #8
nicko
Postovi: 4,190
ako se opteron ne clocka, bolji je san diego...a na albatronki se nemoze bas clockat...
Staro 14.05.2006., 20:39   #9
Postovi: 7,568
Autor nicko_029
Ne znam za ovu Ultru, ali K8NF4X bez problema dela stabilno na 300HTT-a, a ploča je i sama po sebi IMHO čist vredu.
Staro 14.05.2006., 21:59   #10
nicko
Postovi: 4,190
a onda sam je ja zamijenio sa jednom drugom....thx na ispravku...
onda opty-a i deri
