Staro 22.10.2019., 12:48   #1
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,744
HP Omen 2018 + Ballistix 2666 Mhz = 2400 Mhz
Pozdrav,
Kupih ovaj ram https://www.crucial.com/usa/en/nuc6i5syh/CT9643384 , za HP Omen 2018 (HP 15-dc0005nm ) .
Kit je 2 x 16 GB ( I know why 32 GB) ; no bio je jeftiniji nego kod nas 16GB.
Memorija radi, no na 2400 MHZ! Postoji koja fora da ju upogonim na nativnu brzinu?
BIOS koliko sam vidio nema Advanced setup?
Danke.
Staro 22.10.2019., 13:12   #2
goran047
goran047's Avatar
Datum registracije: Nov 2016
Postovi: 142
Na linku di si kupio imas 9 reviewa, i odmah u prvom je netko napisao:
"The issue with these particular modules is that the only profile which runs at the speed of 1333 MHz DDR (2666) is an XMP profile, not a JEDEC profile. If your BIOS does not support XMP(Extreme Memory Profiles) , then you will not be able to run this ram at 2666, only at 2400"
goran047 je offline   Reply With Quote
Staro 23.10.2019., 00:59   #3
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,744
Dođe to s godinama.
