Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 15.11.2015., 11:55   #1
skeri123
Datum registracije: Nov 2015
Lokacija: Sarajevo
Postovi: 4
Koji su ramovi kompatibilni sa workstation?
Kupio sma workstation HP XW8400 bez rama i HDD pa me interesuje da li sve ove ramove mogu koristiti na njoj:
Kingston KVR667D2D8P5
APACER 2GB REG ECC PC5300 CL5
Kingston KVR667D2D4P5K2/4G
Svi su ECC ramovi 667Mhz 2GB.lp
skeri123 je offline   Reply With Quote
Staro 15.11.2015., 12:04   #2
B0ss
B0ss's Avatar
Postovi: 244
Mislim da ti je najbolje ovaj upit poslat direktno HP-u.
"Anything Less Than Immortality Is A Complete Waste Of Time."
B0ss je offline   Reply With Quote
Staro 15.11.2015., 14:02   #3
Postovi: 23,535
Mah, malo su zaglumili po HP site, za saznati odgovor treba malo kopati ...
Sreća pa je Google iskopao HP xw8400 Service and Technical Reference Guide > http://h50146.www5.hp.com/lib/doc/ma...364898-001.pdf
Na str. 67 piše:
Memory
Memory module features
● Eight memory slots for DIMMs
● 512–MB, 1-GB , 2-GB, 4-GB pairs
● 32 GB maximum configuration with 4-GB DIMMs
● Configurable for Single Channel (one DIMM), Dual Channel (two DIMMs), or Quad Channel (four to eight DIMMs)
● DDR2-667 or DDR2-533, Fully Buffered DIMMs (FBD)
● No support for mirroring
● No spare DIMM support
● Standard FBD, ECC (72-bit ECC)
Memory module requirements
● Use only PC2-5300F, FBDs. Certified and warranted HP memoryis recommended.
● Match DIMM pairs by size and type.
U prevodu tražiš DDR2 PC2-5300F 667MHz CL5 ECC Fully Buffered FB-DIMM (240 PIN) ukupne memorije "po želji".
Evo Memory QuickSpecs > http://www8.hp.com/h20195/v2/getpdf.aspx/c04284095.pdf
http://www.google.com/?gws_rd=ssl#q=em162aa+hp
Staro 15.11.2015., 17:03   #4
skeri123
Lokacija: Sarajevo
Postovi: 4
Hvala na odgovorima.
