Staro 13.02.2021., 21:23   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
PowerLine: 1 Gbit propušta samo 100 Mbit
Imam problem. Na postojećoj kućnoj mreži (1 Gbit router, 1 Gbit switch, cat6 tvornički terminiran) jedno računalo odbija koristiti više od 100 Mbita. Radi se o integriranom LAN adapteru na ploči Asrock B550m Phantom 4 Gaming. Službeno je 1 Gbit i spaja se kao 1 Gbit, ali kad kopiram fajlove po mreži s tog računala ili na to računalo dobijem max 8 MB/sec. Na istim instalacijama staro računalo sa 1 Gbit ethernet adapterom je bez problema postizalo 100MB/sec. Tako da mislim da mogu isključiti problem instalacija i mreže općenito. Izgleda kao da je adapter na B550m ploči ciljano ograničen na prijenos od 100Mbit/sec. Ima netko ideju zašto?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 24.02.2021. u 11:30. Razlog: Očito sam zaboravio u naslovu napisati ključnu riječ (powerline)
estugarda je offline   Reply With Quote
Staro 13.02.2021., 21:36   #2
Postovi: 8,218
Probaj se poigrat s ovim opcijama
Stavi 1gb full duplex manaulno umjesto auto negotiation.
Staro 13.02.2021., 22:07   #3
Postovi: 23,548
Koja je mrežna ?
Da nije ona 2.5 Gb šta je sad svugda guraju ?
Ako je, pun je internet veselja sa njom, drajveri su joj u tujcu.
Probaj staviti zadnji drajver sa str. proizvođača mrežne (Realtek ako ne njihova).
Staro 14.02.2021., 10:28   #4
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Pupo Pregled postova
Jesam. Nije pomoglo.
Pokušao sam i s drugim postavkama u drajveru. Bez uspjeha.
Autor Nikky Pregled postova
Koja je mrežna ?
Izgleda da je 2.5 Gb, ako se to odnosi na "Supports 1-Lane 2.5Gbps PCI Express Bus". Realtek kaže Realtek RTL8111H, a to vodi na "Realtek PCIe FE / GBE / 2.5G / Gaming Ethernet Family Controller Software".
Stavio sam zadnji driver sa Realtekove stranice, ali ništa nije pomoglo. Mislim da je to zapravo isti driver kao i ovaj na ASRockovim stranicama. Vidim da ekipa mijenja postavke koje sam i ja pokušao mijenjati, i stavlja stare drivere.
Iako, oni imaju problema sa stabilnošću veze. Ja nemam. Veza je skroz stabilna, samo ne prelazi 100Mbita...
Onboard Ethernet mi nikad nije radio probleme, čak ni na najšrotnijim pločama, i sad odjednom na novoj ploči ne funkcionira...a nisam štedio.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 14.02.2021. u 10:37.
Staro 14.02.2021., 11:32   #5
Postovi: 23,548
Ne pomaže tu štedio / ne štedio kad je mrežna za kua ...
Ako ti negdje "naleti" Intel i210 / i211 ili Intel Gigabit CT PCI-E Network Adapter (82574L) ili 82576 based,
uzmeš > ubaciš > staviš drajver i zaboraviš na probleme
Staro 14.02.2021., 11:57   #6
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Hm. A o čemu se onda ovdje radi? Ne valja hardware ili driveri? Ili oboje? Nema fix?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 14.02.2021., 12:35   #7
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Driveri za mrežnu ili neki drugi softver ti usporava mrežu, imaš li neki dodatni antivirus instaliran?
Staro 14.02.2021., 12:46   #8
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Neki antivirusi, npr Kaspersky, se znaju nakačit na mrežni driver i raditi probleme
https://support.kaspersky.com/common/settings/3474
Staro 14.02.2021., 12:50   #9
Postovi: 23,548
Ne znam precizno jeli hw ili sw ali znam da svuda guraju taj novi chip i da gomila ljudi ima problema i na win i na linux - u.
