Staro 20.08.2015., 14:22   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Preporuka za mobilni internet
Trebam preporuku za mobilni internet. Iskljucivo mobilni i iskljucivo VIP mreza jer druge ne pokrivaju signalom. Mislim da sam time ogranicen na VIP i Tomato, zar ne?
Trebam za pristup internetu sa 2 ili 3 uredjaja (lap, mob, tablet). Moze i za mobitel/tablet pri cemu ce ti uredjaji biti hotspot routeri. Moze i za modem/router za komp.
3g ili 4g. Nebitno. Bitno je da je sto bolji omjer gb/kn. Ima tko savjet? Ja gledam to sad i totalni mi je kaos. Po 1000 caka i skrivenih fora u svakoj ponudi....
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 20.08.2015. u 14:48.
estugarda je offline   Reply With Quote
Staro 22.08.2015., 00:09   #2
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Nisam više mogao čekati savjet, pa sam uzeo najmanje komplicirano rješenje; VIP mobilni Internet na bonove. 10kn za 24h, odnosno 1GB prometa. Pošto mi treba 6-9 dana mjesečno, to je još donekle prihvatljivo. 60-90kn za minimalno 6-9GB. Inače, ako koga zanima; kad se potroši 1GB unutar 24h, može se dalje surfati ali na 64kbps. Nakon 24h stvar se reaktivira i skine 10kn sa računa za novi ciklus, ako nešto ima na računu. Ako nema ništa, nema interneta. Doplatiti se može kupovinom bona na kiosku/dućanu, i navodno zaba Internet bankarstvom i upisom koda na korisničkim stranicama ili putem SMSa.
Što se hardvera tiče; nemam stick. Nema šanse da im dam 200kn za najgore sranje od 3G USB sticka. Stavio sam SIM u Note 2 3G verziju i koristim ga kao WiFI hotspot. Na taj način dobijem cca 8-9Mbit/s downloada. Ping sam zaboravio, mislim da je bilo nešto cca 40-50. Upload nisam čekao zbog štednje. Uglavnom; sve fino radi s tehničke strane.
Negativni dio priče je ciganluk VIP providera. Kad se kupi SIM, to košta 20kn. Na paketu piše da je 20kn na računu kao start paket. Ali kad sam se prijavio, dobio sam SMS da nemam ništa na računu i nisam se mogao spojiti. Nazvao sam korisničku službu, i tamo su se iščuđavali činjenici da na paketu piše da je 20kn uključeno. Pošto sam inzistirao, uplatili su mi 20kn na račun tokom razgovora. Dakle, s tim se mulja, pa pazite.
EDIT: Još jedna vrlo sumnjiva stvar se desila. Nakon prve aktivacije, ostalo je 10kn na računu za drugi dan. Kad sam htio aktivirati drugi dan, opet sam dobio poruku da nema dovoljno sredstava na računu, iako je moralo biti. Išao sam pogledati i provjeriti, i sustav je pokazivao 6kn. Dakle 4kn su nestale preko noći. Opet sam zvao korisničku službu, pa sam opet nakon mučnog uvjeravanja da VIP prodaje pakete sa 20kn na računu za 20kn, dobio optužbu da sam za te 4 kn skinuo neku aplikaciju. Što nije istina. Naravno, nisu mi "znali" reći gdje sam i kad skinuo aplikaciju ni koja je to. Nakon što sam par puta pitao, opet su mi vratili 4 kn na račun. Mislim 4kn je zanemariv iznos, i iskreno me boli za to, ali neprofesionalnost i nepoštivanje korisnika i bezobrazluk nisu zanemarivi. Ako su takvi prema novim korisnicima, što rade za godinu-dvije!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 23.08.2015. u 19:52.
Staro 25.08.2015., 18:38   #3
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
nekak sumnjam da si pokriven vipovim signalom a t-mobileovim da nisi.
alternativa ti je bonbon internet simica
bez ugovorne obveze
10 kn kosta kartica sa 10 kn na racunu.
stick za 100-150 kn na nuskalu (npr huawei 3131)
paketi su ti 3 kn dnevni paket od 300 MB
ili 5 GB za 45 kn koji vrijedi mjesec dana.
naravno ako potrosis prije, mozes aktivirat prije.
ja sam se vipa davno ostavio, jos dok su za mobilni internet imali antene u obliku walkie-talkieja...
(tad je 512 mb bilo 100 kn ) dosao mi je jedan mjesec bio brutalan racun (cca 270+ kn ) koji ja nisam nabio (jer sam si pratio promet du-metrom i nitko osim mene nije imao pristup racunalu / pin ), i otad su kod mene prekrizeni.
slow is smooth, smooth is fast...
Zadnje izmijenjeno od: santos. 25.08.2015. u 18:46.
santos je offline   Reply With Quote
