AutoCad & Allplan expert
Postovi: 2,159
#2 ati x800gto agp
Model X800GTO256 AGP GPU ATI Radeon X800GTO 12 pixel cjevovoda Sučelje AGP 8x Memorija 256 MB 256-bit GDDR3 jel ima ko doticnu grafu? moze malo komentara? oc? ono najvaznije; dali se da odkljucat onik dodatnih 4 pipelina? znam da o tim karticama postoji vec hrpa tema, ali nema bas odgovora koje ja trazim, a meni je hitno jer mi je to jedna od opcija....
none |
Lokacija: n/a
Postovi: 6,128
Ona radi na 400/980 i prakticki je to X800Pro kod kojeg je GPU downclockan na 400MHz. |
Hejter
Postovi: 6,521
Ovisi i koja jezgra - neke su sklonije kloku npr. r480 , do kdruge nisu . |
Postovi: 18,874
R423 se također kloka u nebesa...
Hejter
Postovi: 6,521
Po vidjenome najbolje ide r480 , pa r423 pa 430 , ak sam dobro zapamtio . |
Postovi: 18,874
Ja svoju nisam testirao do kraja, al 560-570 MHz ide.
Postovi: 18,874
PCI-E
Lokacija: Osijek/Ansfelden
Postovi: 225
danas bi trebao frendu ugradit jednu takvu pa chu vidit jel se moze otkljucat. ot: s kojim se programom otkljucavaju radeonke? |
Postovi: 18,874
Treba preflešat BIOS... Ak nemaš PCI grafu, nemoj se igrat, ak ipak oćeš i sjebeš, javi se, al plaćaš cugu. ![]()
#12 | |
Postovi: 1,816
bios with a hex editor. I download an editor named "010 Editor" for a try and seems to work OK but there are many available. In my BIOS the byte at address 0x7A was 0x61. The "1" here disables one quad ( 4 pipes). I edited 0x7A to read "60" and then saved the file. I then loaded and resaved with RaBiT which I think only needs to produce a correct checksum. Of course before any of this happens you need to verify that the fuses are not hardware locked per http://www.techpowerup.com/articles..ing/vidcard/127 I'm not sure if this is relevant but there seems to be several versions of the Sapphire X800GTO AGP board with possibilities for R430 and R480 cores. My version is R430 on a red ATI X800 XL type board. Some of the reviews I have seen show the card with a blue board (like the PCI Express version) that looks shorter than mine and has a completly different heatsink. Some boards are hardware locked and cannot be modded with just a BIOS change.
Stupid is as stupid does |
Postovi: 1,816
Dosta sam trazio i nasao sam za Sapphire model s 256MB da se da fleshati ako je gore R430 s Biosom od Radeona X800XL. Za sve druge kombinacije mislim da ti preostaje samo ovaj nacin editiranja Biosa! Mislim da i moras pomocu ATI Toola provjeriti da li je kartica uopce modabilna.
