Staro 05.08.2020., 23:01   #1
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ethereum (ETH) mining RX5500XT/ 5600XT / 5700 / 5700XT
Bilo mi malo dosadno, pa eto da i to probamo
Prva na test je pala
Asrock Challenger RX 5500 XT 8GB
* Trenutna cijena navedene je oko 1800 kn
* Najjeftinija trenutno RX 5500 XT 8GB je Powercolor 1580 kn
SimpleMining OS + phoenixminer-v5.1b
Code:
Core MHz: _______
Memory MHz: _______
Core undervolt: _______
Memory UV (MVDD): _______
Aggressive undervolt: OFF
Powerstage: 5
Target Temperature ℃: 80
Minimum Fan speed %: 65
Eth: New job #1e42ef0f from ssl://eu1.ethermine.org:5555; diff: 4000MH
Eth speed: 25.407 MH/s, shares: 1/0/0, time: 0:01
OVERCLOCK (najbolje što sam uspio dobiti uz najmanju potrošnju):
Code:
Core MHz: 1000
Memory MHz: 950 (nema učinka preko toga)
Core undervolt: 850
Powerstage: 5
Potrošnja iz utičnice (+AthlonX2+4GB Ram): cca 120W
Eth: New job #4376fdc5 from ssl://eu1.ethermine.org:5555; diff: 4000MH
Eth speed: 27.550 MH/s, shares: 1/0/0, time: 0:02
IGRANJE SA BIOS-om:
Code:
Staro 06.08.2020., 06:32   #2
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,709
Mutno se sjećam se da je bila neka radeonka u ovo doba 2017-e u Linksa na akciji za nekih 1400kn. Bio ultimativni best-buy.
Sapphire 480 4GB? Ili 470?
Kolko je gutala struje i koji je hashrate bio?
Staro 06.08.2020., 10:51   #3
Gigi1
Postovi: 2,138
30MH/s rade 470/480 na cca 75-80W()
Staro 06.08.2020., 11:16   #4
gunther
Postovi: 1,368
Autor kopija Pregled postova
Asus 470 4 gb, hashrate se mogao do 30 nategnuti, ako se ne varam
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 09.08.2020., 11:58   #5
damba_
Datum registracije: Feb 2017
Postovi: 119
Isprobao sam i ja svoju XFX RX 5600 XT 12Gbps 6GB GDDR6 THICC II Pro
Phoenix miner 5.1c + Windows 10.
Postavke su:
cclock 1230 MHz, cvddc 800 mV, mclock 1800 MHz, mvddc 850 mV
S tim postavkama hashrate je 39,19 MH/s i potrošnja same grafičke 100W iz utičnice.
https://imgur.com/a/bVSnVP8
Na ovoj grafičkoj najviše što sam uspio klokati memoriju a da je stabilna je 1800 MHz.
Najveći hashrate koji sam uspio izvući je 41 MH/s i potrošnja 110W, ali ruši se nakon nekog vremena.
Možda bi na nekom mining OS-u radilo bolje nego na windowsima.
Vidio sam da neke grafičke idu i 42MH/s, ali i ovo je sasvim ok.
Po ovome bi rig sa 6xRX 5600XT davao oko 235-245 MH/s i trošio oko 700W.
Ako netko planira kupiti XFX RX 5600 XT 6GB GDDR6 THICC II Pro, pripazite na memoriju koju dobivate zato što XFX ne nudi BIOS za nadogradnju sa 12Gbps na 14Gbps, nego postoji ista verzija grafičke samo s bržom memorijom.
Zadnje izmijenjeno od: damba_. 09.08.2020. u 12:03.
damba_ je offline   Reply With Quote
Staro 09.08.2020., 13:29   #6
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,843
Koju ti memoriju imaš ???
micron,hynix,samsung ???
Jesi modao bios na toj kartici ???
Radeon RX 5600 XT 6GB ETHASH 1250 - 925 - Micron - 0.800 - 42.86 - 116 - PhoenixMiner 4.9c - CL 19.50 - 2.7W/MH - WhiteSpot
Core clock - Mem clock - Memory type - Stable V - Hash rate - Watts - Miner -Driver - W/H - Source
Zadnje izmijenjeno od: Nbdy32. 09.08.2020. u 13:36.
Staro 09.08.2020., 13:51   #7
damba_
Postovi: 119
Ne znam koja je memorija jer u GPU-Z ne piše ništa.
Gdje to mogu provjeriti?
Nisam modao bios.
Probao sam s RedBios editorom kopirati tajminge sa 1550 MHz na 1750, 1800, 1875 i 2000, ali nisam mogao flashati taj bios, izbacio mi je error.
To je bilo s prvim biosom, ovaj drugi nisam probao modati.
