Staro 08.07.2020., 12:55   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Prozujao vent na Corsair CX650M
Prozujao mi vent na cca 1 godinu starom PSU Corsair CX650M. Mislim da je ležaj, jer proizvodi neki visokofrekventni zvuk. Trenutno se premišljam da li slati na servis, ili da sam zamijenim vent. Stvar je u tome da ne zuji jako, pa poučen iskustvom, vrlo je lako moguće da će mi odbiti zamjenu na subjektivnoj razini. E sad, zna li tko kakav je vent unutra, kakav je konektor i s čim bi se mogao zamijeniti?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 08.07.2020. u 12:57. Razlog: Adding info
estugarda je offline   Reply With Quote
Staro 08.07.2020., 13:12   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
RMA, nemoj kemijati po komponenti koja ima jamstvo.
Staro 08.07.2020., 13:54   #3
Postovi: 23,579
Ako ćeš iskoristiti / traje garancija onda na RMA,
ako ne onda vidi > https://www.vortez.net/articles_page..._review,5.html
unutra je (vjerojatno) Yate Loon D12SM-12 > http://www.yateloon.com/style/frame/...nt_set=color_5
ima tema baš za zamjenu venta u psu gdje sve bitno piše, u međuvremenu se nije ništa promijenilo,
alternativa je Artic F12 ili P12
That's all
Staro 08.07.2020., 15:47   #4
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Traje garancija. Još 4 godine. Ali iskreno, ne da mi se navlačiti, objašnjavati, putovati u ZG ili plaćati poštarine i čekati. Da je neki dućan gdje poznam ekipu ili da zuji jako, onda bi, ali ovako mi je tlaka.
Hvala za savjet i linkove.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 08.07.2020., 19:52   #5
Nbdy32
Datum registracije: Aug 2016
Lokacija: Bestovje,Sv.Nedelja
Postovi: 2,838
Znam naporno je to sa slanjem,čekanjem i oko toga, ali ako ti se kaj dogodi na tom napajanju,osim venta ...
Nebudu ti priznali garu ... a možda bu totalka :-)
Staro 08.07.2020., 22:28   #6
quazar912
quazar912's Avatar
Lokacija: north-northwest
Postovi: 1,988
budeš bio bar 20jst dana bez napajanja..ak ti je hića menjaj sam.
ili ak si pri lovi uzmi neko jeftinije dok ti je ovo na servisu da nisi bez kompa.
ja znam šta bi ja napravio.
...and fly...
Thule nosač
Staro 18.08.2020., 07:16   #7
lange
lange's Avatar
Datum registracije: Dec 2011
Lokacija: karlovac
Postovi: 51
iskreno,rade bi kupio novo napajanje a ovo na servis i onda u prodaju.
bas cudno da ti VEC otisao ventilator.
lange je offline   Reply With Quote
