Staro 01.05.2020., 22:10   #1
Postovi: 17,143
SnowRunner
https://www.focus-home.com/games/snowrunner
Get ready for the next-generation off-road experience!
SnowRunner puts you in the driver’s seat of powerful vehicles as you conquer extreme open environments with the most advanced terrain simulation ever. Drive 40 vehicles from brands such as Ford, Chevrolet, and Freightliner as you leave your mark on an untamed open world.
Overcome mud, torrential waters, snow, and frozen lakes while taking on perilous contracts and missions. Expand and customize your fleet with many upgrades and accessories including an exhaust snorkel for heavy waters or chain tires to battle the snow.
Ride solo or with other players in 4-player co-operative!
Key features:
Face extreme environments in a highly advanced physics engine
40 unique vehicles to unlock, upgrade, and customize
Complete dozens of challenging missions across an interconnected world
Go solo or play with other players in 4-player co-op
Naletio na igru, zadnja 3 sata visim u igri.
Kamioni, blato, fizika kakvu još nisam vidio.
Pa pali 4WD, pa gasi, pa stavljaj u sporu brzinu, pa vitlno...
Samo heads up! Meni radi na ultra jedva 70 FPS-a, grafa na 95-100% cijelo vrijeme.
Jedna od najzahtjevnijih, ako ne i najzahatjevnija igra koju sam igrao.
Probajte, ima brdo misija, blata, snijega, vode, puno kamiona, džipova, svega...
Gamepad minimalno, volan poželjan. Kontrole na xbox gamepadu su super riješene.
Staro 01.05.2020., 22:30   #2
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,778
Volan poželjan od strane ljudi, ali na žalost support za volane je nikakav u trenutnoj fazi igre :/
xGAME je offline   Reply With Quote
Staro 01.05.2020., 23:31   #3
Postovi: 10,313
Kakav će mu biti support za modove, se zna šta? Malo pricey, zasad će biti dovoljan i Mudrunner. Lipo na kauč i gamepad u ruke - ima full support. Nekako me nikad nije vukao volanu toj igri...
Ne lajkam prejasnu mapu, previše pokazuje naspram Mudrunnera. Svaki puteljak i sl, nema onoga sve je zeleno, ali ako pogledaš malo bolje vidi se kozja staza samo je pitanje može li proći kamion - idi istraži teren.
Staro 02.05.2020., 01:47   #4
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,165
Nastavak mudrunnera, na prvu izgleda dosta šarenije od ruskog sivila i depresije što je nekako bila i čar igre.
Sigurno će se igrati kad padne cijena ili dođe na steam.
Definitivno nije tip igre za volan jer je ipak fokus na treće lice uz stalno rotiranje kamere. Za joypad dušu dalo
Zadnje izmijenjeno od: nub. 02.05.2020. u 01:54.
Staro 02.05.2020., 14:07   #5
golfw12
golfw12's Avatar
Postovi: 424
jel netko igra na EGS a da mu zapravo igra radi bez crashanja duže vrijeme?
kupio sam key sa cdkeys.com i aktivirao je na svom računu, igra mi radi random od par min do jučernjašnjeg rekordnog sessiona najdužeg dosad bez crashanja u komadu od 5h
hardver iz potpisa, friški driveri, neznam šta više probati
igra je kupljena jer sam fan i spintiresa i mudrunnera
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 02.05.2020., 20:38   #6
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,317
poceo igrati,meni sve radi ok jer igram na plazmi u 720p rezoluciji ali izgleda odlicno jer je plazma HD ready pa netrazi velike rezolucije da prikaz bude odlican,grafika jako ljepa..ukratko kao Death Stranding samo na kotacima,sad ko ima volje i vremena svakako preporuka!