Je li kod tebe modani bios ili original?
Staro 09.08.2020., 15:41   #8
Nbdy32
Postovi: 2,843
Ovaj benchmark je sa mmpos stranice,dečki tamo testiraju raznorazne kartice ...
Zato sam ti i stavio da probaš ...
GPU-z bi trebao pokazati koja je memorija na kartici ...
Ja imam samo 570 Nitro+ .... :-)
Staro 19.08.2020., 21:59   #9
kiki456
kiki456's Avatar
Postovi: 209
Pozdrav,
Da li netko ima deju zakaj na Red devil RX5700 nemrem updejtat bios više? Prvi put sam uspio, ali više ne da. Prvi put sam uspio ali sam zaboravio editirati sa power toolsom da se može malo više overclockati. Vratio sam na tvornički bios preko FreeDosa prema uputama koje sam našao, ali modificirani bios ne da više nikako. Kaže da ne može obrisati rom? Jel ima neku zaštitu ili ima neka caka koju ne znam? Hvala
kiki456 je offline   Reply With Quote
Staro 20.08.2020., 22:45   #10
Nbdy32
Postovi: 2,843
Jel da čitati bios ???
Probaj isčitati bios i vratiti nazad,bez modifikacije, ako ide,onda taj bios editiraj i probaj vratiti ...
Jel ako si stavio noviji bios, stariju verziju neće prihvatiti ...
Staro 24.08.2020., 21:51   #11
neverin
Datum registracije: Dec 2017
Postovi: 219
Rig 5xRx5700
3xAsus DUAL-RX5700-O8G-EVO, 8GB
1xASRock Radeon RX 5700 Challenger D 8G OC
1xMSI Radeon RX 5700 XT MECH OC
sve originalni bios
5.6.0-200807--hiveos-beta, AMD driver OpenCL 19.50 phoenixminer-ver. 5.0b i druge
840W iz zida, clock 1300/900, core volt 775, 252-257 Mh/s, temp core 60-66 temp mem 92-102, stale shares 18%
stabilno nekoliko sati
NHOS 1.2.0 low power mode, miner ?
1080W iz zida, clock ?/?, core volt ?, 251 Mh/s, core temp 64-76, mem temp ?
mmpOS phoenixminer-ver. 5.1c
852W iz zida, clock 1330/915, core volt 800, 264 Mh/s, core temp 56-64, mem temp 88-94 nema stale shares
Nije stabilno ni 30 min. prvo dobijem poruku kartica xy has low hashrate, onda ide restart minera, drugi put bude neka druga,
ne znam uzrok
Nema skoro nikakve razlike u hashrateu medju karticama, ili su sve 50 Mh/s ili sve 53 Mh/s.
NHOS previše troši uz najslabiji hashrate. HiveOS previše grije i proizvodi stale shares kako god mijenjao clockove, voltažu i verzije minera. mmpOS moram još probati iako nemam ideju kako to ustabiliti.
neverin je offline   Reply With Quote
Staro 24.08.2020., 23:15   #12
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Prvo probaj jednu po jednu grafu, vrti par sati pa vidi...Jer moguće da ti jedna grafa radi probleme. Zato nikako ne volim šarati grafe na rigu jer uvijek tako problemi
Staro 25.08.2020., 07:34   #13
Nbdy32
Postovi: 2,843
Gle za nešto stabilno moraš se igrati sa karticama ...
Benchmark koji sam stavio je za modificirani bios ...
Stavi kartice da rade bez ikakvog clocka,pa kako fripper veli,ckockaj jednu po jednu ...
ako ti se sviđa kako hashaju na normali,ostavi ih tak ... ako ne u modifikaciju ...
Niko od nas nije od prve uspio staviti 6-8-12 kartica u rig i da je sve oda savršeno radilo,inače čekiranje i pregled sharova se radi nakon 2 sata,onda se računa da se rig "ustabilio" ...
Evo i ja tek od jučer svoje 570 nitro sa 29 uspio nagurati na 31 ... mala razlika,ali na 30 kartica,dobio sam 2 kartice (po hash-u)...
nemam 5700 niti jednu,da bi ti dao neki konkretan savjet ... svi preporučaju red dragone i to čak bez XT-a (jeftinije za isti hash) ...
Staro 30.08.2020., 20:59   #14
neverin
Postovi: 219
Znam da bi trebao jednu po jednu, ali.. nemam pc samo za testiranje, i da maknem ostalih 5 šteta je da ne rade bilo koliko sad kad je isplativo, dok ja iz jedne pokušavam izvući par Mh/s više.
