Datum registracije: Oct 2011
Lokacija: svemir
Postovi: 8
Arcadyan VRV9518BA
Dali je netko na doticnom uređaju kod ht-a uspio tagirati vlan, najme zelio bih bez dodatne kupovine nekog rutera wifi-jem poslati maxtv na extender iz kojeg ide lan kabel u maxtv. Ako se ne tagira promet, to ne radi. Posto sam jos na starom firmwareu imam pristup ovome dole, a ako netko zna kako bi uspio osposobiti vlan i onda tagati promet neka javi. Code:
//FEATURE LIST var operation_func=8; var vlan_func_enable=0; var custom_page_flag=2; var my_usb=1; //MENU LIST var MENU_LVL=0; var MENU_TITL=1; var MENU_NAME=2; var MENU_URL=3; var MENU_REALM=4; var MENU_EN=5; var MENU_GRP=6; var MENU_ELM=7; var MENU_USER = 5; var MENU_SUPER = 7; var realm = MENU_USER; var dftWanPageFile = menu_physical_config ? 'arc_physical_config.php' : 'wan_config_pppoe.php'; var MenuList=[ //Gateway [ '0', '100', 'gateway', 'at_a_glance.php', MENU_USER, true], ['1', '101', 'glace', 'at_a_glance.php', MENU_USER, true], ['1', '102', 'connection', 'connection_status.php', MENU_USER, true], ['2', '103', 'conn_status', 'connection_status.php', MENU_USER, true], ['2', '104', 'conn_cable', 'network_setup.php', MENU_USER, true], ['2', '122', 'conn_xdsl', 'arc_xdsl_statistic.php', MENU_USER, menu_xdsl], ['2', '107', 'conn_moca', 'moca.php', MENU_USER, menu_MoCA], ['1', '109', 'software', 'software.php', MENU_USER, true], ['1', '110', 'hardware', 'hardware.php', MENU_USER, true], ['2', '111', 'hw_system', 'hardware.php', MENU_USER, true], ['2', '112', 'hw_lan', 'lan.php', MENU_USER, true], ['2', '113', 'hw_wifi', 'wifi.php', MENU_USER, true], ['1', '124', 'smarthome', 'smarthome.php', MENU_USER, true], //Wizard ['0', '800', 'wizard', 'wizard_step2.php', MENU_USER, menu_wizard], ['1', '114', 'wizard', 'wizard_step2.php', MENU_USER, menu_wizard], //Network ['0', '801', 'wan', 'arc_wan_config.php', MENU_USER, true], ['1', '802', 'wan_sub', dftWanPageFile, MENU_USER, true], ['2', '120', 'conn_physical', 'arc_physical_config.php', MENU_USER, menu_physical_config], ['2', '123', 'wan_pppoe', 'wan_config_pppoe.php', MENU_USER, true], ['1', '112', 'lan', 'local_ip_configuration.php', MENU_USER, true], ['2', '105', 'conn_local', 'local_ip_configuration.php', MENU_USER, menu_local_ip_config], ['2', '202', 'static_dhcp', 'arc_static_dhcp.php', MENU_USER, menu_static_dhcp], ['1', '113', 'conn_wifi', 'wireless_network_configuration.php', MENU_USER, true], //Connected device ['0', '200', 'connected_device', 'connected_devices_computers.php', MENU_USER, true], ['1', '201', 'connected_device', 'connected_devices_computers.php', MENU_USER, true], //Parental control [ '0', '300', 'parent_ctrl', 'internet_pause.php', MENU_USER, true], ['1', '305', 'internet_pause', 'internet_pause.php', MENU_USER, true], ['1', '301', 'ctrl_site', 'managed_sites.php', MENU_USER, menu_parental_control], ['1', '302', 'ctrl_service', 'managed_services.php', MENU_USER, menu_parental_control], ['1', '303', 'ctrl_device', 'managed_devices.php', MENU_USER, menu_parental_control], ['1', '304', 'ctrl_report', 'parental_reports.php', MENU_USER, menu_parental_control], //Security [ '0', '804', 'securrity', 'firewall_settings_ipv4.php', MENU_USER, menu_firewall], ['1', 'ip4', 'firewall_ip4', 'firewall_settings_ipv4.php', MENU_USER, menu_firewall], ['1', 'ip6', 'firewall_ip6', 'firewall_settings_ipv6.php', MENU_USER, menu_firewall], //VoIP [ '0', '900', 'voip', 'arc_tel_sip.php', MENU_USER, menu_voip], ['1', '901', 