Evo ti pomalo overkill rješenje u kolege HP NC360T > http://forum.pcekspert.com/showthrea...light=mre%9Ena
to je server dual port mrežna bazirana na Intel 82571EB chipsetu, PCI-E x4,
po "imenu" to je Intel PRO/1000 PT Dual Port Server Adapter,
specs > https://h20195.www2.hpe.com/v2/GetPD.../c04163767.pdf
za "obične" winse malo pametuju sa drajverom, treba ti HP SP52449.exe paket ili skini sa Intel supporta paket za mrežne > https://downloadcenter.intel.com/pro...Server-Adapter
Zadnje izmijenjeno od: Nikky. 14.02.2021. u 13:12. Razlog: Nadopuna
Staro 14.02.2021., 12:53   #10
Matebaron
Matebaron's Avatar
Lokacija: Supetar
Postovi: 328
Imao sam sličan slučaj prošle godine i na kraju je ipak bilo do kabla.
I have spoken.
Matebaron je offline   Reply With Quote
Staro 14.02.2021., 13:33   #11
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Mislim da ipak nije driver. Ni stari komp više ne radi na 1Gbit. A nije ni kabel, jer sam upravo probao s novim cat6.
Mislim da zeza ili neki switch, ili powerline.
Switcheve sam resetirao. Naizgled su svi ok. Ali mislim da bi mogao biti powerline. Signal je maksimalan, ali sve do powerline radi na gigabit, a sve dalje više ne radi. Powerline je gigabit. I prije je radio na gigabit 100% po cijeloj instalaciji. E sad, što bi moglo biti? Ništa na struji nisam dirao. Možda hladnoća?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 14.02.2021. u 13:45.
Staro 14.02.2021., 13:45   #12
Postovi: 23,548
Na switch - evima svaki link detektiran kao GB (kod nekih se vidi po Led - icama) ?
Koji su switch - evi i koliko su u pogonu ?
Za PowerLine ištekat > uštekat, ako je TP-Link onda se u njihovom sw vidi brzina linka između ...
Staro 14.02.2021., 15:20   #13
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ovako. Imam 2 switcha. Oba TP-Link TL-SG105. Ledice sve blinkaju na isti način. Trepere brzo. Mislim da tu nema razlike, jer su mi na prvom switchu u radnoj sobi kompovi i NAS i tu 1Gb radi dobro i ledice izgledaju isto kao na switchu u kući gdje očito radi samo 100Mbita.
Powerline TP-link TL-PA7010P KIT V2 spaja radnu sobu i kuću koje su u različitim zgradama. Strujni kabel između zgrade gdje mi je radna soba i kuće ide po zraku. Udaljenost je nekih 12-15 m. Znam da to nije dobro, ali do sada je funkcioniralo bez greške skoro 2 godine. I powerline i switch su kupljeni u 5. mj. 2019. i otad rade. Problem sam primjetio jučer kad sam skužio da mi 4k video reprodukcija sa NASa slabo radi u kući, i onda sam naknadno shvatio da mi je transfer fajlova 5-8 MB/s. Ne mogu točno reći otkad, ali znam da je prije bilo puno brže.
Isključio sam i uključio oba PowerLine adaptera. Nije pomoglo. Isto sam napravio sa switchevima. Ni to nije pomoglo. Firmware na powerlineu je zadnji. Ništa se tu nije dogodilo od 2018.
E da; deklarirana brzina PowerLine-a u TP-link sučelju varira od 160-240Mbps. Mjeri li to maksimalnu brzinu ili trenutnu? (edit: kaže u sučelju; transmission capacity)
PS Ono što je ovih dana bitno drugačije je da je jako zima ovdje. -12C je bilo ujutro. Postoji li mogućnost da niske temperature utječu na powerline zbog strujnog kabela koji ide zrakom?
Ako nije to, što bi moglo biti?
EDIT: Na struji nisam radio ništa novo, ali sam se sad sjetio da mi je Elektra samoinicijativno prije nekoliko tjedana zamijenila brojilo. Stavili su nekakvo digitalno čudo. Nisam siguran je li do promjene u brzini došlo tada, ili ne.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 14.02.2021. u 16:28.
Staro 14.02.2021., 19:21   #14
riceburner
SCSI Freak, deda :P
riceburner's Avatar
Lokacija: ZEGEIZABREGE
Postovi: 871
Talking
specs >
hvala @Nikky
ako nekom treba imam i 2kom genuine INTEL ponasaju se identicno kao i ovaj NC360T, nema razlike u radu, sa dobrim switchem papaju malu decu
use SCSI/SAS and live longer!