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 05.05.2020., 12:13   #7
golfw12
golfw12's Avatar
Postovi: 424
nakon što sam napravio verify opciju na igru, nešto se stanje popravilo, prvo se downloadalo oko 5gb pa kad se to završilo ponovo je downloadalo oko 11gb, nemam pojma šta je to bilo ali nakon tog sam uspio igrat par puta po pola sata i guglajuči sam pročitao da probam spustiti frekvenciju rama u biosu što sam i napravio, prebacio sam xmp profil sa 3200mhz na 3000mhz i mogu reči da poslje tog verify i promjene xmp-a igrica radi bez crashanja, nedjelju sam imao maraton 10h u komadu bez greške
neznam kako joj je pomoglo promjena xmp profila ali zasad je dobro, radi
dojam igre, zanimljivo je način na koji smetaju grane od borova i da kamion/džip zapne i neprolazi samo tako kad se probijaš i voziš kroz šumu, pogotovo kad imaš kanister goriva na krovu džipa i zapneš s njim gore za granu (i manevrirajuči dok skužiš s čim si zapeo, se prevrneš )
-"pokidao" sam gumu prednju na kamionu, imala je 0/50 bodova i izgledala je kao da je prazna i to je promjenilo način upravljivosti, smotaš u tu stranu i pokušaš skreniti i kao da nema gripa
-isprobo sam dizalicu na kamionu i onaj mali kran, osjeti se utjecaj gravitacije kad neizvučeš one bočne potpore za stabilnost a i kad izvučeš do kraja "ruku" pa probaš dizat teret ili okretat prevrnito vozilo da ga ispraviš na točkove vidi se kako se cjeli kamion naginje
-zavisno od terena možeš zapast bez problema bilo gdje iako izgleda da je "tvrda" podloga
-fali mi mjenjač iz mudrunnera gdje je svaka brzina imala 3 podbrzine
-potrošnja kamiona je velika, planiraj put dobro ili vuci malu cisternu sa džipom
-lagano se za izvrnit na bok, bio pun ili prazan kamion
HDD: 256 GB M.2 SSD
PSU: HP 90W
Staro 05.05.2020., 15:46   #8
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,890
definitivno nije igra za mene.
Doslovno osjećam prolaznost života Toliko je beskorisna.
Ivo_Strojnica je online   Reply With Quote
Staro 05.05.2020., 19:19   #9
nub
PREMIUM
nub's Avatar
Postovi: 2,165
Evo nisam mogo odolit i posudio sam igru. Vidi se fini napredak u odnosu na mudrunner.
Sve mape, challengei i taskovi/contracti su ukomponirani u jedan game mode pa igra pruža više osjećaj napretka. Također ima više vozila, više opcija za apgrejdat, mape su generalno zanimljivije i šarenije (koristili su i ostale tonove pored smeđe, sive i zelene). Malo su i skretanje popravili, sad se kotači doista okreću na poziciju ovisno o analog sticku, al i dalje je malo pimplavo za vozit . Blato (i snijeg) mi se čine bolje napravljeni, nešto teže je nego prije, moguće je lako zapest ako nisi u prikladnom vozilu dok se prije moglo kolko tolko iskoprcat iz govana i s neprikladnim vozilom. Nema više opcija za normal ili hardcore mode već je sve negdje između po težini. DLC je čisti pay to win i nudi scoutove kakve bi se moglo složit vjerojatno tek na kraju igre, pa preporučam zaobići ili ih ne koristiti za pravo mudrunner iskustvo.
Ali kao što je kolega gore napisao, s vremenom počnem gubit živce koliko neke stvari sporo idu, baš se osjeća prolaznost života. Najviše volim scoutat, dok mi beskrajno razvoženje materijala postane naporno. U dvoje bi išlo bolje i brže.
Ako niste veliki fan možda bi bilo dobro malo sačekati da ispeglaju početne bugove. Ništa mi nije bilo game breaking, ali definitivno ima mušica.
Autor golfw12 Pregled postova
Imaš tu opciju, samo moraš instalirat napredniji gearbox. Potrošnja mi se čini manja nego u mudrunneru na hardcore.
Staro 05.05.2020., 19:35   #10
Postovi: 10,313
Ovo je sigurno bolje igrati u dvoje (kao i mudrunner) #bezobraznioglas tko igra MR moze se javiti za co-op
Staro 06.05.2020., 15:32   #11
drle1
drle1's Avatar
Lokacija: Velika Gorica
Postovi: 182
Autor xlr Pregled postova
onda mozemo threesome
drle1 je offline   Reply With Quote
Staro 10.05.2020., 13:54   #12
Smarty
Smarty's Avatar
Datum registracije: May 2005
Postovi: 1,285
Instalira sam igru al nebi bog podesija Logi G25 da radi. Gledan po netu a nigdi nac tutorial
Smarty je offline   Reply With Quote
Staro 10.05.2020., 14:08   #13
xGAME
xGAME's Avatar
Postovi: 4,778
Nema podrške za volane. Tu i tamo neki radi i to je to.
Staro 11.05.2020., 01:27   #14
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: Tannhausen (Aalen)
Postovi: 486
Ma i da ima podrška - zasad su volani nepotrebni. Nit imaš FFB niti možeš koristit mjenjač kak spada. Imam G920 i ne preporučujem igrat s volanom. Vjerojatno ću se vratit na XBox360 kontroler.
