Staro 01.11.2005., 09:11   #1
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
P4 Vs AMD64
AMD Athlon 64 3500+, 2200 MHz, 512 kb c., socket 939, BUS 2000 MHz, BOX (Venice core) 1.792,00
MBO ABIT, s. 939, Fatal1ty AN8 SLI, nForce 4 Ultra, BUS 2000 MHz, serial ATA II, RAID, 7.1 zvuk, DDR 400, 1Gbps, FireWire, Firewall, ATX 2 1.728,00_
RAM, 1 GB, DDR, PC-3200, 400 MHz, KINGMAX 934,00
VGA PCI-E SAPPHIRE ATI Radeon X550 128 bit, 128 MB, tv-out, DVI 550,00
DVD pisač, DVD±RW & DVD±R, NEC ND-3540, 16x, 8x dual layer 8.5 GB, bulk, crni 369,00
HDD WD Caviar 160 GB, serial ATA-II, 7200 o/min., 8 MB cache 667,00
6.036,00
INTEL P4 HT, 3.2 GHz, 2 Mb c., LGA 775, BUS 800 MHz, Prescott, EM64T, BOX 1.818,00
MBO EPOX, s. 775, 5NVA+ SLI, nForce4 SLI, BUS 1066 MHz, serial ATA II, RAID, 7.1 zvuk, 1Gbps, FireWire, DDR 2, ATX 2 1.629,00
RAM, 1 GB, DDR 2, PC-4300, 533 MHz, KINGMAX 817,00
5.848,00
Koji je bolji naravno bez oc-a????
Staro 01.11.2005., 10:19   #2
mighty
mighty's Avatar
Postovi: 519
IMO ovaj
VGA PCI-E SAPPHIRE ATI RADEON X800GTO, 256MB DDR3, DVI, TV
Raspoloživo, isporuka odmah
1.720,64 KN 1.610,81 KN
obriši
DVD±RW NEC ND-3540, 16x, black, Dual layer ± recording, bulk
374,16 KN 350,28 KN
obriši
HDD 160.0 GB HITACHI, Serial ATA II 3.0, 8 MB cache, 7200, Deskstar GST T7K250
686,02 KN 642,23 KN
obriši
2* RAM PC-3200, 512MB, DDR, A-DATA, Value, DDR 400 MHz
859,57 KN 804,71 KN
obriši
CPU AMD Athlon64 3000+ BOX, socket 939, Venice, 1800MHz, 512kb c., HTT 1000MHz
1.104,12 KN 1.033,65 KN
obriši
MBO DFI LAN PARTY UT nF4 Ultra-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939
1.295,75 KN 1.213,04 KN
obriši
ukupno: 6.040,27 KN 5.654,72 KN
mighty je offline   Reply With Quote
Staro 01.11.2005., 10:25   #3
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Originally posted by mighty
IMO ovaj
obriši
374,16 KN 350,28 KN
obriši
686,02 KN 642,23 KN
obriši
859,57 KN 804,71 KN
obriši
obriši
obriši
slažem se, ovaj venice lako dostigne takt onoga na 2.2, večina ide bez problema na 2.6ghz sa box coolerom
Staro 01.11.2005., 11:51   #4
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
moj odogovor ne dobis dok ne ispunis sva pravila koja si preksrio
blup
mc_fish je offline   Reply With Quote
Staro 01.11.2005., 12:27   #5
masni
masni's Avatar
Datum registracije: Apr 2003
Lokacija: Zagreb,Travno
Postovi: 2,110
procesori ekvivalentne brzine (znači venice 3000+ i intel 630 prescott 3ghz) imaju otprilike jednake preformanse...na defaultu naravno...
npr. super pi 1mb venice 3000+ računa za 45-46s, a intel 3.0ghz prescott za 44-45s...
treba jos koji test probati pa vidjeti, ali u principu, tu su negdje...osim u igrama, gdje je amd nešto malo brži...
e sad, ti si uzeo dosta lošu ploču za intela (IMO), u usporedbi sa abitom kojeg si uzeo za amd, takvu bi treba uzeti i za intela...recimo asus p5wd2 ili abit aw8...
problem kod intela - GRIJANJE...odnosno, u odnosu na venice, prescott se grije recimo nekih 25% više...(amd oko 30 stupnjeva, intel oko 40)...
ja bi intelu dao prednost, ako ti malo vece zagrijavanje i malo losije performanse u igrama ne predstavljaju problem...i tu je naravno HT (hyper threading), koji je po meni prilično korisna stvar...
eto, nadam se da sam pomogao...
