Staro 18.06.2024., 21:01   #1
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,115
Exclamation ARM Laptopi - info, vijesti, modeli, novosti
Danas su izašle recenzije novih laptopa sa Snapdragon Elite X procesorima, na ARM arhitekturi.
Neke od recenzija modela baziranih na Elite X
<iframe width="560" height="315" src="https://www.youtube.com/embed/rSx0WZfDbE0?si=c5qxXorV9GPUH75D" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube-nocookie.com/embed/uyHs5-XYh6s?si=7HLg23kopNtBnhvA&amp;controls=0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Uglavnom - jako dobre performanse, u rangu sa high-end AMD i Intel procevima, ali s puno duljom baterijom, manjim grijanjem i potrošnjom, i nikad boljom podrškom za ARM software.
Isto tak, performanse su i dalje izvrsne čak i na bateriji.
Isto tak, sleep napokon funkcionira kak bi trebal, nekaj kaj Intel nikad nije uspel srediti
Za sad se čini too good to be true. Kod nas se more kupiti Asusov Vivbook S15+ ali vjerojatno bu i drugih modela.
Jel netko preorderal neki model s tim procem? Jel mislite uzet u obzir za sljedeći lap?
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 18.06.2024. u 21:08.
Staro 18.06.2024., 22:18   #2
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,830
Napokon. Intel bye bye.
Kolko citam, to je rang eplovog m3, napokon potonji dobiva konkurenciju.
https://www.nabava.net/prijenosna-ra...reno-571435841
1600€
Staro 18.06.2024., 22:31   #3
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,346
Autor zvonac Pregled postova
1600€
Polako decki...Hardware je samo jedan dio ukupne jednadzbe. Windows se dosad nije proslavio na ARM platformi a osobno sa Linuxom na ARM platformi nemam iskustva tak da nebrem komentirat. Uglavnom - pametni ce pocekat malo da se speglaju neke stvari...iako me jako svrbe prsti
Staro 18.06.2024., 22:34   #4
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,115
Tak jasno, pričekal bum i ja barem godinu-dvije, dok se ne dokaže da je software na mjestu + do tad bude i X Elite 2 izašel, nakon kaj isprave 1st gen dječje bolesti
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 18.06.2024., 22:47   #5
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,143
Mislim da do sljedeće verzije Windowsa nije realno očekivati nikakvu ozbiljniju podršku za ARM.
1500 eura sad dati za komad hardvera kojem se još širi popis kompatibilnog softvera je ipak malo suludo.
Imate ovdje popis, pa ako se to uklapa u ono što radite...navalite
https://armrepo.ver.lt
Nitko sretniji od mene za par godina kad ARM preuzme štafetu od Intela/AMD-a. S Appleovim M1 imam dobra iskustva nakon početnih mušica, tako da kad se pojavi nekakva mala i lagana alternativa Macbook Airu, zasvrbit će me prsti. Pratim kako Surface napreduje već dosta dugo, ali ne bih ništa imao protiv nekakvog budget rješenja od Acera recimo.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 18.06.2024., 23:29   #6
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,115
I ovo je dobar popis igri koji delaju na ARM-u:
https://www.worksonwoa.com/
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 18.06.2024., 23:50   #7
Postovi: 8,546
IMHO nije to još tak bajno kakvim se predstavlja, mada je itekak bolje od onoga kaj je dosad bilo dostupno za Windows + ARM kombinaciju. Nažalost, Microsoft je po dobrom starom običaju sjebal samog sebe, pa se Recall spyware moral izbaciti iz Windows 11 24H2 verzije, a laptop OEM društvo je u relativno kratkom roku moralo svoje planove presložiti i danas nemamo mnoštvo Snapdragon X recenzija već nekolicinu najčešće jedno-te-istog modela laptopa. Intel i AMD imaju spreman (na Computexu predstavljen) novi hardver koji stiže sljedeći mjesec i u stanju je upogoniti sve kaj Copilot+ nudi, ali ništa od toga ne bude dostupno u službenim recenzijama, jer trenutno samo ARM verzije imaju Windows 11 24H2 izdanje.
With less consumption, performance drops significantly, but efficiency increases. However, it is still difficult to make concrete statements compared to AMD, Apple and Intel at the moment, because the isolated power consumption of the Qualcomm SoC cannot be determined. In terms of GPU performance, the synthetic tests already show that Qualcomm still has to catch up with AMD and Intel – the games confirm this. As recently seen with Intel and AMD, the consumption is low compared to the CPU full load, but even here a final verdict on efficiency is still missing.
