Staro 08.02.2006., 21:26   #1
DrTom
Resistance is futile
DrTom's Avatar
Postovi: 1,212
Question Samsung 940BF
SAMSUNG SM940BF
Ima li tko od Vas kakva konkretna iskustva s tim monitorom?
Ono što me očaralo kod njega je response time od samo 2ms.
Inače, radi se o 19" LCD monitoru, da ne bi bilo zabune. Koliko
sam ja shvatio, to je nasljednik 930BF modela koji je jako
nahvaljen. Ima li smisla to kupovati? Kroz mjesec/2 bi mogao
sakupiti lovu pa ubosti nešto u tom rangu. Da li baš njega ili imate
još neke favorite?
Najjeftiniji je koliko vidim u M-computersu, 3502kn.
Staro 09.02.2006., 22:05   #2
DrTom
DrTom's Avatar
Postovi: 1,212
A da vidimo sad ovo... komparacija modela...
Samsung 940BF
Display type - Flat panel display:TFT active matrix
Viewable screen size - 19" (48.26cm)
Max resolution - 1280 x 1024
Response Time - 2ms (grey to grey)
Dot pitch - 0.294 mm
Color support - 24-bit (16.7 million colors)
Image brightness - 300 cd/m2
Display (projector) image contrast ratio - 700:1
Max vertical view angle - 160°
Max horizontal view angle - 160°
Max sync rate (V x H) - 75 Hz x 81 KHz
AOC LM2028
Display type - TFT Active Matrix LCD, Slim Cabinet
Viewable screen size - 20" (50.8cm)
Max resolution - 1600x1200
Response Time - 16ms (grey to grey)
Dot pitch - 0.255mm
Image brightness - 250 cd/m2
Max vertical view angle - 170°
Max horizontal view angle - 170°
Max sync rate (V x H) - 75 Hz x 80 KHz
Nemojte se sramiti, slušam preporuke i mišljenja...
Zadnje izmijenjeno od: DrTom. 09.02.2006. u 22:37.
Staro 09.02.2006., 22:16   #3
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
komentar
Nemam više lema!!!
Staro 09.02.2006., 23:38   #4
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Nema crnih
Staro 10.02.2006., 17:48   #5
nicko
Postovi: 4,190
ma samsunga tog uzmi, u toj klasi je najbolji...
nicko je offline   Reply With Quote
