Staro 23.03.2006., 23:39   #1
-SSJ4-
Postovi: 28
Da li se isplati dati 6000kn za ovo????
MBO ASUS, s. 478, P4P800 Deluxe, i865PE, BUS 800 MHz, 7.1 zvuk, serial
ATA RAID, RAID, 1Gbps, FireWire, DDR 400, ATX 2
INTEL P4 HT, 3.0 GHz, 1 Mb c., s. 478, BUS 800 MHz, Prescott, BOX
RAM, 512 MB, DDR, PC-3200, 400 MHz, KINGMAX
Midi Tower, NEON CX-8959, 400 W, ATX 2, crno
VGA PCI-E GAINWARD, Ultra/1580 PCX TV/DVI, GeForce 6500, 256 MB, tv-out, DVI
FDD 1, 44 MB, 3, 5", crni
HDD MAXTOR 160 GB, serial ATA, 7200 o/min., 8 MB cache
DVD pisac, DVD±RW & DVD±R & DVD-Ram, LITE ON 165P6S-01C 16x, 8x dual layer 8,5 GB, bulk
DVD ROM Drive, 16x 48x, LITE ON, bulk, crni
Modem 56k US ROBOTICS (interni), v90, PCI
Mon. 17" SAMSUNG, SM797MB, 30-96 kHz, 0.20 mm, DynaflatX
-SSJ4- je offline   Reply With Quote
Staro 23.03.2006., 23:55   #2
Facelessone
Facelessone's Avatar
Postovi: 4,204
pa bas ti se ne isplati kupovat s.478 plocu i procesor, rađe uzmes Pentijum D805 i neku maticnu p aonda i ddr2 s tim....
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 24.03.2006., 00:38   #3
domy_os
domy_os's Avatar
Postovi: 18,867
Definitivno se ne isplati, uopće nemoj gledat...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 24.03.2006., 08:47   #4
crash owerride
See You On The Other Side
crash owerride's Avatar
Lokacija: Bistra
Postovi: 116
uopće ti se ne isplati
za te pare možeš kupit solidnu konfu sa pločom s.939 i proc-om:clap: : hello2 :
crash owerride je offline   Reply With Quote
Staro 24.03.2006., 11:28   #5
-SSJ4-
Postovi: 28
Ako nekom nije problem može li mi sastaviti konfiguraciju do 6000kn može ici malo vise ako treba,ako je netko voljan bio bih mu zahvalan.
Na kompjuteru vecinom radim programe kao AutoCAD,Photoshop,Dreamweaver,stoga htio bi da mi konfiguracija može brzo otvarati te programe i da mi ne blokaje,i naravno da mogu igrati igrice koje su trenutno u điru,ako je netko voljan molio bih ga da mi sastavi neku masinu
Staro 24.03.2006., 12:51   #6
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
neću ti sastavljati neko drugi hoće nego samo reći,što će ti modem,rama barem gigu uzmi.
Staro 24.03.2006., 12:57   #7
-SSJ4-
Postovi: 28
Autor demetrius
što će ti modem
????????????????????????????????????????: bonker :
pa eto tako da mi zauzima mista u kučištu,za ici na net za sta ce mi drugo trebat.
Staro 24.03.2006., 13:04   #8
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
Autor -SSJ4-
dsl ti ne treba????: bonker : .
Staro 24.03.2006., 13:11   #9
-SSJ4-
Postovi: 28
Autor demetrius
Za mjesecni racun od 50kn,hmmmmmmmmmmm pa i ne bas,jer nisam bas nesto puno na net-u onako kad mi nesto zatreba odem i procitat mail i to je to!
Staro 24.03.2006., 13:17   #10
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,860
ja ti ipak preporučam dsl,mene je živciralo samo surfanje,polusatno otvaranje slika,treba mu 20 min da updejta antivirus,ako ti neko pošalje 1mb mejlom opet skidaš 10 min,uzmi dsl makar osnovni paket.
Staro 24.03.2006., 13:23   #11
domy_os
domy_os's Avatar
Postovi: 18,867
Slažem se.
Staro 24.03.2006., 13:29   #12
-SSJ4-
Postovi: 28
A dobro kada tako kazes,aj mos me malo uputiti u DSL cua sam za njega i sve ali bar da vidim sta time dobivam,brzine,kako to funkcijonira mos mi ti rec ili mos mi rec di da se informiran da nebi trazia na krivom mjestu???
Staro 24.03.2006., 13:37   #13
extasy
Lokacija: st
Postovi: 371
zaleti se do t-coma sve ce ti oni rec i ako budes tija samo ispunis par stvari i to je to...samo jesi li bas u splitu ili pokraj,o tome ovisi jeli imas dostupnost dsl-a.
extasy je offline   Reply With Quote
Staro 24.03.2006., 13:57   #14
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
Ili nazoves sluzbu korisnika 08009000
Inace:
Najjeftiniji T/scum DSL te ispadne 110Kn mjesecno. U tu cijenu je uracunat promet 512MB, a savakih daljnjih 512MB placas 25kn.
