Staro 01.05.2016., 08:34   #1
real01
real01's Avatar
Postovi: 83
Skype
Dobivam ovu poruku i ne mogu pokrenuti Skype:
Exception EINvalidPointer Operation in module Skype.Exe at 00005DA1
Invalid pointer operation.
Malo sam guglao i probao ove stvari:
https://community.skype.com/t5/Windo...p/td-p/4184829
DX diagnostic kaže da je sve okej, a ni ovo nije pomoglo:
Try to reset all Skype settings.
Quit Skype or use Windows Task Manager to kill any Skype.exe process. Go to Windows Start and in the Search/Run box type %appdata% and then press Enter or click the OK button. The Windows File Explorer will pop up. There locate a folder named “Skype”. Rename this folder to something different, e.g. Skype_old.
Next go to Windows Start and in the Search/Run box type %temp%\skype and then press Enter or click the OK button. Delete the DbTemp folder.
Restart Skype.
N.B. If needed, you will still be able to re-establish your call and chat history. All data is still saved in the Skype_old folder.
Ima tko kakav još prijedlog?
real01 je offline   Reply With Quote