Stvar je u tome da i bez ikakvog clocka rig nije najstabilniji. Evo npr. skinuo sam jučer najnoviji mmpOS, stavio na Overclocking and config disabled i radilo je cijeli dan stabilno, sad je već 6 grafa, 303 Mh/s 1000W iz zida, memclock default 875, core clock i core voltage su sami došli na približno željene vrijednosti oko 1350 i 800. Onda probam dići samo memclock na 900, ne tijekom mininga, to je ranije uvijek išlo. Krene dobro 312 Mh/s ali ubrzo se sruši mmpOS. Sad sam vratio na Overclocking disabled opet radi oko 300 Mh/s ali troši 1150W iz zida, 2 grafe se spustile core clock i voltage a 4 drže jako visoko, mem temp su kod nekih na samoj granici 104-106 ali radi. Znači ništa nisam dirao u odnosu na jučer a velika razlika.
Koliko sam čitao hrpa ljudi ima problema s ovim grafama, i ako kome radi taj ne napiše koji je točno OS i koja verzija AMD drivera i minera.
Zanimljiv mi je oglas na njuškalu, MINING RIG 6 X RX5700, Hashing power 350 MH / s Potrošnja energije max. 850 W u opisu Nicehash OS s kojim sam isto već svašta pokušavao ali troši više i daje manje
Staro 31.08.2020., 08:58   #15
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Zasto ne probas simple mining? On je meni uvijek bio najbolji i najlaksi za postaviti.
I 1000w za 6x 5700 je ok pa ipak su te grafe 180w.
Vecina mojih rigova sa 6x rx570 su na 800w sto ispada za 200w više imas 70% veci hash.
I probaj smanjiti core clock a ne dizati.
Testiram ovih dana rx5700 pa vidimo...
Staro 31.08.2020., 10:10   #16
neverin
Postovi: 219
Nisam dizao core clock nego je visok bio kad bi isključio bilo kakav overclock.
Probao sam noćas simple mining, na prvu mi bolje izgleda od HiveOSa, mmpOSa i NHOSa. Ostavio sam preko noći OC na 1300/910 0,8V 0,8V i još uvijek tako radi. 990W iz zida 316 Mh/s 6xrx5700, i temperature su niže, pretpostavljam da se memclock može još malo dići ali već s ovim sam zadovoljan.
Staro 31.08.2020., 10:16   #17
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ma da SMOS je zakon, sve ovo drugo su kopije
Staro 01.09.2020., 17:59   #18
Dambo
Datum registracije: Feb 2004
Postovi: 305
Autor neverin Pregled postova
Jesi modao bios?
Dambo je offline   Reply With Quote
Staro 01.09.2020., 23:21   #19
neverin
Postovi: 219
Nisam modao bios, napisao sam to već. Hoću vidjeti što se može izvući sa originalnim.
Mogući dobitak je u % puno manji nego što je to bio sa modanjem biosa rx570/580, tako da se meni s tim ne žuri. Mislim da rudarski programi mogu i bez promjene biosa koristiti druge memory timingse ali i da sve to nije još dorađeno, mijenjaju se driveri, pa se onda rudarski programi moraju usklađivati s driverima ili bolje rade sa starim. Ja sam u svemu tome amater, ali recimo mogu u phoenixminer dodati samo jedan extra parametar -openclLocalWork 128 i hashrate svake rx5700 ide puno preko 60 Mh/s i mogu to staviti na youtube, ako me ne zanima koliko ću imati invalid ili stale shares.
Staro 02.09.2020., 01:22   #20
Dambo
Postovi: 305
Ako staviš postavi link ovdje.
Kupio danas dvije Sapphire RX5700XT Nitro+ 8GB. Sutra pokušam.
Skinuo Red Bios Editor i atiflash293plus, ali idem prvo bez modanja
Staro 02.09.2020., 16:51   #21
Dambo
Postovi: 305
Autor Dambo Pregled postova
Prvi dojmovi
SMOS
Bez modanja biosa 1600/910, 850mV,
svaka 51,9Mh/s, 110W
Staro 05.09.2020., 00:02   #22
neverin
Postovi: 219
Modao sam bios jedne PowerColor Red Devil Rx 5700, promijenio sam samo memory timingse, kopirao one sa 1500 na sve više. Nemam još konačan rezultat ali trenutno mi radi u SMOSu sama kao jedan rig: 56,8 Mh/s pri 1400/925 Mhz, 825/825/1350 mV uz malo manju potrošnju i temperature nego prije.
Rig sa 5 RX5700 bez modanja biosa radi mi 266,1 Mh/s (5x53,2) isto SMOS, Phoenixminer 5.1c pri 1400/920 Mhz, 800/800/1350 mV
Zanimljivo da mi ovaj rig nije bio potpuno stabilan dok iz njega nisam izbacio gore navedenu Red Devil koja bi morala biti najbolja grafa. Najskuplja, jedina ima 3 venta, dual bios i najniže mjerene temperature.
