Lokacija: Bjelovar
Postovi: 482
Win10 IRST driveri
Pokusavam instalirati W10 na Acer Travelmate P214 i naravno u setupu kaze da ne vidi disk. Skinem Intel RST drivere, ucitam RST VMD Controller 09AB, ali on i dalje ne vidi M2. Ima tko sto pametno za ovo? |
#2 | |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 306
EDIT: Ili probaj ovo: https://community.acer.com/en/kb/art...0-installation Code:
Select Intel RST VMD Controller 9A08 (TGL), and click Next. Zadnje izmijenjeno od: BinaryJesus. 13.10.2023. u 07:01. |
Lokacija: Val
Postovi: 304
Ili nađi driver (IRST) po serijskom broju (uspio napraviti disk vidljivim nakon pravog drivera, posebno za W10 ili za W11): https://www.acer.com/gb-en/support/p....009/downloads Ili napravi ovo: 1. Run BIOS 2. On "Main" menu press CTRL + S to display hidden "VMD Controller" setting 3. Select "disable" VMD Controller 4. Save changes and exit 5. Run Win10 installer again What is a VMD controller? Intel® VMD is an Intel® Xeon® Scalable processor feature that enables direct control and management of NVMe SSDs from the PCIe bus without additional hardware adaptors. What happens if I disable VMD controller? Disable VMD technology will make your computer can't utilize RAID Array.
"You know, you come from nothing - you're going back to nothing. What have you lost? Nothing!" Zadnje izmijenjeno od: dani77. 13.10.2023. u 09:09. |
#4 | |||
Lokacija: Bjelovar
Postovi: 482
![]() Hvala obojici, možda nekome zatreba ![]() |