'voip_line', 'arc_tel_sip.php', MENU_USER, menu_voip], ['1', '902', 'voip_log', 'arc_tel_callLogs.php', MENU_USER, menu_voip], //USB ['0', '700', 'usb', 'dlna_settings.php', MENU_USER, menu_usb_tab], ['1', '701', 'usb_media_share', 'dlna_settings.php', MENU_USER, menu_usb_tab&menu_media_sharing], ['1', '702', 'usb_file_share', 'arc_account_management.php', MENU_USER, menu_usb_tab&menu_file_sharing], ['2', '703', 'usb_file_acnt', 'arc_account_management.php', MENU_USER, menu_usb_tab&menu_file_sharing], ['2', '704', 'usb_file_samba', 'samba_server_config.php', MENU_USER, menu_usb_tab&menu_file_sharing], ['2', '705', 'usb_file_ftp', 'ftp_server_config.php', MENU_USER, menu_usb_tab&menu_file_sharing], ['1', '706', 'usb_print_server', 'arc_print_server.php', MENU_USER, menu_usb_tab&menu_print_server], ['1', '707', 'usb_dongle', 'arc_usb_dongle.php', MENU_USER, menu_usb_tab&menu_usb_dongle], //Advanced ['0', '400', 'advanced', 'port_forwarding.php', MENU_USER, menu_advanced_tab], ['1', '422', 'nat', 'port_forwarding.php', MENU_USER, (menu_advanced_tab&menu_port_forwarding)|(menu_advanced_tab&menu_port_triggering)|(menu_advanced_tab&menu_dmz) |(menu_advanced_tab&menu_nat_passthrough)], ['2', '401', 'adv_port_forward', 'port_forwarding.php', MENU_USER, menu_advanced_tab&menu_port_forwarding], ['2', '402', 'adv_port_triiger', 'port_triggering.php', MENU_USER, menu_advanced_tab&menu_port_triggering], ['2', '404', 'adv_dmz', 'dmz.php', MENU_USER, menu_advanced_tab&menu_dmz], ['1', '403', 'adv_remote_mang', 'remote_management.php', MENU_USER, menu_advanced_tab&menu_remote_management], ['1', '415', 'adv_ddns', 'dynamic_dns.php', MENU_USER, menu_advanced_tab&menu_dynamic_dns], ['1', '405', 'adv_dev_discovery', 'device_discovery.php', MENU_USER, menu_advanced_tab], ['1', '407', 'adv_alg', 'arc_alg.php', MENU_USER, menu_advanced_tab&menu_alg], ['1', '427', 'adv_tr69', 'arc_tr69.php', MENU_USER, menu_advanced_tab&menu_tr69], ['1', '428', 'adv_led', 'arc_led.php', MENU_USER, true], //MTA ['0', '600', 'mta', 'arc_mta_status.php', MENU_SUPER, menu_eMTA], ['1', '103', 'mta_overview', 'arc_mta_status.php', MENU_SUPER, menu_eMTA], ['1', '602', 'line_diag', 'mta_Line_Diagnostics.php', MENU_SUPER, menu_eMTA], ['1', '603', 'sip_log', 'mta_sip_packet_log.php', MENU_SUPER, menu_eMTA], ['1', '604', 'call_qos', 'qos.php', MENU_SUPER, menu_eMTA], ['1', '606', 'vqm', 'voice_quality_metrics.php', MENU_SUPER, menu_eMTA], //troubleshooting ['0', '500', 'troubleshooting', 'troubleshooting_logs.php', MENU_USER, true], ['1', '501', 'ts_log', 'troubleshooting_logs.php', MENU_USER, true], ['1', '502', 'ts_diag_tool', 'network_diagnostic_tools.php', MENU_USER, menu_diag_tool], ['1', '503', 'ts_wifi_spectrum', 'wifi_spectrum_analyzer.php', MENU_USER, menu_wifi_spec_analyzer], ['1', '505', 'ts_reset_restore', 'restore_reboot.php', MENU_USER, true], ['1', '506', 'ts_password', 'password_change.php', MENU_USER, menu_password_change], null ]; /*OPT#PROJ_UI_MULTI_USER*/ //for realm=MENU_USER, we need to tranlate the html file name from xxx.htm to xxx_user.htm //sometimes, the menu title need change too. If empty, it's not necessary to change. var divided_html_for_user={ "wizard_step2.php": {"t":"114", "r":"wizard_step1.php"} }; /*END_OPT*/ |
lar~
Postovi: 1,557
Zasto mislis da bi radilo ako tagiras promet? Nisam siguran da je ti je to moguce uopce izvesti s opremom koju imas. |
Lokacija: svemir
Postovi: 8
kakvu ti predlažeš |
