Staro 06.01.2006., 03:48   #1
soda
soda's Avatar
Lokacija: Vukovar
Postovi: 438
DFI Lanparty problem sa zvukom
Evo malo sam se i ja ponovio. Uzeo sam DFI Lanparty Ultra-D, A64300+@2.5 GHz, Gainward 6600 GT...
Sve radi odlicno osim najbitnijeg. ZVUK!
Kako da osposobim digitalni izlaz na ploci!?
Ono, jednostavno nemam zvuka, bilo da probam digitalni output preko ALC850 ili nForce4!
Pomagajte..
Poz.
soda je offline   Reply With Quote
Staro 06.01.2006., 04:15   #2
E.T.
E.T.'s Avatar
Postovi: 2,458
Imas pod Overclocking sticky o DFI plocama pa mozda bi ondje dobio brzi odgovor...
Si potrazio u manualu koji dobijes na cd-u?
Mislis na ovo:
"The system board is equipped with an onboard S/PDIF-in RCA jack
(red) and a S/PDIF-out RCA jack (yellow) at locations CN5 and
CN7 respectively.
The S/PDIF connector at location J3 is used to connect to
optical S/PDIF ports. The S/PDIF ports may be mounted on a cardedge
bracket. Install the card-edge bracket to the system chassis
then connect the audio cable connector to J3. Make sure pin 1 of
the audio cable connector is aligned with pin 1 of J3.
DO NOT use RCA S/PDIF and optical S/PDIF at the same time."
Jel u biosu ovo on:
AC97 Audio
Auto Select this option when using the onboard audio.
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 06.01.2006., 12:19   #3
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,540
Pa da ja sam morao prebaciti taj jumper, iako bi prema manualu trebao raditi u oba polozaja.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 06.01.2006., 16:54   #4
soda
soda's Avatar
Lokacija: Vukovar
Postovi: 438
Znaci, prebacio si jumper na nF4 izlaz i instalirao nVidia drivere sve radi?
Da li si morao instalirati i realtekove drivere?
Poz.
Staro 06.01.2006., 16:59   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Taj jumper određuje koji zvučni chip se koristi na digitalnom izlazu. Znači, postavi ga na npr. Realtek i instaliraj drivere za njega i onda radi. Ili na nvidiu i drivere za nju.
Staro 06.01.2006., 18:40   #6
soda
soda's Avatar
Lokacija: Vukovar
Postovi: 438
I mislio sam tako da radi, ali nece...
Stavio sam na nVidiu, istalirao drivere, ali nista od digitalnog izlaza...
uf...
Taj digitalni output mi je jako bitan. Ne znam vise sto da radim...
Poz.
Staro 06.01.2006., 19:11   #7
soda
soda's Avatar
Lokacija: Vukovar
Postovi: 438
PRORADILO!
Kako, zasto, nemam pojma
Idem malo uzivati u Iced Earthu...
Poz.
Staro 06.01.2006., 21:00   #8
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,540
Poz.
Samo sam nvidia drivere instalirao i onda odes u nv mixer i tamo speaker wizard...
vidim da ti je proradilo ali to je nacin ako ti bude trebalo opet.
MacBook M1 Pro
MacBook Air M2
Moto Edge