IBM T43 > Centrino M750 > 2GB DDR2 > 60GB > DVD-RW > 14" XGA
Atom 230 > D945GCLF > 1GB Buffalo > 120GB > DVD-RW > HP L1940
Atom 330 > D945GCLF2 > 2GB G.SKILL > 160GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > GB DDR2 > 80GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > 2GB DDR2 > X1600Pro > 250GB > DVD & DVD-RW > SM932B
X4 9950 > AM2NF3-VSTA > 2x2GB G.SKILL > Parhelia 256 > 2x 640GB > DVD-RW > 2x SM205BW
E6300 > ASUS P5B > 2xGB kingmax > X1900AIW > 2x320GB > DVD-RW & DVD-RW > LG 194WT
dDario je offline   Reply With Quote
Staro 24.03.2006., 14:10   #15
dDario
dDario's Avatar
Postovi: 1,567
Prijedlog za komp
Monitor 17'' Samsung SM796MB, 85 kHz, 0.20mm, DynaFlatX
999,21 KN
Tipkovnica Logitech Deluxe
59,13 KN
Miš Logitech S96, optički
59,36 KN
MBO DFI nF4-INFINITY/DAGF, nForce 4, DDR, zvuk, S-ATA, FW, G-LAN, PCI-E, s. 939
772,45 KN
2X RAM PC-3200, 512MB, DDR, Corsair, Value Select C2.5, DDR 400 MHz
695,87 KN
CPU AMD Athlon64 3000+ BOX, socket 939, Venice, 1800MHz, 512kb c., HTT 1000MHz
1.062,90 KN
VGA PCI-E XFX, GeForce PCX 6600GT, 128MB DDR3, DVI, TV
1.107,07 KN
HDD 80.0 GB SAMSUNG SpinPoint HD080HJ, Serial ATA II, 8 MB cache, 7200 okr/min
447,85 KN
Kućište ANTEC SLK 3700 AMB, MIDI, srebrni, 350W SmartPower
610,44 KN
Modem Conexant 56k, interni, softverski
46,32 KN
Floppy drive 3.5'', 1,44MB, crni
45,97 KN
DVD±RW LG GSA-H20L, 16x, black, Dual layer, DVD+-R/RW/R9/RAM
384,85 KN
ukupno:6.291,42 KN
Staro 24.03.2006., 14:22   #16
domy_os
domy_os's Avatar
Postovi: 18,867
Ja bih stavio MSI-evu K8N Neo4-F(I) ploču, s njom ima manje zajebancije, ima bolji zvuk i ostale sitnice i neku drugu grafu tipa X800GTO...
Staro 24.03.2006., 14:25   #17
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor dDario
Inace:
a da nije možda 20kn svakih 512mb
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 24.03.2006., 14:46   #18
domy_os
domy_os's Avatar
Postovi: 18,867
I Start paket je 99 kn...
Staro 24.03.2006., 15:15   #19
Rijecanin
Rijecanin's Avatar
Postovi: 289
Potpisujem sve rečeno, giga rama, zajebi modem i ako je ikako moguće 17 ili 19" LCD... Zajebi ova CRT djubreta...
Rijecanin je offline   Reply With Quote
Staro 24.03.2006., 15:21   #20
Postovi: 7,568
Prijedlog:
__________________________________________________________
Procesor: Intel Pentium D 805, sck. 775, BOX - 1.071 kn (Diskont24)
Matična: Asus P5LD2, i945P chpiset - 930 kn (Links)
Memorija: 2x512MB GeIL Retail DDR533 - 728 kn (Links)
Grafička: MSI Radeon X800 - 1.055 kn (Links)
Hard disk: Samsung 160GB, SATA II - 578 kn (Bing)
Floppy drive 3.5'', 1,44MB, Black - 45 kn (ve-mil)
DVD/RW: LG GSA-4167BLB, Black - 306 kn (Ve-mil)
Napajanje: Chieftec 400W, 12cm FAN - 335 kn (Ve-mil)
Kućište: Chieftec BG-01B-B-SL - 300 kn (Ve-mil)
Monitor: 17" CRT LG Flatron F720B - 883 kn (Bing)
Ukupno: 6.231 kn
Staro 24.03.2006., 16:15   #21
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor -SSJ4-
Di si nasao tu plocu, i kolko kosta?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 24.03.2006., 21:18   #22
-SSJ4-
Postovi: 28
ASUS, P5GD2-X LGA 775, Intel 915P, FSB 800, 4xDDR2 533/400 DUAL CHANNEL, PCI-Ex16, 3xPCI-Ex1, 3xPCI, U/ATA100x1, S/ATAx4 ports, Marvell LAN, USB 2.0, 8 kanalna zvučna, S/PDIF-out, ATX
Intel Pentium 4 3.0 GHz, cache 2MB 800MHz S775 BOX P4-630, LGA775-LAND, 64 bit
TWINMOS DDR2 1GB DDR533 CL4 240pin U-DIMM TWINMOS DUAL CHANNEL, 3 godine garancija
ASUS, PCI EXPRESS, EN6600SILENCER/TD, GeForce 6600, PCI-Ex16, 128MB DDR3 128-bit, DVI-I, TV-out, engine clock 300MHz, memory clock 550GHz, RAMDAC 400MHz, max resolution 2048x1536, 15-pin D-sub, S-Video and Composite
FDD 1.44 Mb, 3.5, Samsung Black
Western Digital, Caviar 160 GB, WD1600JS, SERIAL ATA II, 8MB cache, 7200rpm
DVD-ROM SAMSUNG, bulk Black, Free PowerDVD Software, DVD (16x), CD (48x), Buffer 512KB, Lead-Free, Magic Speed Function, A.B.S., DVA, MPEG II Card & Soft MPEG Compatible...Awaken your senses!
