Doktor znanosti!
Lokacija: Zg,Peščenica/borongaj
Postovi: 1,311
Ja sam inace naklonjeniji Gigabyte-u....Ali sto vi kazete?... Prva ploca MB Gigabyte K8N51GMF9, s939 Gotovina:530,18 kn Opis Model GA-K8N51GMF-9 Podržani procesori AMD Athlon64 X2/ 64 FX/ 64 Chipset NVIDIA® GeForce™ 6100 and NVIDIA nForce™ 430 Memorija 4 x DDR400/333/266 -184pin Dual Channel podrška 4 GB maksimalno Utori 1 x PCI-Express X 16 slot 1 x PCI-Express X 1 slots 2 x PCI slots (PCI 2.3 compliant) I/O interni konektori 4 X Serial ATA 3.0Gb/s 2 x UDMA ATA 133/100/66 Bus Master IDE connectors 1 x FDD connector 2 x USB 2.0/1.1 connectors (4 porta) 1 x IEEE 1394b connector (1 port) 2 x cooling fan pin headers S/P DIF in/out connector CD in 1 x Com port connector I/O eksterni konektori 4 x USB 2.0/1.1 ports 1 x RJ45 ports Audio (4 x Line-out/ 1 x Line-in/ 1 x MIC) connector PS/2 Keyboard/ Mouse 1 x IEEE1394 port 1 x LPT 1 x VGA port 1 x S-Video port (TV- out) Napajanje ATX power connector and ATX 12V connector Dimenzije Micro-ATX form factor (24.4 x 24.4 cm) Ostalo VIA VT 6307 IEEE1394 controller CICADA8201 Gigabit LAN PHY chip Realtek ALC880 Audio Codec 2. ploča MB Albatron K8NF4X, s939, nForce4-4x, SATA, LAN Gotovina:486,78 kn Opis Model K8NF4X Podržani procesori Socket 939 AMD Athlon™64 / Athlon™64 FX /Athlon™64 X2 Dual Core Processor 800/1000+ MHz FSB Chipset Chip : nForec4 4X ( Single chip) LAN Chip : Broadcom MCSAC131 (PHY) 10/100 Audio Chip : Realtek ALC655 I/O Chip: Winbond Smart I/O W83627THF Memorija 4 × DDR400/333/266 Max. 4GB Dual Channel podrška Utori 1 x PCI Express x 16 3 x PCI Express x 1 2 x PCI slots (PCI 2.3 compliant) IDE / SATA konektori 2 ATA133 Channels 4 Serial ATA150 Channels I/O interni konektori 1 x Floppy Connector 4 x USB 2.0/1.1 header 1 x S/PDIF in/out header (S/PDIF in/out cable optional) 1 x CPU fan header (1 fan rotation detection function) 2 x System fan headers 2 x 5 pin system panel header (Intel spec) 1 x 3 pin Power LED header 1 x Front audio header (Intel spec) 1 x ABS header I/O eksterni konektori PS/2 keyboard/mouse 2 x USB(2.0/1.1) RJ45 1 x Com (serial) 1 x Parallel 1 x RCA 1x Line-in/Line-out(Speaker Out) Napajanje ATX (24-pinski konektor), ATX12V Dimenzije ATX (293 x 198 mm) Ostalo Zero Jumper Design Adjustable CPU frequency by 1 MHz increment, Adjustable Vcore,,VMemory for overclocking. Watch Dog Timer (auto-reset system when it can not handle overclock configurations) Special design for CPU Over Temperature Protection. (OTP) I sto kazete koja je bolja?? Hocu sto manje para potrositi pa ciljam na jeftinije ( ali kvalitetno)... A posto gigabyte-ica ima integriranu grafu.. nebi morao pare i na to trositi...I kaj velite?? |
Lokacija: ri
Postovi: 42
ako se ne misliš ozbiljnije igrat i ne zanima te klokanje bolji izbor ti je gigabajtica...... opremljenija je, ima sata2, fajrvajr i giga lan, i integriranu grafu.... s druge strane albatronka se izvrsno kloka........ |
#3 | |
-nVidiot-
Lokacija: Varaždin/Zabreg
Postovi: 962
#4 | |
Lokacija: Zagreb, Centar
Postovi: 1,796
Re: MB Gigabyte K8N51GMF9, s939 ili MB Albatron K8NF4X, s939, nForce4-4x
Gigabyte, zvuči lijepo, dobro, jeftino, ali... pročitaj |
#6 | |
Postovi: 1,796
#7 | |
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Albatron NF4 radi kao zmaj,nacitao sam se hvaljenja o ploci pa sam na kraju i kupio jednu,tj preporucio je dobrom frendu,znam skocit do njega tu i tamo i ploca je rock stable i bez ikakvih simptoma bolesti,a mali sempron je uspjesno klokan na 2500Mhz,sve u svemu Albatron je napravio odlicnu plocu za tu cijenu!
Lokacija: Beograd
Postovi: 6
A koliko samo ljudi ima problema sa DFI plocama... Ne mozes samo na osnovu svog slucaja i slucaja nekolicine ljudi reci da je Gigabyte smece...kada napises zasto je neka ploca smece onda napises i zasto to mislis da covek ne ostane u zabludi...a ja iz mog iskustva mogu kazem da sam Gigabyte plocama vise nego zadovoljan ![]() |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
problem je u tome kaj ploce kao takve nisu smece, al BIOS-i su jako lose napravljeni i tim cine ploce losima... Ne govorim, al osim sto je tu na forumu bilo prica o tome, o gigabytu i njihovim biosima, sam sam se uvjerio u 2-3 ploce na kojima nije memorija radila normalno...ponekad radi, al u vecini slucajeva radi sporije neg sto treba...
#10 | |
Lokacija: RI
Postovi: 4,918
#11 | |
Postovi: 1,796
Zato sam i dao link da čovjek i sam vidi, iz iskustva drugih ljudi, zašto ta ploča nije dobra. Sam sam naručio jednu Gigabyte, ali se nadam da će radit dobro, no to ću tek saznati za oko mjesec dana. Radi se o ovoj ploči |
#12 | |
Lokacija: RI
Postovi: 4,918