Staro 14.02.2021., 20:06   #15
James Dean
Datum registracije: Dec 2020
Postovi: 361
Ja sam imao sličan problem ali sa 10/100 brzinom neta i bilo je do routera (bnet modem/router) koji nije htio switchat na 100 mbitnu mrežu. Kad sam zatražio zamjenu za novi router radilo je na punih 100 mbita do tada nije htijelo više od 50. Isto izmjenjao sam kablove sve živo na kraju je bio problem u routeru. Probaj mrežnu ručno podesit na gigabitnu mrežu
Staro 14.02.2021., 21:22   #16
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Ma ne. Isti je router. Imam problem sa Powerlineom. Samo mi nije jasno kakav i zašto.
Sent from my SM-N950F using Tapatalk
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 14.02.2021., 21:22   #17
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Aj skini iperf i napravi test između 2 kompa na mreži prije powerlinea i onda server prije a klijent poslije powerlinea pa stavi rezultate.
žmnpp
Staro 14.02.2021., 22:32   #18
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Hoću, ali što ću s tim dobiti? Evidentno je već sad da je Powerline usko grlo.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 14.02.2021., 22:41   #19
dadoremix
dadoremix's Avatar
Postovi: 4,720
Ja jos nisam vidio powerlinea koji gura čistih 1gbit
Al sam se nagledao ovih sto im sve smeta
Sve sto mu sa strane uštekaš pa do led rasvjete u kupaoni
Staro 14.02.2021., 22:56   #20
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Autor estugarda Pregled postova
Uz pomoc njega ces sistemom eliminacije potrosaca mozda dobit uvid sto zeza.
Ili sve redom istekat pa ustekavat ili obrnuto.
Ocito nesto smeta ak je prije radilo ok.
žmnpp
Staro 15.02.2021., 10:15   #21
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Tebi je definitivno fokus na vezi izmedju kompa i powerline, ovo sve dalje ne diraj trenutno.
Svi switchevi i sve ostalo dalje uopce nema veze ako ti je veza od pc do prvog powerline 100 mbit. Tu kreni...
Za pocekak donesi switch do kompa i spoji pa vidi jel radi 1000... Zamjeni kabel od kompa do powerline...
Staro 15.02.2021., 12:05   #22
Postovi: 23,548
Evo napomena / objašnjenje Led - ica na switch - u (TL-SG105/TL-SG105S/TL-SG108/TL-SG108S),
detekcija 100 Mbps ili 1000 Mbps:
Staro 16.02.2021., 09:58   #23
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor zwer54 Pregled postova
Isključeno je sve osim powerline-a. Problem je u powerline-u 100%. Odnosno u instalacijama struje u uredu (bivša garaža) i/ili u novom brojilu. Iako je to u garaži sve prastaro, sve je na jednom osiguraču, i staro 50 godina, izgleda da je radilo dobro dok elektra nije postavila novo brojilo. Nešto su tu puno komplicirali, nije radilo, pa je radilo. Par tjedana nakon toga je došao očitat stanje iz Elektre drugi lik i buljio u to brojilo ko tele u šarena vrata i nije ga znao ni očitat. Kaže neko industrijsko, koje je očito negdje bilo višak ili je servisirano, pa su ga meni uvalili. Najgore je što treba jebeni manual da se s njega očita potrošnja. I to sam mu ja našao na netu, pa smo nekako zajedno prokužili kak se s tim barata.
Na žalost, nemam tu nekih prevelikih mogućnosti i vjerojatno ću morati ići na drugo rješenje. Razmišljao sam potegnuti LAN žicu za eksterijer zrakom sa zaštitom s obje strane. Mislim da je to naracionalnije u ovom trenutku. Nemam trenutno ni resurse ni vremena pretumbavati opet instalacije struje, a voditi u zemlji nema smisla jer bi morao 2 asfaltirane površine potrgat.
