Staro 22.11.2016., 15:47   #1
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,692
Random restarti
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2016-11-22T07:48:20.807115800Z" />
<EventRecordID>2395</EventRecordID>
<Channel>System</Channel>
<Computer>DESKTOP-3R35IQR</Computer>
<Security />
</System>
- <EventData>
<Data>8:46:12 AM</Data>
<Data>‎11/‎22/‎2016</Data>
<Data />
<Data />
<Data>530356</Data>
<Data />
<Data />
<Binary>E0070B000200160008002E000C003B02E0070B000200160007002E000C003B023C0000003C000000000000000000000000000000000000000100000005000000</Binary>
</EventData>
</Event>
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>4</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2016-11-22T07:48:16.815616600Z" />
<EventRecordID>2410</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">257</Data>
<Data Name="BugcheckParameter1">0x18</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0xffffd201472a3180</Data>
<Data Name="BugcheckParameter4">0x6</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
</EventData>
</Event>
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000101 (0x0000000000000018, 0x0000000000000000, 0xffffd201472a3180, 0x0000000000000006). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 86032d19-c1ee-4795-868a-9f59e1369331.
- <System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2016-11-22T07:48:21.145614700Z" />
<EventRecordID>2402</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data Name="param1">0x00000101 (0x0000000000000018, 0x0000000000000000, 0xffffd201472a3180, 0x0000000000000006)</Data>
<Data Name="param2">C:\WINDOWS\MEMORY.DMP</Data>
<Data Name="param3">86032d19-c1ee-4795-868a-9f59e1369331</Data>
</EventData>
</Event>
Audit events have been dropped by the transport. 0
- <System>
<Provider Name="Microsoft-Windows-Eventlog" Guid="{fc65ddd8-d6ef-4962-83d5-6e5cfe9ce148}" />
<EventID>1101</EventID>
<Level>2</Level>
<Task>101</Task>
<Opcode>0</Opcode>
<Keywords>0x4020000000000000</Keywords>
<TimeCreated SystemTime="2016-11-22T07:48:21.072870900Z" />
<EventRecordID>19596</EventRecordID>
<Correlation />
<Execution ProcessID="1244" ThreadID="2060" />
<Channel>Security</Channel>
<Security />
</System>
- <UserData>
- <AuditEventsDropped xmlns="http://manifests.microsoft.com/win/2...ndows/eventlog">
<Reason>0</Reason>
</AuditEventsDropped>
</UserData>
</Event>
Svaka pomoć je dobrodošla
Imam problem sa random restartima svako X dana. Nekad nebude po tjedan-dva nekad restarta 2 put u 2 dana.
Komp je pod moj komp, OS je Win 10 x64
Upaljen je 24/7 ,i uvik radi nešto, ram je popunjen 90% uglavnom, 2 virtualne mašine itd.
Do hardvera nije, bar ja mislim.
Počelo se događat ima mnogo miseci tako da neznam točno što sam instalira prije nego se počelo događat al je pomalo krenilo ić na živce sve pokretat ispočetka, mašine i to
Evo Event Viewer posto ja nekužin ništa iz toga:
The previous system shutdown at 8:46:12 AM on ‎11/‎22/‎2016 was unexpected.
- <System>
<Level>2</Level>
<Task>0</Task>
<Security />
</System>
- <EventData>
<Data />
<Data />
<Data>530356</Data>
<Data />
<Data />
</EventData>
</Event>
- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
- <System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
- <EventData>
</EventData>
</Event>
- <System>
<Level>2</Level>
<Task>101</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
- <UserData>
<Reason>0</Reason>
</UserData>
</Event>
Staro 22.11.2016., 19:24   #2
Postovi: 17,138
Dobivaš BSOD ili se samo ugasi komp i ponovo upali?
Ide tipičan restart/shutdown windows screen, ili kao da si ga iz struje ugasio, odmah se ugasi?
Provjerio temperature i stanje harda?
Staro 22.11.2016., 20:50   #3
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,692
Problem je sta se to dogodi kad ja nisam na kompu.
Jednom sam ubra BSOD ,slucajno doša u sobu.
Jednom se desilo da zamrzne sve i mora sam ga sam restartat.
nekako virjen da je BSOD i/ili da se zamrzne i srusi...Bez "normalnog" restarta
Ali ostalih bar 10-20 puta me nije bilo tu.
Temp odlicne, SSD novi,testiran, sve normalno.
Edit:
Jel imaju neki logovi ili programi koji vade logove pa da neko ko se razumi pogleda?
Edit1:
C:\WINDOWS\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
Zadnje izmijenjeno od: webstartm. 22.11.2016. u 21:43.
Staro 22.11.2016., 22:26   #4
Postovi: 17,138
Ja mislim da je do hardware-a ipak.
Nisam siguran.
Staro 22.11.2016., 22:38   #5
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,692
Mozda fali soka CPU?
OC je na 4.2, vcore 1.256V i tako radi otkad ga imam.
I s time je prosa prime 24 sata, WoT, WoWs, GTA 5
Dignit cu mu malo napon iduci put kad se crasha,pa cmo vidit.
nemogu odma dignit jer mi se neda sve gasit pa palit opet
