Staro 12.03.2006., 01:58   #1
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Thumbs up 7600 @ AGP?
The launch of Nvidia 7900 and 7600 series on Thursday didn't contain AGP at all, but several Taiwanese manufacturers are gearing up to produce yet another wave of boards featuring Nvidia's BR02 AGP-to-PCIe-to-AGP chips. The product will probably go by the name 7600GS AGP, and it will feature a PCB very similar to the 6600GT.
Suggested specs are 500MHz core clock speed - BR02 chip supposedly has problems with chips clocked over 500MHz) and 256MB of GDDR-3 memory clocked at either 1000 (conservative Taiwanese VGA manufacturer - or 1300MHz (overclocking-friendly Taiwanese VGA manufacturer.
Izvor: Inquirer
psf[i]-[Tomek] je offline   Reply With Quote
Staro 12.03.2006., 02:28   #2
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
...naravno kad se agp grafe prodaju odlicno,ne bi me cudilo da jos dvije naredne generacije gpu-a budu izlazile za agp slot...
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 12.03.2006., 02:32   #3
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,165
Pa u biti me ne cudi da ce ipak izaci AGP verzija buduci da je GF7600 navodno pin kompatibilan sa GF6600...a cak trosi i manje struje.
Samo je neoprostivo da ce mema biti samo na 1000MHz.... 1400MHz kao i na PCie verziji bi trebalo bit i tocka No meni se cini da ce to na kraju zavrsit kao i prica sa 6600GT... AGP verzija trebala imati 900MHz memoriju, na kraju su skoro sve imale 1000MHz i vise.
Staro 12.03.2006., 05:26   #4
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Autor The INQUIRER
So, if you still have an AGP machine and would not trade your Mobile Athlon XP clocked at 2.5G and nForce2 SoundStorm solution, not to worry. 7600GS just might be the answer to keep you waiting for the first wave of DX10 mainstream parts, which is currently scheduled to hit the street during CeBIT of 2007. µ
G0RKI je offline   Reply With Quote
Staro 12.03.2006., 10:40   #5
MAHER
Postovi: 1,583
moja verzija ima 900mhz memu,ali to ništa ne znači jer je to ista mema i ide na 1200mhz
MAHER je offline   Reply With Quote
Staro 12.03.2006., 19:51   #6
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor JC Denton
Mema je i 6600GT, a pogotovo 6600 gusila. Kartice su imale fin fillrate ali relativno malu mem. propusnost(128-bit)
Staro 12.03.2006., 23:21   #7
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Da a da su imale 256nitnu sabirnicu onda to vec ne bi bilo to...niti bi to bila 6600 GT! A sad...to bi lipo bilo kad bi imal toliku propusnost..ALI... to joj nije bio cilj
Staro 13.03.2006., 16:39   #8
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
Autor MAHER
ti miša imao si sreće ja došo do 1100 al moro spustiti na 1050 jer su mi u c&c generalsu počele texture pucati,ne znam za druge igre,koji će biti prajsić u nas 7600 gt agp??,da se znam polako pripremati za promjenu 6600gt.
Staro 13.03.2006., 17:44   #9
marconi
marconi's Avatar
Postovi: 130
Autor demetrius
to ti se uopce ne isplati.nema TOLIKO velike razlike da vrijedi 1500kn koliko ces dati za novu grafu.
marconi je offline   Reply With Quote
