Povratak   PC Ekspert Forum > Računala > Periferija > Ostalo
Staro 13.03.2016., 04:07   #1
_saiko
system kaiser
Postovi: 194
Gdje nabaviti ukrasne podne vodilice za kabele
Tko u HR drzi bolji asortman vodilica, racewaya i ukrasnih letvi za IT kabliranje po uredima i za doma sa naglaskom na maloprodaju?
Znaci trazim ovakvo nesto:
u elmazu (samo veleprodaja) vidim ima onih spirala za kabele medjutim meni treba ovakvo nesto kao letva za organizaciju IT kabela gdje se kabeli mogu naknadno umetnuti (znaci bauhaus ovdje otpada).
Ima li neka od nasih firmi to u ponudi a za maloprodaju?
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
_saiko je offline   Reply With Quote
Staro 13.03.2016., 12:53   #2
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,491
Ovog imaš u svim trgovina elektromaterijala koji prodaju kanalice za kablove, to je podna kanalica
Staro 13.03.2016., 13:02   #3
_saiko
system kaiser
Postovi: 194
A kabelske spirale?
To sam htio isto spomenuti al mi je promaklo.
Znači ovo
https://www.elmaz.hr/ponuda/RAZ006-k...m-kab0014.html
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 13.03.2016., 15:45   #4
spaceman
spaceman's Avatar
Datum registracije: Feb 2010
Lokacija: Našice
Postovi: 329
Provjeri u Šaheru...link
spaceman je online   Reply With Quote
Staro 15.03.2016., 23:26   #5
boy005
boy005's Avatar
Postovi: 598
Autor _saiko Pregled postova
A kabelske spirale?
Znači ovo
imas u "instar-informatika"
boy005 je offline   Reply With Quote
Staro 16.03.2016., 01:30   #6
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,059
Spirale imaš u Bauhausu od fi (mislim) 0.8 ili 1 cm pa do 4 cm, samo što su imali samo crne i bijele (kad sam to kupovao prije nekih godinu dana, 2 m fi 1 cm je bilo nekih 20 kn)
Ove vodilice ako budeš išao u Bauhaus, također pogledaj kod njih ali ne na odjelu s elektrikom (strujom, žicama i sl.) već na odjelu s laminatima i drugim podnim oblogama.
Zadnje izmijenjeno od: bertone. 16.03.2016. u 01:35.