The wider 24H2 update rollout will also likely enable the Copilot+ PC features on Intel and AMD PCs that meet the hardware requirements. That hardware will supposedly be available starting in July, but neither Intel nor AMD seems to know exactly when the Copilot+ features will be enabled in software. Right now, the x86 version of Windows doesn’t even have hidden Copilot+ features that can be enabled with the right settings; they only seem to be included at all in the Arm version of the update.
Staro 19.06.2024., 07:18   #8
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,346
Yep
Snapdragon X Elite's first real-world benchmarks can't even beat an older iPhone, but a fix may be out soon
Pogotovo sad u pocetku treba sve uzet sa zrnom soli - hype i zelje su jedno - realna primjena i prakticni testovi su nekaj drugo.
Qualcomm is cheating on the Snapdragon X Plus/Elite benchmarks given to OEMs and the press.
Za mene osobno ne mora biti u rangu High-End cipova. Da je u rangu ovog sto sad imam i da mi drzi baterija 10-12 sati uz tih rad i da se ne przi mi na nogama ko 3 lapa u potpisu - kupujem odmah.
P.S.- Linux ima jedan mali benfit na temelju Bug-a :P
Uglavnom - treba pocekat da se sve to jos malo spegla.
Staro 19.06.2024., 11:57   #9
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
ARM nije izlazio u desktop varijanti jer nije bilo pravog desktop OSa a desktop OSa za ARM nije bilo jer nije bilo desktop CPUova na ARM arhitekturi.
Još i to što su ARMovi bili (pre)spori za desktop. Moj stari FX-8350 softwareski dekodira 4K video. ARM iz tog doba se prestrašno vuče. Čak ni RPi5 koji je 11god mlađi ne može 4K koliko vidim bez HW dekodera.
Staro 19.06.2024., 14:27   #10
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,800
Ne znam zasto uopce gledate Windowse na tome (unatoc cinjenici da RT i kasniji derivati postoje vec preko 10 godina).
Ovdje sam pisao o vrlo operativnom i ucinkovitom ARM desktop i laptop setupu kojeg imam; Chromebook mi je prakticki dnevna prijenosna masina, dok se na desktopu vrti sve od 4k videa do developmenta cemu primarno i sluzi. Na oba sustava su Debian derivati (desktop je Ubuntu a Chromebook je neki njihov Debian based fork) i to vec ~godinu dana radi ko sisa. Istini za volju, ARM desktop je zahtijevao malo vjestine (nije bas PnP, vise ima onaj PC vibe '80. i '90., hehe), ali realno, cijela masina je malo frankenstajnasta, no radi vrlo dobro i solidno, eto ga vec... mjesec ipo dana bez da trepne!
Navodno se i Lenovo nesto kurcobecio da ce izbaciti neku, IIRC, X seriju na ARM-u, gdje ce vjerujem biti sluzbenog Linux supporta, sto ako se malo s njihove strane poslozi kako spada, moze poceti raditi presing na Appleovu M seriju, jer vjerujem da mogu biti itekako konkurentni s cijenom, a postoji dobar dio developera koji trose takve masine upravo za to - a dramaticno lakse bi bilo uklopiti ostatak hardverskog ekosustava s nekim Lenovom, HP-om i slicno nego s Appleom, koji se tradicionalno onda nalazi u nekom heterogenom ekosustavu.
Iskreno, Chromebook mi je bio otkrice, jer sam za ~300 dolara dobio respektabilan stroj kojemu je jedina mana to sto ima nekakav kilavi eMMC ili kako se vec zove ta predpotopna spora DASD kurcina, jer da to malo cudo ima kakav suvisli SSD (a kamo li NVMe) i da postoje opcije s 16GB RAM-a... hijao!
Programer
Staro 08.07.2024., 21:55   #11
Postovi: 8,546
Š.O.K._i_V.J.E.V.E.R.I.C.A. - većina Qualcomm Snapdragon X + Windows ARM recenzija je ispala plaćena reklama.
Staro 08.07.2024., 22:15   #12
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,346
Yea..that sucks...samo neznam sto vise koci razvoj x86 alternativa - Redmond ili Qualcomm. Apple je pokazao da je alternativa x86 moguca i to u mnogocemu superiorna. No u Apple slucaju barem - preskupa (200 Eura za 8GB vise meme u 2024...400 Eura doplate za 1TB SSD..aj molim te)....Al iskreno - da je ARM kompetitivan barem sa midrange uredajima (cijenom i performansama) i po potrosnji parira onome sto mozemo vijeti u Apple taboru - to bi vec bio dobar pocetak.
