Staro 04.02.2006., 01:20   #1
speedy-3
speedy-3's Avatar
Postovi: 458
Cooler
evo ga trenutno imam ovaj cooler
Model No.
* ‧ TTC-D5TB/G
Specifications
Outline Dimension 80 x 80 x 66.5 mm
Fan Dimension 80 x 80 x 25 mm
Rated Voltage 12V DC
Rated Current 0.16 A
Power Consumption 1.92 W
Rated Speed 2800 ± 10%RPM
Airflow 37.57 CFM
Static Pressure 3.45 mm H2O
Noise Level < 32 dBA
Housing 2510-3P
3Wire, 3Pin Connector
No. of Pole 4 Pole
Bearing Type Sleeve / One Ball / Two Ball / Z-AXIS
Life Time 25,000 / 35,000 / 50,000 / 60,000 Hours
Packing
1CTN(PCS) 50
G.W.(KGS) 17.6
MEAS'T(CUFT) 1.68
i laganini rikava,,,, vrijeme je da se mijenja,,,
mislio sam uzeti
COOLERMASTER, Alps HHC-L61,
Material izrade hladnjaka Copper with Heat Pipe
Dimenzije ventilatora 60 x 60 x 25 mm
Brzina ventilatora 3000 rpm
Strujanje zraka 14.3 CFM
Vrsta kugličnog ležaja Dual Ball Bearing
Napajanje 12V
Razina buke 25.5 dBA
Konektor 3 Pin
Težina 530g
Toplinski otpor Rja 0.65 C/W
zanima me je zna itko koliko je taj cooler dobar ili nije,,,
ce moci drzati temp kao TITAN
ovo mi everest govori.... s otvorenim kucistem,,
speedy-3 je offline   Reply With Quote
Staro 04.02.2006., 11:34   #2
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
jel to ono smece s heatpajpima? ako je, bjezi od toga sto noge nose...to je bilo smece i pred 4g, kad je hladilo (nije) atghlon xp 1900....
samo na sadasnji kuler stavi neki novi vent (preporucam arctic cooling, glacialtech il spire, to je jeftino i dobro)
