Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 16.02.2017., 15:51   #1
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Kad lead-free nije dovoljno zlo
Taman kad čovjek pomisli da nema dalje...
BEIJING and TOKYO – Feb 7, 2017 – Lenovo (HKSE: 992) (ADR: LNVGY) today announced a new patent-pending Low Temperature Solder (LTS) process developed to improve PC manufacturing by conserving energy and increasing reliability.
The true innovation is in the science and testing required to develop and validate the new LTS process. Lenovo investigated thousands of combinations of solder paste material composed of a mixture of tin, copper, bismuth nickel and silver, specific compositions of flux material and unique profiles of time and heat temperatures that combine to enable this process.
With the new LTS process, soldering heat is applied at maximum temperatures of 180 degrees Celsius, a reduction of 70 degrees from the previous method.
After validation of the procedure, Lenovo discovered a significant reduction in carbon emissions as a result of using the new process. The procedure is already in production for ThinkPad E series and the 5th generation X1 Carbon recently announced at CES. Throughout 2017, Lenovo intends to implement the new LTS process on 8 SMT lines and estimates savings of up to 35% on carbon emissions1. By the end of 2018, Lenovo aims to have 33 SMT lines with 2 ovens per line using this new process, giving an estimated annual saving of 5,956 metric tons of CO22. To put this into perspective, the equivalent reduction in CO2 emissions is equal to the consumption of 670,170 gallons of gasoline3 per year.
Izvor: LINK
Staro 17.02.2017., 09:47   #2
tskarda
tskarda's Avatar
Postovi: 1,129
Misliš da će trajnost materijala odnosno lakše taljenje dovesti do učestalijih kvarova na elektronici?
Alvin, što ti kažeš?
Staro 17.02.2017., 10:33   #3
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Nije toliki problem ni u temperaturi topljenja nego u sastavu paste. Sastav paste je problem. Bizmut...
Staro 17.02.2017., 11:01   #4
tskarda
tskarda's Avatar
Postovi: 1,129
Ali što tebi osobno znači Bizmut osim kemijskog elementa, koji su mu nedostaci?
Staro 17.02.2017., 11:52   #5
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Otrovan.
U biti, ili imaš olovo u zubu ili imaš bizmut u računalu, nijedno nije dobro.
Staro 17.02.2017., 12:08   #6
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Dok periferiju ne grizeš zubi'n dobro je, olovo i bizmut na istom sweet spotu
Pomelo mi sig -.-
Staro 17.02.2017., 12:11   #7
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 779
Olovo kao plomba...zapravo nije niti otišlo,jer nije dokazano da ga tijelo može otopiti kao takvo.I bolje je.Tak kažu zubari...ko će ga znat.Kava je malo zdrava pa štetna pa nevalja,pa slobodno pijte itd...PVC stolarija je bila hit,sad se drvo vraća...nastavi niz...
Zadnje izmijenjeno od: Flood. 17.02.2017. u 12:21.
Staro 17.02.2017., 13:06   #8
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
3310 ponovno u prodaji?
Staro 17.02.2017., 14:48   #9
spitfire83
spava mi se
spitfire83's Avatar
Datum registracije: Nov 2013
Postovi: 329
Autor Halos Pregled postova
Otrovan.
Otrovan u jako velikim količinama. Koristi se za izradu ne otrovne sačme i streljiva za lov.
spitfire83 je offline   Reply With Quote
Staro 17.02.2017., 16:19   #10
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
...i u organskim preparatima za liječenje sifilisa...
Kak onda može bit otrovan?
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 18.02.2017., 11:46   #11
Alvin
Postovi: 853
Biti će da sam ekološki osvješten, volim koristiti leguru s nižom točkom tališta kada god to mogu.
Trajnost, pojma nemam. Postoji metodologija kojom se to testira i oni će to sigurno napraviti prije masivne upotrebe, treba pričekati rezultate.
Onako na prvu, bolje, ponajviše radi fluxa. Bizmut kao element prema specifikacijama daj eobećavajuće rezultate, ima sve što je meni potrebno za otvaranje podružnica u svakom zaseoku. Loša termička provodljivost, loša elektro provodljivost, širi se pri promjeni ag. stanja. Djeluje zbilja obećavajuće. No kako rekoh, pričekajmo rezultate.
A ekologija, mali zeleni i to, stvarno koga briga?
Zadnje izmijenjeno od: Alvin. 18.02.2017. u 11:56.
Alvin je offline   Reply With Quote
Staro 18.02.2017., 14:53   #12
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Problem su mehanička i električna svosjtva bizmuta, ne ekološka.
Staro 22.02.2017., 19:50   #13
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Valjda živa, ne olovo ako misliš na amalgamske plombe?
U svakom slučaju nebitno
Autor Milentije Pregled postova
Gledano po uzoru na razne metalne legure u kojima različiti maseni udio elemenata igra lavovsku ulogu u karakteristikama materijala, vjerujem da i bizmut može igrati isto takvu ulogu.
Nisam upoznat s današnjim supstancama za lemljenje, daleko od toga, ali je svakako moguće ovo gore. Tinol koristim relativno rijetko, pa se ne zamaram koji i kako, nema se vremena
Bit će interesantno vidjeti 2 godine nakon prodaje kad već thinkpadovi budu izraubani kako će držati
Spoiler alert!
