Staro 01.02.2017., 17:03   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
(riješeno) Lenovo ThinkCentre M55 8808-CTO Win 7 Ultimate x64 problem
Pozdrav,
Dakle radi se o PC-u iz naslova kod kojeg se tokom instalacije Win 7 Ultimate x64 javlja ova poruka o gresci: “Windows installation encountered an unexpected error. Verify that the installation sources are accessible, and restart the installation.
Error Code: 0xC0000005”.
CPU podrzava x64, u cemu je problem? Source instalacije, ili ta konfiguracija uopce ne podrzava Win 7 x64? HDD je testiran i OK, isto vrijedi i za RAM.
Konfiguracija je:
Intel Pentium D 925 Presler @ 3.0
Chipset Intel Q965
Grafika Intel Q965/963
2GB RAM DDR2.
Zahvaljujem unaprijed!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 01.02.2017., 17:24   #2
syss
syss's Avatar
Postovi: 10,805
ne znam koji je problem, ali provjereno gore igra w7 x64.
Staro 01.02.2017., 17:56   #3
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor syss Pregled postova
Hvala
Probat cu s drugim izvorom instalacije. Javim ako uspije.
Staro 01.02.2017., 20:30   #4
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,622
Probaj instalirati preko bootabilnog sticka windowse, možda ti zeza čitać ili DVD medij
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 02.02.2017., 14:21   #5
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor maXonja Pregled postova
Inace u zadnje vrijeme koristim samo USB bootabilni stick, no problem je bio u losoj instalaciji na sticku, napravio sam iznova bootabilni stick i sad je sve uredno proslo. Jedino me muci grijanje HDD-a u Thinkcentru, zagrije se do 100c
Staro 02.02.2017., 15:12   #6
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,622
Hmm, vidiš, to još nisam doživio da bi bio problem u instalaciji na sticku
Jedino ako se iz nekog razloga nakon nekog vremena ne corruptaju fileovi na sticku, druge mogućnosti ja mislim da nema
Ali ako bi došlo do toga onda bih već sumnjao u ispravnost samoga sticka
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 02.02.2017., 17:20   #7
Postovi: 23,618
Autor Traitorous_8 Pregled postova
Jesi siguran da je info točan, baš HDD ?
Je da se radi malom zbijenom SFF kučištu al opet je debelo previše.
Vidi šta se dešava, bar nije teško otvoriti kućište.
Staro 03.02.2017., 16:40   #8
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor Nikky Pregled postova
Sve je u redu, svi fan-ovi rade. Trenutno HDD temp = 76c. Provjerio sam i sa vanjskim termometrom. Fan napajanja se vrti konstantnom brzinom, nisam siguran da li je interno reguliran sa termistorom ili ne. Mozda ne bi bila losa ideja otvoriti napajanje, ispuhati te pogledati situaciju s kontrolom fan-a ili ga cak zamijeniti.
Staro 03.02.2017., 16:42   #9
syss
syss's Avatar
Postovi: 10,805
neće ti taj m55 još dugo bez obzira na temp (koji je vjerovatno cpu temp, a ne disk samo ga krivo prikazuje)... prošlo mu vrijeme jbg.
Staro 04.02.2017., 15:05   #10
Traitorous_8
Lokacija: Vž
Postovi: 81
Cpu mu je na 45c-50c, oce jos par godina pa tek onda
Staro 04.02.2017., 15:36   #11
syss
syss's Avatar
Postovi: 10,805
nama je dosta njih pokrepavalo, zato ti velim.