DVD+RW/-RW RAM SAMSUNG Super WriteMaster™, RETAIL version with Black bezel, Double Layer DVD+R (8x), DVD+/-R (16x), DVD +/-RW (8x), Buffer 2MB, Low CPU usage, Lead-Free, Magic Speed Function, Double OPC, Silent PWM, SAT, Tilt A.C.T., A.B.S., A.M.L.P.U., DVA, Buffer Under Run Free Technology...Mastering all your storage needs!
Modem 56k V.92,K56 Flex, Flash nadogradivi, PCI, Conexant, Smartlink, Asonic, Retail
CASE MSI MIDI ANDROMEDA MDC-811-400W - MSI MIDI TOWER, SECC METAL, USB 2.0, AUDIO IN I OUT, NAPAJANJE 400W S 12CM VENTILATOROM,EMI FILTERI, SATA, PCI EXPRESS I P4 12V KONEKTORI, KOMBO KONEKTORA SA 24 NA 20 PIN, WIND PIPE (IZLAZNI TUNEL NA UNUTARNJOJ BOČNOJ STRANICI KUĆIŠTA ZA BOLJU CIRKULACIJU ZRAKA UNUTAR KUĆIŠTA)
SAMSUNG 797MB 17" FLAT CRT, 0.20D/P, H(30-96kHz), P(250MHz), 1920x1440@64Hz, 1280x1024@85Hz, Ivory, MagicTune, NaturalColor Pro, Magicbright II, Hightlight zone III, TCO'03, LH17ISBBH
JE LI OVO BOLJE???
Staro 24.03.2006., 21:30   #23
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
nije
Staro 24.03.2006., 21:34   #24
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
Jedine zamjerke na graficku i dvd snimac, ovo ostalo sve moze proci...
-potpis-
h3lld je offline   Reply With Quote
Staro 24.03.2006., 22:28   #25
-SSJ4-
Postovi: 28
Zasto nevalja sa grafičkom i dvd snimačem????
to su ono jedine koje su mi se cinile ok sve ostalo je previse skupo a nesmim preci dozvoljeni prag sto se tice love
Staro 24.03.2006., 22:34   #26
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Autor -SSJ4-
Ja bi ti preporučil da još jednom pročitaš McG-ov prijedlog
psf[i]-[Tomek] je offline   Reply With Quote
Staro 24.03.2006., 23:22   #27
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
također...
samsungova optika nije ni za qurac, ispričavam se na izrazu, ali tako je...
a za oko 900-950kn se nađu prave 6600GT
Staro 25.03.2006., 17:47   #28
mat
Postovi: 2,105
ne kuzim zasto ubijate decka u pojam?!!??!
ako ne koristi internet i mjesecno s dial-upom napravi faking 50kn onda mu dsl sigurno ne treba jer ce platiti mjesecno 150kn a nece nista dobiti... eventualno ce se navuc na internet servise na kojima smo mi brijali prije 10 godina i onda nece imat love platit... pustite ga na miru moj dragi bože ne mogu vjerovati da ga svjesno u t-faking-com šalju
AKO SLUČAJNO ćeš i pomišljati na brži i bolji net: DCM. ak nije dostupan kod tebe onda neznam sto da kazem al nemojte ga probijat ovakvim premutavim pitanjima "sto ce ti modem" i "ne treba ti dsl?"... *križa-se*
mat je offline   Reply With Quote
Staro 25.03.2006., 18:12   #29
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Autor McG
Prijedlog:
Ukupno: 6.231 kn
Pa ti si pobogu promjenio copy/paste
Nema sta, konfa i pol, a 2 jezgre nisu vise za odbacit.
Staro 25.03.2006., 18:28   #30
Postovi: 7,568
Autor Vucko
Prilagođavam se modernijim vremenima
