Staro 30.09.2018., 12:20   #1
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Log potrošnje memorije
Pozdrav ekipa. Imam jedno vjerojatno banalno pitanje.
Treba mi neki program koji bi mi logirao trenutnu potrošnju RAM memorije (fizičku i swap, poželjno i točno po programima koliko koji trenutno koristi RAM-a). Znači da mi zapisuje log i da mogu pogledati povijest potrošnje memorije. Nešto kao Resource monitor, samo da vidim sate i dane, a ne samo 60 sekundi
Možda se to može i iz Windowsa samo sam ja tukac koji to ne zna Pomagajte!
Staro 30.09.2018., 19:55   #2
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,759
https://stephanvaningen.net/powershe..._usage_logging
Evo ti malo izmijenjena skripta:
Code:
#Set-ExecutionPolicy -Scope Process -ExecutionPolicy Bypass
$Processes = get-process
$gDate = Get-Date -format "yyyyMMdd"
$gTime = Get-Date -format "HH:mm:ss"
$gFileName = "RegisterProcessMemoryUsage$(get-date -f yyyyMMdd).csv"
foreach($Process in $Processes)
    $Obj = New-Object psobject
    $Obj | Add-Member -MemberType NoteProperty -Name Date -Value $gDate
    $Obj | Add-Member -MemberType NoteProperty -Name Time -Value $gTime
    $Obj | Add-Member -MemberType NoteProperty -Name ID -Value $Process.Id
    $Obj | Add-Member -MemberType NoteProperty -Name Name -Value $Process.Name
    $Obj | Add-Member -MemberType NoteProperty -Name PagedMem -Value $Process.PagedMemorySize64
    $Obj | Add-Member -MemberType NoteProperty -Name PagedSysMem -Value $Process.PagedSystemMemorySize64
    $Obj | Add-Member -MemberType NoteProperty -Name nonPagedSystemMem -Value $Process.NonpagedSystemMemorySize64
    $Obj | Add-Member -MemberType NoteProperty -Name Responding -Value $Process.Responding
    $Obj | Export-Csv -Path $gFileName -Delimiter "," -Append -NoTypeInformation
#This removes double quotes from the numeric columns (content of the regexp depends on the Add-Members above)
(Get-Content $gFileName) -replace '^"(.*?)",(.*?),"(.*?)",(.*?),"(.*?)","(.*?)","(.*?)",(.*?)$', '$1,$2,$3,$4,$5,$6,$7,$8' | Set-Content $gFileName
Nemoj zaboraviti na
Code:
ako neces digitalno potpisivati skriptu.
Dobijes nesto u ovom stilu:
Stavis ga u Scheduler i Bog da te vidi. Samo pazi, nije bas jeftina skripta, tako da nemoj bas raditi query svakih par sekundi...
Programer
