13.12.2016., 14:11 | #1 |
Datum registracije: Jul 2015
Lokacija: Vukovar
Postovi: 248
Ne može se logirat na facebook
Let's Check Your Device for Malicious Software -->
Hi Maria, we're continuously working to keep your account secure. We've noticed that this device may be infected with malicious software. To continue to use Facebook, you can either use other devices or clean this device by downloading the scanner provided by Facebook and Trend Micro. Clean This Device Download Scanner Please download ttie recommended scanner fiom Facebook and Trend Micro to clean your Infected device By doing Download, you agree that Faceoook and Trend Micro can access your device in order to collect, analyze and remove files that may be malicious and use and snare the colected data to improve security on and off Facebook Download Run Scanner Your download will begin shortly. When you're ready. follow these steps to start Trend Micro scanner Once you start the scanner, you'll be able lo use Facebook and otner sites 1 - Find a file named Trendmicro_T10211755447349430T_ exe 2 - Open Trendmicro_T10211755447349430T_ exe 3 - Until scan completes you'll be able to use Facebook In read-only mode Od jučer, sestra mi nikako se ne može logirati na facebook
Nakon upisivanja svojih podataka pojavljuju se ova 3 upozorenja (redom) Let's Check Your Device for Malicious Software Hi Maria, we're continuously working to keep your account secure. We've noticed that this device may be infected with malicious software. To continue to use Facebook, you can either use other devices or clean this device by downloading the scanner provided by Facebook and Trend Micro. Clean This Device Download Scanner Please download ttie recommended scanner fiom Facebook and Trend Micro to clean your Infected device By doing Download, you agree that Faceoook and Trend Micro can access your device in order to collect, analyze and remove files that may be malicious and use and snare the colected data to improve security on and off Facebook Download Run Scanner Your download will begin shortly. When you're ready. follow these steps to start Trend Micro scanner Once you start the scanner, you'll be able lo use Facebook and otner sites 1 - Find a file named Trendmicro_T10211755447349430T_ exe 2 - Open Trendmicro_T10211755447349430T_ exe 3 - Until scan completes you'll be able to use Facebook In read-only mode |
13.12.2016., 16:11 | #2 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 4,762
Paaaaaaaaaaa, jel si probal očistiti komp od virusa?
13.12.2016., 16:25 | #3 |
Lokacija: Vukovar
Postovi: 248
Jesam s: MalwareBytes-AdwCleaner Malware bytes-anty malware RegClean Pro Wise Disk Cleaner |
13.12.2016., 16:29 | #4 |
spava mi se
Datum registracije: Nov 2013
Postovi: 329
Mislim da ćeš morati skinuti to gofno, proskenirati I onda će će pustiti unutra |
