Staro 26.01.2006., 18:47   #1
jonai
jonai's Avatar
Lokacija: gl
Postovi: 15
Matična
Imam jedno pitanje. Koja bi bila najbolja ploča ASRock proizvođača za P4 640 u svrhu overclockinga? Ili možda nekog drugog proizvođača?
jonai je offline   Reply With Quote
Staro 26.01.2006., 20:47   #2
Pr@ko
Pr@ko's Avatar
Postovi: 127
ASUS P5WD2-Premium Definitivno!
CPU Pentium 4 3E
MBO ABIT IC7-G
RAM OCZ Platinum Rev2 2x512MB
VGA ATI Radeon X850XTPE
HDD WDC1200JDX2; WDC800; WD740GD; WD1200JB
OKO LG F920P
POW Chieftech 420W DF
CAS Chieftech Bravo BIG
Pr@ko je offline   Reply With Quote
Staro 26.01.2006., 22:20   #3
Lignja
Re Di Calamara
Lignja's Avatar
Datum registracije: May 2002
Postovi: 570
kaj vec imas 640 ili bus ga tek sad kupil
jer ako ga sada uzimas
rade kupi cedar mill jer je na 65 nm
a kaj se tice ploce
svakako asus ...
p5wd2-e?!
xxx
Lignja je offline   Reply With Quote
Staro 04.02.2006., 23:56   #4
Shinichi
Taiketsu Master
Shinichi's Avatar
Lokacija: Suzuka, Japan
Postovi: 150
Slobodno razmisli i o ploči Abit AW8. Čipset hlađen heatpipe-om. Sve tiho i stabilno. Ima i puno opcija za oc.
Shinichi je offline   Reply With Quote
Staro 05.02.2006., 03:20   #5
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Mislim da tu plocu ima LorD ClockaN, pitaj njega kak radi ta ploca...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
