19.01.2006., 14:34 | #1 |
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Spybot - Search & Destroy restarta komp
Ajd molim vas nek netko pogleda dali ovdje ima šta sumljivo ? Pri upotrebi Spybot - Search & Destroy računalo mi se zamrzne ili restarta. Probao sam više verzija programa - ista stvar. Nod32 sa max heuristikom ništa, CWShredder ništa, Trojan Remover ništa, procesa imam kao uobičajeno , ništa novo nisam primjetio, PF usage oko 125MB. Obično restarta kad Spybot provjerava boot - kod nekog gatora ? S čime bi još mogao pročešljat ? Logfile of HijackThis v1.98.0 Scan saved at 14:17:04, on 19.1.2006 Platform: Windows XP SP2 (WinNT 5.01.2600) MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180) Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\system32\spoolsv.exe C:\Program Files\Diskeeper Corporation\Diskeeper\DkService.exe C:\Program Files\Eset\nod32krn.exe C:\WINDOWS\system32\nvsvc32.exe C:\WINDOWS\Explorer.EXE C:\Program Files\Siemens\Adsl\dslstat.exe C:\Program Files\Eset\nod32kui.exe C:\Program Files\ASUS\Probe\AsusProb.exe C:\WINDOWS\system32\ctfmon.exe C:\Program Files\Registry Mechanic\RegMech.exe D:\Software\HijackThis\HijackThis.exe F0 - system.ini: Shell= F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe, O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll O4 - HKLM\..\Run: [DSLSTATEXE] C:\Program Files\Siemens\Adsl\dslstat.exe icon O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE O4 - HKLM\..\Run: [DiskeeperSystray] "C:\Program Files\Diskeeper Corporation\Diskeeper\DkIcon.exe" O4 - HKLM\..\Run: [ASUS Probe] C:\Program Files\ASUS\Probe\AsusProb.exe O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup O4 - HKLM\..\Run: [nwiz] nwiz.exe /install O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit O4 - HKLM\..\Run: [RegDoctor] "C:\Program Files\RegDoctor\RegDoctor.exe" -Quick O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe O8 - Extra context menu item: I&zvoz u Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000 O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file) O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file) O9 - Extra button: Istraživanje - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL |
19.01.2006., 19:19 | #2 |
Postovi: 9,067
e tutto a posto. ova dva mozesh maknuti jer su ionako no file: - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file) O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - (no file) po ovome nista problematichno. sto se tice smrzavanja spybota, ne postoji, ili barem ja nisam cuo za nishta odredjeno. mozesh probati sa josh jednom deinstalacijom, ali ovaj put i brisanjem iz registry-a. (za slucaj da nisi)
___________ HTPC: Intel Core2Duo E8500 × ATI Sapphire HD4670 HDMI × 2x 1GB DDR2 × Samsung 160GB × Lenovo Key+Mouse × Philips 49PFS5501 LED TV × Technics SA-EH780 5.1 × Windows 10 Laptop1: Lenovo x100e w/Windows 10 |
19.01.2006., 21:45 | #3 |
Lokacija: Online
Postovi: 2,404
E fala , baš obrisah suvišno... Ma već sam to doživio od Spybota ali reinstalacijom je uvjek bilo riješeno. Sad neće. Čistio sam regisrty sa TuneUp, Registry Mechanic, SpySubtract, RegDoctor kao manijak sam po pitanju takvih alata .... neki drugi program koji bi ga dostojno zamjenio ? |
20.01.2006., 19:32 | #4 |
Postovi: 9,067
ruka. pametno rucno uklanjanje.
