Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Logitech G5 Laser Mouse Firmware Update 1.1
Fakat nisam znao kam bi ovo stavio pa ide pod soft Eh, ako ste mislili da se flasha novi firmware samo za prže ili hardove (ili ostalu periferiju "sitnog zuba")-malo ste se z******i ![]() Ovaj je za dobrog starog mišonju. http://www.logitech.com/index.cfm/do...instructions=1 Instructions for Downloading the Logitech® G5 Laser Mouse Firmware Update 1.1 Updating your Logitech® G5 Laser Mouse´s firmware to track on more surfaces is easy and quick. To obtain the latest firmware, download the G5Update1.1.exe file. And follow the instructions: 1. Plug your mouse into the USB port on your computer. 2. Open the G5Update1.1.exe file. 3. Follow the on-screen instructions: a. If your mouse needs to be updated with the current firmware (version 1.1), the program will say “Found a G5 with firmware 1.0.” i. Click on the “Flash” Button ii. The program will then automatically prepare your mouse for the update and execute the update. This process takes less than 30 seconds. During this stage, it is critical that you do NOT unplug your mouse or quit the program iii. Once the update is complete, you will see a message asking you to unplug and re-plug your mouse iv. After you´ve plugged your mouse back in, choose “Exit” to close the update program b. If your mouse already has the current version 1.1 firmware, the program will say “Found a G5 with Firmware version 1.1” — there is no need to update your mouse. Just click on the Exit button to exit the program. Your updated Logitech® G5 Laser Mouse is now ready for use. Note: Some dialogs and warning message may appear during the updating process and should be ignored. They do not represent a failure of the updating process. Disregard these messages and continue to follow the on-screen instructions provided within G5Update1.1.exe. Anticipated messages include… 1) “Found New Hardware: A problem occurred during hardware installation. Your new hardware might not work properly.” 2) “USB Device not recognized: One of the USB devices connected to this computer has malfunctioned, and Windows does not recognize it. For assistance in solving this problem, click this message.” Note: The 64-bit version of Windows® XP does not support this update. If you are using a 64-bit version of Windows® XP, please contact Logitech´s Customer Support for further guidance. |
