Staro 17.04.2024., 22:14   #1
Astra
Lokacija: Earth
Postovi: 539
Mikrotik - P2P link
Ovako,imam 2 Mikrotika SXTsq Lite2 i više sam se pogubio u konfiguracijama.
Ovo je konfiguracija za Master:
Code:
# aug/07/2018 21:10:22 by RouterOS 6.42.6
# software id = N5L5-NAV7
# model = RBSXTsq5nD
# serial number = xxxxxxxxx
/interface bridge
add name=BrLocal protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyn disabled=no frequency=5200 \
    mode=bridge nv2-preshared-key=zzzzzzzzz nv2-security=enabled ssid=Link \
    wireless-protocol=nv2
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/interface bridge port
add bridge=BrLocal interface=wlan1
add bridge=BrLocal hw=no interface=ether1
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=BrLocal \
    use-peer-ntp=no
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=LiMaster
/system ntp client
set enabled=yes primary-ntp=161.53.30.170 secondary-ntp=161.53.30.3
/system routerboard settings
set silent-boot=no
/tool bandwidth-server
set authenticate=no
/user set 0 password=Trvi2
a ovo za Slave:
Code:
# aug/07/2018 21:10:36 by RouterOS 6.42.6
# software id = 7D5Q-3J0E
/interface bridge
/interface wireless
    mode=station-bridge nv2-preshared-key=zzzzzzz nv2-security=enabled \
    ssid=Link
/ip hotspot profile
/ip dhcp-client
    use-peer-ntp=no
/system clock
/system identity
set name=LiSlave
/system ntp client
set enabled=yes primary-ntp=161.53.30.170 secondary-ntp=161.53.30.50
set silent-boot=no
Di griješim? Ima li netko možda gotovu konfiguraciju pa da mi prosljedi? Hvala.
Zadnje izmijenjeno od: Nikky. 17.04.2024. u 22:47.
Astra je offline   Reply With Quote
Staro 17.04.2024., 22:42   #2
Postovi: 23,622
Imaš primjera po netu, npr:
https://wiki.mikrotik.com/wiki/Bridg...works_with_SXT
https://www.youtube.com/watch?v=DQO9nHXEYhI
https://scoop.co.za/blog/how-to-crea...tp-bridge-link
možda igra i ovaj (za drugi tip uređaja) > https://help.mikrotik.com/docs/displ...tP+GUI+example
Svakako kreni iz početka, obavezno bez default konfiga pa onda slijedi upute.
Staro 17.04.2024., 23:14   #3
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,555
jesi probao ovo uopće podesit ručno ili si samo upucao skriptu unutra?
na ap-u ti fale postavke na wifi (širina kanala, regulatory domain za početak, nakon toga ti fale nv2 postavke).
na clientu ti fali to isto plus ti fali sken lista i opet regulatory domain. na klijentu ne upisuješ frekvenciju jer to ničemu ne služi, već upisuješ sken listu.
skini si winbox i poklikaj to ručno.
PS NEMAŠ lite2 nego imaš lite5.
Staro 17.04.2024., 23:30   #4
dadoremix
dadoremix's Avatar
Postovi: 4,749
jedan je ap bridge, drugi bridge na wifi
šta če ti za to postavke, skripte
par klikova
jednog stavis da je ap takoreč, drugi client i vozi
Staro 18.04.2024., 09:27   #5
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,936
- Prvi uređaj staviš kao bridge
- Pod security profile postaviš postavke (šifru, itd...)
- Izabereš frekvenciju, širinu kanala, daš ime SSID-u, postaviš wireless protocol, postaviš security profile koji si napravio.
-Drugi uređaj staviš kao station bridge
- Pod security profile postaviš iste postavke kao na prvom uređaju postavke (šifru, itd...)
- Izabereš istu frekvenciju, istu širinu kanala, isti SSID, isti wireless protocol kao na prvom, postaviš security profile koji si napravio a koji je identičan prvom.
I to je to.
Matta je offline   Reply With Quote
Staro 18.04.2024., 21:05   #6
Astra
Lokacija: Earth
Postovi: 539
Ok uspio sam to,ponekad je bolje manje tog podešavati. Oni su se povezali. Međutim,nešto sam profulao jer na ovom drugom koji je u station bridgeu nemam internet konekcije,a ovog u bridgeu sam spojio u ruter.
Staro 18.04.2024., 21:35   #7
dadoremix
dadoremix's Avatar
Postovi: 4,749
daj se javi na pp
remote rješimo
