Staro 02.07.2019., 20:43   #1
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,573
Intel ARC/Xe GPU
Nekoliko novosti o intelovoj dGPU , pod nazivom Xe:
Intel Puts Out More Official-looking Renders of the Xe Graphics Card
"Intel China through its Weibo (Twitter-equivalent) handle put out more official-looking renders of its Xe graphics card. The Weibo post doesn't cite an author, leading us to speculate that the company's industrial design team is close to finalizing a product-design for at least the client-segment derivative of Xe. The swanky-looking card apparently has a stamped metal cooler shroud, a cooling solution that's based on a fin-stack heatsink that's ventilated by three fans, and quite some LED embellishment. An interesting design detail is the exponent symbol projected on the center fan. The power inputs are located at the tail end of the card, which is where most professional graphics cards have them; and consist of a pair of 8-pin PCIe inputs. Display inputs include three DisplayPorts, and an HDMI. The first Xe graphics card bound for 2020 will be built on Intel's 10 nm silicon fabrication process, which offers comparable transistor-densities to current 7 nm nodes."
Staro 03.07.2019., 09:42   #2
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,833
S obzirom da je Intel počeo kuhati Larrabee još sada davne 2010. nadam se da će Xe biti dostojan pojavljivanja na tržištu uz Nvidiu i AMD.
Staro 03.07.2019., 20:07   #3
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
A neznam, ove slike mi iskreno izgledaju ko da su se djeca igrala, ali dobro, izgled je nebitan. Cijena i performanse, ništa drugo.
Slobodno me dodajte na PSN
Staro 03.07.2019., 23:17   #4
Sinac
Sinac's Avatar
Postovi: 2,833
S obzirom da Intel cilja na tržište brze pohrane podataka koja će pratiti nadolazeću 5G mrežu i na servere koji će to objediniti, ne bih se čudio da ovom grafičkom karticom ulaze i u dio tržišta koje Nvidia pokriva svojim Tesla karticama.
Staro 04.07.2019., 09:50   #5
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Autor Disco Pregled postova
To su konceptualni cooleri od umjetnika (vjerojatno neće vidjeti tržište jer ne radi za vendore)
Zašto ih intel predstavlja - vjerojatno da golica maštu i da se priča o njihovim gpu
Mene najviše zanima rang performansi, spominjalo se od gtx 1060 pa do gtx 1080, no random rant, nije ni leak. Vrlo vjerojatno neće napasti nvidia high end, a možda ni rang najjačih amd-ovih (tada navi 20)
Staro 04.07.2019., 09:59   #6
Sinac
Sinac's Avatar
Postovi: 2,833
https://www.tomshardware.com/news/in...res,38246.html
Imaš na slici pod nazivom GPU IP SCALABILITY navedeno "Datacentre/AI". I na tom linku pretpostavljaju: If successful, this could be Intel's answer to Nvidia's CUDA, except it would work on any Intel processor.
Staro 04.07.2019., 14:00   #7
Postovi: 8,396
Kaj se tiče Intelovih GPU planova, sudeći po ex-AMD/ATi/RTG ekipi koja se okupila oko tog projekta - i taj dio priče bi se mogel odigrati slično ko i CPU verzija. U prijevodu, Intel GPU bi sasvim lako mogel jako sličiti sadašnjim Vega i MI60 karticama, samo naravno Intelov marketing će to (kao i za procesore) zapakirati i prezentirati kao njihovu ideju i nešto što se dosad nije moglo ni zamisliti. I tu se vraćamo na ono kaj sam u ovakvim osvrtima već nekoliko puta napomenul - nVidia. Kaj god da Intel prezentira kao svoj GPU, nVidia će promptno rastaviti na sastavne dijelove i prije nego krene prva narudžba. Naravno, pod uvjetom da Intel GPU uopće bude u rangu s Quadro i Tesla modelima. U suprotnome će se Jen-Hsun samo nasmijati i odmahnuti rukom.
