Staro 01.06.2015., 18:53   #1
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
NVIDIA GeForce WHQL Driver 353.06
  • Supports G-SYNC technology in windowed mode. (Supported for 2-way SLI, but not 3-way or 4-way.)
  • Offers both G-SYNC (V-SYNC on) and G-SYNC (V-SYNC off) options.
  • Adds support for Ultra-Low Motion Blur (ULMB) in the NVIDIA Control Panel.
  • Provides Dynamic Super Resolution (DSR) for notebooks with discrete GeForce GPUs, Fermi-based and above.
  • Implements optimizations and bug fixes that provide increased performance for Kepler-based GPUs.
  • Profil-Changes:
  • F1 2015 (added 3D Profile "rated as not recommended")
  • Heroes of the Storm (updated SLI Profile "set to SingleGPU Mode")
  • Killing Floor 2 (updated 3D Profile, Compatibility-Mode "rated as not recommended")
  • Monster Hunter Online (added SLI Profile)
  • Project CARS (updated 3D Profile,"rated as not recommended")
  • Space Engineers (added SLI Profile)
  • The Witcher 3 (updated 3D Profile, Compatibility-Mode "rated as good")
  • World Of Warships (updated 3D Profile "rated as not recommended")
  • Bugfixes:
  • [GeForce Experience, SLI]: Following an in-game resolution change, Shadowplay icon is missing after Alt+ Tab. [200108633]
  • [SLI]: Display goes to half tile when 3840 × 2160 resolution is applied. [200095220]
  • [OpenGL, Windows 8.1 -x86/x64]: GLSL shader compile error. [1647324]
  • [N16x, Windows 8 -x64]: Allow overclocking settings to be read from the video BIOS as long as it has overclocking enabled. [1579756]
  • Additional Details:
  • Installs PhysX System Software 9.15.0428
  • Installs HD Audio 1.3.34.3
  • Installs GeForce Experience 2.4.5.28
Windows Vista, 7, 8, 8.1 64bit
Windows Vista, 7, 8, 8.1 32bit
Za Windows 10 još nema.
Navodno popraviše Keplera, bar u Witcheru.
tole_ je offline   Reply With Quote
Staro 02.06.2015., 17:35   #2
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,573
I na ovoj verziji driver dobivam konstantne TDRove
Driver instaliran preko DDUa kroz safe mode.
Note : Događa se na Desktopu a najviše u Chromeu
http://i.imgur.com/yHfNKRs.png
Pošten trgovac:
1,2,3,
Staro 06.06.2015., 12:02   #3
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Što govore za GTA 5? Imali kakvog poboljšanja / pogoršanja?
Staro 06.06.2015., 12:07   #4
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,175
ja nisam primjetio nikakav pomak na gtx 770, i odlucio sam promjeniti stranu nazad na ati
prvo 3.5 s 970, sada ovo s keplerom, dosta da izgubim povjerenje
Staro 06.06.2015., 12:49   #5
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,573
Autor Gemmy Pregled postova
Pa meni je 770ka mljela na ultra sve na 55fpsa, smanjio detalje vode i trave na normal i msaa x2 i to je to. Ne razumijem sto tebi nije radilo ?
Niti jedan takav problem, snimam drivere uredno jedne preko drugih.