Staro 08.07.2024., 22:20   #13
Postovi: 8,546
Jebiga, hardver nije loš, ali bome nije ni tak super kakvim su ga htjeli prikazati, posebice ne za nofce koje traže kad realno imaju malo bolji Chromebook kakav Bubba spominje, tak da je IMHO 500€ do 750€ sasvim vredu za Snapdragon X uređaje, ali oni su krenuli s ciframa koje nemaju veze s vezom. I onda još Microsoft na to stavi točku na i sa svojim poluproizvodom od OS-a, dok standardni plaćenici poput Linusa nastoje s kreveljenjem pred kamerom skrenuti pažnju s konkretnih recenzija.
Staro 09.07.2024., 12:35   #14
medo
medo's Avatar
Postovi: 3,733
Pa ako Jabuka može što ne bi i oni mogli nabiti cijene.
Ili ne…?
Staro 09.07.2024., 14:32   #15
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,800
Mozda si mislio na x86 *desktop* alternative.
Tu je najveci problem sto ne postoji standardni boot proces na ARM platformi, pa je samim time potrebno puno vise vremena za prilagoditi pojedinacni OS svakoj specificnoj platformi.
To je vrlo vjerojatno jedan od razloga zasto za ove laptope, osim ako nije sluzbeno podrzano, jos uvijek nema Linux distribucija.
Da, ali Apple ima zatvoreni ekosustav i onda (njima) nije tesko raditi u njemu i podrzavati ga.
Moja sreca&odusevljenje su se temeljili na tome da je bio (kao sto cesto je) na vrlo solidnom popustu u BestBuyu, ali iskreno, taj popust mu je realna cijena...
Tog lika "prati" par desetaka milijuna ljudi i ima visemiljunske preglede svojih video uradaka. I onda me studentice rodne ideologije napadaju kada kazem da je IBM unistio covjecanstvo dozvolivsi medianu retardacije sirok pristup racunalima.
Programer
Staro 11.04.2025., 10:13   #16
zvonac
zvonac's Avatar
Postovi: 5,830
Da nabacim jedan osvrt na laptop sa ARM (Elite) čipom. Nabavio MS SL7 15" 16/512, laptop dolazi s instaliranim win 11 home..
Ono što mogu reć, ovo je macbook air sa winsima, u smislu završne obrade, izrade i korištenih materijala, touchpad je tu negdje sa air-om po pitanju korištenja, znači, skoro pa fenomenalno..
Bateriju sam punio prije nepuna dva dana, i sad je na 68%, inače moje uobičajeno korištenje je, libre office, yt-4k, surfanje, vlc-video materijal. jučer i prekjučer pobrao neka ažuriranja pa sam tu "izgubio" 4-5min. na svaki update.
SL7 u deep sleepu, znači tokom noći, potroši 1% baterije, a danas ujutro dok sam ga upalio % je ostao isti kao i sinoć oko 23.30h, a batka je bila na 70%..
Što se tiče programa, manje više sve radi, bar one koje ja koristim.
SL7 jedva da se grije, u najgorem slučaju mlak je, a ventove jedva da čujem, kod updejta pojača ventove i proc onda skače gore..
Al ono kaj ogu reć, tipkovnica je odlična a touchpad pravi preporod..
Da se razumijemo, ovo nije radna stanica gdje će te vi pokretat teške zadatke, mislim da je naglasak stavljen na autonomiju baterije, a koja mi se čini ovak na prvu odlična; prekjučer je bilo prvo punjenje, mislim da je bilo oko 12.30h kad je baterija bila na 99% onda sam ga skinuo sa punjača, sad je na 68% uz čačkanje, podešavanje, instalacija programa, updejtanje, restartanje itd.
Inače imam naviku koristit miš na laptopu, al ovo je sad prvi put da mi ne treba, za sad
Dal winsi rade fluidno? Pa teško je reć, pošto mi je na bivšoj desk pili (13600k-32gb) znalo štekat i postojao je neki povremeni delay-lag; al u pitanju su winsi, pa od njih možemo sve očekivat.
Zamjerka je jedino što nema veći enter i ovaj glossy ekran mi nije baš nekaj, uzeo sam sa LCD ekranom pošto je oštriji spram oleda na kojem tekst izgleda mutnije.
Eto nadam se da će budućnost bit svijetla za ARM i vrijeme je da macbook dobije oštru konkurenciju A mislim da upravo svjedočimo tomu.
Zadnje izmijenjeno od: zvonac. 11.04.2025. u 10:20.