Staro 04.07.2019., 23:46   #8
Sinac
Sinac's Avatar
Postovi: 2,833
Ma tako sam nekako i ja razmišljao sve dok nisam shvatio da je Intelu ciljano tržište zapravo upravo ovo navedeno, "Datacentre/AI". Ne mora sama grafička biti posebno brža od Nvidia pandana, dovoljno je da Intel uklopi svu novu tehnologiju pa da se to na serverima ipak dobro vrti. Tu mislim na brze SSD-ove, Optane i pitanje što još Intel skriva kao asa u rukavu, ako se to sve ukomponira u server koji ima ultrabrzi dohvat i pohranu podataka, to bi moglo biti pun pogodak.
Staro 02.08.2019., 21:58   #9
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,498
Staro 18.11.2019., 13:00   #10
Postovi: 8,396
Intel’s 2021 Exascale Vision in Aurora: Two Sapphire Rapids CPUs with Six Ponte Vecchio GPUs
Despite initially being a ‘deliver by 2020’ project, Intel is now saying that Aurora will be delivered in 2021.
This means that Intel has to execute on the following:
  • Manufacturing at 10++ in sufficient yield with respect to cores/frequencies
  • Manufacturing at 7nm for chiplets, both in yield and frequencies
  • Transition through DDR3 to DDR4 (and DDR5?) in that time frame
  • Transition through PCIe 3.0 to PCIe 4.0 and PCIe 5.0 in that time frame
  • Release and detail its 2nd generation Optane DC Persistent Memory
  • Provide an SDK to deal with all of the above
  • Teach researchers to use it
Ultimately, based on what we know so far, Intel still has a lot of work to do to deliver this by 2021. At any rate, some of these technologies might not get in the hands of the rest of us until 2022.
Izvor: AnandTech
Staro 04.12.2019., 22:18   #11
Postovi: 8,396
Intel Xe rumors: Development reportedly stagnating and efficiency worse than its competitors
Under the direction of chief architect Raja M. Koduri:
  • Work on the Xe GPUs does not seem to be going well
  • Ponte Vecchio is unlikely to arrive within the next two years
  • Currently, the efficiency of the Xe architecture is relatively low compared to the competition
  • For the time being, there are no plans for custom models of Xe graphics cards
  • Drivers would need a lot of time to improve
Izvor: Guru3D
Staro 04.12.2019., 23:01   #12
Manuel Calavera
Postovi: 14,584
Raja
Flashback kao da čitam vijesti o Vegi i Naviju
Staro 04.12.2019., 23:03   #13
Postovi: 8,396
Majke mi i onda bude frajer (opet) otišel u neku drugu firmu i sve 5, ovi nek se slikaju. PR tim im je već zbrisal, a ovi još love nanometre po Internetima.
Staro 05.12.2019., 07:11   #14
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,327
Raja se očito zna dobro prodat.
Da ne guglam, ima li nešto uspješno iza čega on stoji ?
Staro 05.12.2019., 10:00   #15
Postovi: 8,396
Uspješno prelazi iz firme u firmu pri čemu uvijek zadržava rukovodeće pozicije. Super su mi ovakvi intervjui s njim u kojima uvijek priča iste stvari i uvijek je fokus stavljen na arhitekturu.
Ko zna kaj bude na kraju ispalo od Intelovih GPU rješenja, ali ne bi me čudilo da Raja Maharadža i ovaj brod napusti u potrazi za novim izazovima. Možda ga Kožna Jaketa angažira.
Staro 05.12.2019., 10:29   #16
Ne znam samo šta će Kožnatom Rađa. Da mu zanosi jaja u zavoju...
Staro 05.12.2019., 10:31   #17
Postovi: 8,396
Baš zato, nek ga voda nosi, što dalje od AMD-a.