Staro 05.09.2020., 12:23   #23
Nbdy32
Postovi: 2,843
Eto meni u dolasku red dragonice,pa javim rezultate idući tjedan ...
Staro 14.09.2020., 19:10   #24
Nbdy32
Postovi: 2,843
Pa ...... stigle dragonice ...
Hash je 55.6 MH/s uz prikazano trošenje od 117-119W ...
Realno je to oko 135,kad se uračuna i ploča i proc,ram i hard ... iliti da velim da 3 kartice troše 530W sa HDD (neki 2.5"),ram (4gb),proc (G4560) i H110-DP3 ploča ...
klokovi su :
1390 CORE
912 MEM
0.787 V
1325 MVDD
800 MVDDCI
Sustav koji se koristi je MMPOS
Temperatura je lijepih 60 stupnjeva za core (uz 70% ventilatora) to ću sutra još probat smanjiti
Temperatura memorije je 82-86 stupnjeva,što vele da je isto OK ...
Moram i priznati da 3 dragonice imaju pola sharova od 12 komada 570 NITRO+,a razlika u hashu je 200 ...
Kučište koje sam iskoristio ima opciju za ventilatore,pa će i oni sutra doć najvjerojatnije unutra,tako da se ventovi na karticama mogu smanjiti ...
Zadnje izmijenjeno od: Nbdy32. 14.09.2020. u 21:21.
Staro 15.09.2020., 20:21   #25
neverin
Postovi: 219
Bios modan? Isto kao što sam ja?
MVDD može na 1300 jer tako sad rade sve moje, a i preporučuju na smos supportu - smanjit će temperaturu memorije.
Autor Nbdy32 Pregled postova
Nije mi jasno, misliš da rade više shareova nego što bi trebale po hashu?
Staro 16.09.2020., 12:40   #26
Nbdy32
Postovi: 2,843
Ne da rade više nego kaj bi trebalo,samo usporedba koliko je GDDR6 bolji i brži od GDDR5 ...
Naravno i kartice su puno jače ...
Staro 07.10.2020., 23:11   #27
neverin
Postovi: 219
Nakon dosta igranja, evo malo šire analize..
Rig se satoji od 6 kartica:
1x POWERCOLOR Radeon RX 5700 Red Devil
1x MSI Radeon RX 5700 XT MECH OC
1x Asrock Radeon RX 5700 Challenger D 8G OC
3x ASUS Radeon RX 5700 DUAL 08G-EVO
Powercolor ima modan bios, ostale ne. Simplemining, Phoenixminer-v5.1c
Rig se ne može pustiti da radi bez ikakvog overclocka jer troši +300W uz manji hash a kartice se kuhaju. Evo slike kako to izgleda uz napomenu da su prikazane temperature EDGE a postoje još i ASIC i MEM. Najbitnije MEM nekima su ovdje i preko 100.
Neki preporučeni safe overclock za sve rx5700 trebalo bi početi od: 1300/900 MH/s, core 812 mV mem 1300/750 mV
Dizanje core clocka 1300-1400 bitno diže hash ali samo kod nekih kartica (kod mene samo Powercolor). Mem clock može se probati dizati 900-930 ali dobitak je dosta mali u odnosu na rizik nestabilnosti. Neke kartice kao moje 3 Asusice imaju katastrofalno loše hlađenje memorije. Tada treba probati undervoltati memoriju ispod 1300 ali ako ne ide jedino je rješenje spustiti mem clock ako treba i na default 875. Na drugoj slici je jedno dosta stabilno stanje riga 318 MH/s 855W (iz zida oko 940W što izgleda dosta realno 85W za mbo+cpu i3-7100)
ID:	22785   Click image for larger version
Staro 08.11.2020., 19:13   #28
neverin
Postovi: 219
Mali update. Modao sam bios 3x ASUS Radeon RX 5700 DUAL 08G-EVO i sad one imaju najveći hash. I dalje se previše griju (mem preko 90) ali to je isto i sa manjim clockom i sa bilo kakvim postavkama. Kupio sam i jednu Asus TUF Gaming X3 EVO OC Radeon RX 5600 XT koja je vrlo hladna i daje 42 Mh/s.
Staro 08.11.2020., 20:37   #29
Nbdy32
Postovi: 2,843
Red Dragon ... na mmpos-u ...
Staro 12.11.2020., 10:26   #30
zozo10k
Lokacija: ...01...
Postovi: 73
Planiram složiti jedan rig sa 6 x 5700XT. Zanima me da li bi bilo dovoljno jedno napajanje od 1200W?
Hvala unaprijed!
zozo10k je offline   Reply With Quote
