Staro 11.08.2019., 09:56   #1
Damir Kelic x
Damir Kelic x's Avatar
Lokacija: izmedu sb & ng
Postovi: 117
kablovi za modularno CM rs 600w pro napajanje
poz, nabavio jako jeftino ovako napajanje ali nemam kablove za njega, tocnije ona dva za grafe, jel ima neko tako pokvareno pa da mi proda ili zna di se moze kupiti?
hvala
https://www.hardwaresecrets.com/cool...supply-review/
Damir Kelic x je offline   Reply With Quote
Staro 19.11.2019., 11:22   #2
trex
trex's Avatar
Lokacija: Bjelovar
Postovi: 649
Autor MalaTang Pregled postova
Cable (461816 YL005):
Cables include power cables, control cables, compensation cables, shielded cables, high temperature cables, computer cables, signal cables, coaxial cables, fire resistant cables, marine cables, mining cables, aluminum alloy cables, and the like. They are composed of single or multi-strand wires and insulating layers for connecting circuits, electrical appliances, and the like.
This hope can help you
Šta je ovo? bot na forumu?
trex je offline   Reply With Quote
