Staro 04.02.2006., 14:56   #1
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
blaster worm
možete mi reći čemu služi win xp zakrpa blaster worm
CPU AMD Athlon64 BOX 3200+sck939 // MB Gigabyte K8N-SLI s939 nForce4 SLI // Powercolor Radeon x800gt // 2x256 MB RAM // HDD Seagate 120 GB s-ata150 // DVD+RW/-RW NEC ND-3550ABL // Codegen midi tower 6205L-CA, 400W // Mon. Samsung SM793DF 17" DynaFlat // ASUS TV TUNER My Cinema P7131H Dual
blondie je offline   Reply With Quote
Staro 04.02.2006., 15:06   #2
domy_os
domy_os's Avatar
Postovi: 18,959
Po seljački: krpa rupu u Windowsima kroz koju se može provuć crv Blaster i naredit isključivanje kompa čim se spojiš na net.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 04.02.2006., 18:24   #3
blondie
blondie's Avatar
Lokacija: split
Postovi: 198
a po stručno......
Staro 04.02.2006., 19:31   #4
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
I ovako po seljacki je dobro receno. Vise od toga nije vrijedno pisanja, ako nemas instaliranu zakrpu pozuri jer vrag nikad ne spava....
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 09.02.2006., 10:15   #5
AC Thunder
Lokacija: InTheAir
Postovi: 206
Ovo radi crv Blaster:
Distributed Denial of Service Attack
Once it secures an Internet connection, this worm checks for the current system date. On the following system dates, it launches a thread that performs a Distributed Denial Of Service attack against windowsupdate.com:
* On the 16th to the 31st day of the following months:
o January
o February
o March
o April
o May
o June
o July
o August
* Any day in the month of September to December.
When performing the DDoS attack, this worm constructs a specially crafted packet around 40 Bytes in size, and continuously sends it as a SYN packet request to http://www.windowsupdate.com every 20 milliseconds.
The packet does not contain any data except for its TCP/IP header. It is constructed such that this worm can spoof the sender’s IP address.
Also, if this worm fails to resolve the Web site, http://www.windowsupdate.com, it uses 255.255.255.255 as destination address instead for the DDoS attack.
As of this writing, Microsoft had already disabled the redirection of http://www.windowsupdate.com to the real Windows Update site, http://microsoft.windowsupdate.com. This prevents the Windows Update site from being attacked by the worm’s DDoS payload.
Exploiting the RPC DCOM Buffer Overflow
This worm exploits the RPC DCOM BUFFER OVERFLOW, a vulnerability in a Windows Distributed Component Object Model (DCOM) Remote Procedure Call (RPC) interface, to infect remote machines. The vulnerability allows an attacker to gain full access and execute any code on a target machine, leaving it compromised.
(TrendMicro)
Ukratko Blaster zajebava Microsoft update zatrpavajuci ih paketima velicine 40 Bytes sa zarazenog kompa dok je spojen na internet. Jednostavno, ak apliciras zakrpu Blaster to vise nece moci raditi, a komp se nece odspajati sa interneta.
P.S. Blastera dobijes sasvim slucajno dok si na internetu (a nemas instaliranu zakrpu) jer on stalno skenira IP adrese sistemom slucanosti i provjerava da li je port 135 nezasticen, kad nanjusi otvorena vrata upada i zabava pocinje.
AC Thunder je offline   Reply With Quote