Moji su ovi koji rotiraju samo zeleno, ali rade na 1Gbit provjerno. Rotirao sam switcheve. Probao s drugim kablovima. Switchevi i kablovi rade na 1Gbit. Odnosno nešto manje, ali to je to. Ako dobijem 100MB/s prijenosa (ilitiga 800Mbita), ja zadovoljan. Ma i 50MB/s mi je dovoljno, ali 8 nije.
Autor buljo Pregled postova
Probao sam malo ištekavati i uštekavati stvari koje sam mogao. U kući (nove instalacije i brojilo) nije bilo nikakve razlike, a ni u radnoj sobi, ali zato je brzina dosta varirala u donosu gdje je uštekan powerline u radnoj sobi. Na nekim mjestima je bilo 100Mbita, na nekim 300Mbita, tako da su te instalacije u radnoj sobi vjerojatno problematične, a iz nekog razloga se situacija pogoršala s novim brojilom.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: Nikky. 16.02.2021. u 10:40.
Staro 16.02.2021., 11:02   #24
Postovi: 23,548
Pada mi na pamet (mogućnost) da je baš u tom "novom" brojilu riječ,
moguće je da ima daljinsko očitanje i sad se te dvije komunikacije kolju.
Nasmijala me ova situacija sa bulji ko tele u šarena vrata i nije ga znao ni očitat ... treba jebeni manual da se s njega očita potrošnja. I to sam mu ja našao na netu, pa smo nekako zajedno prokužili kak se s tim barata. ...
Imaju valjda 5 - 6 tipova tih elektronskih brojila pa ti zapamti proceduru za svakoga,
neštto sitno sam bio gledao (ne sjećam se koji tip) i to je stvarno svinjarija kako su napravili + ti treba mikroskop i manual.
Za sada stavi PowerLine tamo gdje dobiješ najbrži link (pisao si 300 Mbita.
a planiraj razvući štrik (pardon) Cat6 Lan kabel i mirna bosna,
obrati pažnju da vanjski širm spojiš na uzemljenje samo na jednoj strani (riješiš to pri blankiranju i postavljanja konektora).
Ako i staviš zaštite na oba kraja (one se i spajaju na uzemljenje) ne zaboravi naponu iz prethodne rečenice.
That's it
Staro 16.02.2021., 13:20   #25
Prezime
Datum registracije: Aug 2013
Postovi: 4,337
Hehe, imam i ja jedno takvo brojilo, pa sam na njega zaljepio salabahter sa postupkom ocitanja obje tarife, da ga moze ocitat svako s imalo soli u glavi
Staro 24.02.2021., 11:23   #26
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Danas mi opet HEP samoincijativno zamijenio brojilo. Ne znam otkud im takve blesave ideje da usred pandemije uletavaju u kuće (naravno bez maski) i to bez razloga. I ne jednom.
Ovaj put "novo" broijilo ima daljinsko očitanje. Ono prošlo je izgledalo puno kompliciranije, ali očito nije imalo. Zapravo ovo što su sad stavili izgleda vrlo neuvjerljivo meni laiku. I da stvar bude zanimljivija, sad mi je još slabiji Powerline. Dakle počeo sam sa 500-800 u vrijeme prastarog analognog brojila, pa nakon prve zamjene brojila na digitalno bilo je 160-240, a sad nakon treće je 100-160 Mbps. Downgrade-ao me HEP 2x u mjesec dana. Instalateri koji su bili tvrde da brojilo s tim nema nikakve veze, i prave se mutavi. Pošto sam im rekao za to, kao provjerili su sve, i sve je OK s instalacijama.
I dalje idem s LAN-om, samo što sam ga ipak odlučio zakopati, ali činilo mi se bitno napisati, ako se netko nađe u sličnoj zavrzlami.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 24.02.2021. u 11:33.
Staro 24.02.2021., 13:24   #27
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,511
digitalna brojila, navodno, propuštaju plc u oba smjera. shodno tome, i smetnje iz "vanjske" mreže tebi ulaze u kućnu mrežu, dok tvoj powerline "ide van" iz kuće.
za samoočitanje, iako nsiam toliko upućen, se koristi frekvencija do 500khz pa to ne može utjecati na brzinu powerline-a, već po meni samo smetnje izvana su glavni uzrok manje brzine.
