Staro 12.04.2006., 02:26   #1
MOrdecai83
Keeper of the Nine Keys
MOrdecai83's Avatar
Postovi: 193
Forceware 84.30 Win2000/XP
Ovi ih rade kao na traci...svakih 10 dana jedan novi driver.. :confused:
Evo ako netko zeli neka izvoli i isproba ih...
Mozda budem i ja ovih dana...
http://downloads.guru3d.com/download.php?det=1373
"The 84.25 were Fast, but this set simply kick Butt!
Crazy Fast, IQ is superb.
Defenitively a Keeper!"
"I have gaing 5fps in Oblivion at my static test save point...up from 23 to 28 fps. Not a very scientific way of testing perfomance, but these really do seem faster.
Had to create a cutom resolution 960x600 which I play at, as the game was crashing on start-up...so it seems not all resolutions are catered for with this set."
"Yep, in Oblivion instead of having 22FPS in a Shop in Leyawin, I now have 37!
So now I can use HDR. But 37FPS is still not much."
"Right after my test, exactly the same FPS as before being careful to make sure every single setting and overclock was the same (Control panel + game). Be careful guys cus the game changes alot of details settings when you load it on a new driver. Also the driver defaults to quality when you might have had high quality. I set all of mine back and it's exactly the same."
"BUT having re-checked my driver and game (Oblivion) settings, I can still confirm around a 5fps increase and IQ looks unchanged to me."
Rijeci nekih sa foruma Guru3D
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN
CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2)
CPU COOLER : Stock
MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8)
RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz
GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030
POWER SUPPLY : Thermaltake Toughpower 600W PSU
CASE : Thermaltake Armor Jr
HDD : 2 x Seagate 320GB HDD SATA2
DVD-RW : Pioneer DVD-RW R-110
MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200
Zadnje izmijenjeno od: MOrdecai83. 12.04.2006. u 02:37.
MOrdecai83 je offline   Reply With Quote
Staro 12.04.2006., 03:10   #2
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
ja imam 84.25 XG još uvijek. ak neko skine ovo nek kaže jel ide brže ili seru ko dosad
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 12.04.2006., 07:34   #3
MAHER
Postovi: 1,583
boring,čekam 85.XX drivere
MAHER je offline   Reply With Quote