Staro 05.12.2019., 13:47   #18
Manuel Calavera
Postovi: 14,584
Sad lik više nema izgovora. Imao je vremena, financije i ljude, ako to već nije imao u AMD-u
Osobno ne vjerujem da će biti nešto mega, ali ne bi bilo dobro da intelove gpu ispadnu flop, one time, tj. da ne ostanu 3 igrač
Staro 05.12.2019., 13:52   #19
Gigi1
Postovi: 2,138
Zapravo je najuspješnije razdoblje Ati/Amd gpu-a bilo pod njim, tada je Amd konkurirao i bio bolji od nvidie u dobrom proju parametara, pogotovo u perf/watt.
To je doba bilo ono doba terrascale arch
Staro 05.12.2019., 14:06   #20
Postovi: 8,396
Da, ali to je već bilo u planu i opticaju prije njegovog (ponovnog) dolaska u AMD. Nekak ostaje dojam da su za njegove uspjehe zaslužni drugi, tj. timovi za koje je bil zadužen.
Slično kak se Jim Keller spominje u Zen kontekstu, a zapravo je Michael Clark (1 - 2 - 3) zaslužan za sve uistinu bitno.
Previše toga je trenutno ni-vrit-ni-mimo u Intelu, a Raja i biser Ryan Shrout baš ne pomažu u takvoj situaciji.
Staro 05.12.2019., 19:49   #21
Gigi1
Postovi: 2,138
Ne baš, terrascale je izašao 2007, a on je u ATi-u od 2001, istina nije samo on zaslužan za uspjeh odredjene qarch, ali isto tako nije ni jedini krivac.
Za ostalo se sve slažen, kak si napisao, ni vrit ni mimo
Staro 05.12.2019., 22:23   #22
Manuel Calavera
Postovi: 14,584
Staro 05.12.2019., 22:40   #23
Postovi: 8,396
PoCjetimo se kak to izgleda kad Raja i Intel (1 - 2 - 3) stvarno imaju i hardver spreman. Na pragu 2020. pak imamo puno priče, bez konkretnog hardvera i popratnih detaljnih tehničkih osvrta.
Staro 06.12.2019., 00:33   #24
Da, bilo bi prvi puta da gledamo nekakve performance chartove proizvoda koji ni ne postoji
Staro 06.12.2019., 01:00   #25
Postovi: 8,396
Kak god, ali izgleda da nemaju ni takav materijal. Ian Cutress sjedi u prvim redovima prilikom svih tih konferencija za tisak i nema pojma kaj točno Intel ima i na kojem proizvodnom procesu.
Staro 06.12.2019., 01:01   #26
Ima rekordnu zaradu. Meni dovoljno.
Staro 06.12.2019., 01:14   #27
Postovi: 8,396
U tom slučaju, jedna prigodna...
Staro 06.12.2019., 01:24   #28
Mladenxy
Mladenxy's Avatar
Postovi: 4,389
Polako, grade iz nule nisu "samo" kupili gotovu tvrtku i brendirali. Kad izbace tek 2./3. generacija će biti vrijedna spomena. Kaj se zarade tiče psi laju, karavane prolaze.
Staro 06.12.2019., 08:02   #29
Legendo ovo je sviralo u autu jutros
Svakako paše za tematiku.
A ovo za Intel i ekipu oko njega, pocjeća me na kolegu iz srednje. Lik je slušao Beatlese. Glavni argument mu je bio "to je najbolji i najprodavaniji bend svih vremena, ove vaše Metalike i to, to je qrac. Svi skupa nemaju prodanih albuma ko ovi moji".
Tako da ono... valid ground je valid ground
Iskreno, bilo bi dobro da kad grafičke izađu da ne bude samo "rekordna zarada" nego da se hvatamo čak i usporedbi sa duopolistima. Držim fige.
Staro 06.12.2019., 10:05   #30
Mladenxy
Mladenxy's Avatar
Postovi: 4,389
Akcija i reakcija...mindfacory de statistika svako malo i sl.