Staro 01.11.2005., 15:52   #6
E.T.
E.T.'s Avatar
Postovi: 2,458
Kao sto i mc-fish kaze odakle da znamo sto da ti preporucimo kad nisi napisao nista sta ovaj podforum zahtjeva da napises...Nemojte da moram zakljucavati i brisati, sto mnogi clanovi od mene zahtjevaju kad vide ovakav thread... No ja imam razumijevanja i svjestan sam da konfiguracije nisu bas najprometniji dio foruma te da tu svoja pitanja vecinom postavljanu novi clanovi ili oni s nesto kracim stazom pa im zbog toga progledam kroz prste...
Dakle namijena!
-Ako je igranje u pitanju uzmi AMD-a ali 3000, a ne 3500 (oc 3000+ na njegov takt je izuzetno jednostavan) i uzmi neku postenu graficku karticu (pogledaj mightijev thread) min 6600GT...
-Sto se tice Intel konfiguracije nevidim na sto si ciljao no slazem se s masnim treba ti druga ploca a ako je namijena te konfiguracije nesto sto ce intezivnije koristiti multi-threading (sto trenutno nisu igre) onda se uzme:
Pentium IntelD 820 BOX 2.80GHz, 800MHz, 775-pin, 2×1MB (dual core)
1960 Kn
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 01.11.2005., 17:22   #7
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ma intel netreba netreba gamerima!!!!osim ak kanis istovremeno imat mjuzu,igru,teamspeake i video(a to ja i sa amdom imam)daklem pukni za sta ce ti dal se kloka itd itd(procitaj pravila) pa ti slozimo po voljii zelji do tad papa
blup
Staro 02.11.2005., 00:47   #8
psf[i]-[Tomek]
-nVidiot-
psf[i]-[Tomek]'s Avatar
Lokacija: Varaždin/Zabreg
Postovi: 962
Originally posted by mc_fish
teamspeake
Samo kaj mogu na ovo napisat je ROFLMAO!!
psf[i]-[Tomek] je offline   Reply With Quote
Staro 02.11.2005., 00:53   #9
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ehhe hebi ga potrebno
blup
Staro 02.11.2005., 01:39   #10
psf[i]-[Tomek]
-nVidiot-
Postovi: 962
Hihi znam al ŽDEEEEEEEEEEEERE procesora da je to jednostavno strašno!
Staro 02.11.2005., 01:50   #11
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Re: P4 Vs AMD64
6.036,00
5.848,00
Ako nemaš namjeru OCat zašto ne uzmeš
Foxconn NF4UK8AA-8EKRS, ATX, DDR, LAN
[fox-nf4uk8aa] 681,00 Kn Infocor
Foxconn je jako cjenjena firma u serverskom svijetu i sad su počeli proizvoditi i ploče za desktop PCe.
RAM nemoj Kingmax već uzmi Corsair ValueSelect 1GB DDR, PC3200 128Mx64non-ECC 184 DIMM, 756 Infocor
HDD Uzmi HDD HITACHI 160 GB, serial ATA-II, 7.200 o/min., 8 MB cache 631 Hgspot
Ostalo OK.
Za Intel
Foxconn 915A01-P-8EKRS2, ATX, DDR2
[fox-915a01p-] 693,90 Kn
Apacer DDR2 512Mb, 533Mhz, Dimm 240pin, Elp 387×2=774Kn Infocor
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 02.11.2005., 08:32   #12
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ovo mi se svida:
Sada jedino matična...po mojem ovdje ne ide searial ata 2 ili??? ak ne koju onda drugu uzeti???
Staro 02.11.2005., 15:02   #13
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
ide SATA II na tu ploču.
na
nF4-D ne ide jer nije Ultra nF4 čip
Grunf je moj idol!
